I have a 2TB external disk that suddenly lost its partition information (and I'm invited to repartition/format from Windows 10). Running Testdisk "finds" some linux partitions (no idea why, since they were never there), but also sees this
NTFS at 243200/235/43
filesystem size 3907022848
mftmirr_lcn 2
HPFS - NTFS 0 0 1 243200 235 43 3907022848
NTFS found using backup sector, blocksize=4096, 2000 GB / 1863 GiB
Partition not added.
So I try to add the partition manually
Drive P: - 2000 GB / 1863 GiB - CHS 243200 255 63
HPFS - NTFS 0 0 1 243199 254 63 3907008000
[Cylinder] [ Head ] [ Sector ] [Cylinder] [ Head ] [ Sector ]
[ Type ] >[ Done ]
when I click on Done, I get nothing (see below)... What is going on? What am I missing? Thanks in advance!
Keys A: add partition, L: load backup, Enter: to continue
Can't create partition
Re: Can't create partition
No partition has been lost otherwise, P: will not be here.
Run TestDisk, select the PhysicalDrive corresponding to P:, Advanced, select the partition, Boot, RebuildBS, List.
If you can see your files, choose Write, confirm, Quit and restart your computer.
rvyhmeister
On entering TestDisk I did this:
1. Select the drive
2. Select the [Intel] partition type ([none] is preselected).
3. Select [Advanced]
And now I see this (blank lines removed). The "drive" exists, but the partition is not there...
Drive E: - 2000 GB / 1863 GiB - CHS 243200 255 63
No partition available.
>[ Quit ]
Return to main menu
Here's the log from this session. Thanks in advance for any assistance.
Sun May 08 10:29:56 2016
OS: Windows 8 (9200)
Compiler: GCC 4.9, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=491536777216
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000395698176
Disk \\.\PhysicalDrive0 - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Drive C: - 491 GB / 457 GiB - CHS 59759 255 63, sector size=512
Drive E: - 2000 GB / 1863 GiB - CHS 243200 255 63, sector size=512
1. Select the drive
>[ Quit ]
Return to main menu
