Recovering a NTFS partition corrupted by Mac
mcfchan
#1 Post by mcfchan »
A partition of my drive becomes unreadable. My PC is configured to dual boot Mac OS El Capitan and Windows 10. So there is a drive having Win10 UEFI installed. I tried to set the Mac Time Machine drive to be the partition/drive of Win10. Time Machine prompted me the partition does not have enough space to do be a Time Machine drive. So I quite setting up the Time Machine drive. Then the Win 10 partition in NTFS becomes unreadable. The partition cannot be accessed in Mac. When I tried to boot Win10, it failed to start. I then install a Win 7 in another drive and find that the Win10 partition cannot be accessed. It looks the Time Machine in Mac has corrupted this NTFS partition.
In TestDrice, I chosen the drive having issue and select type as GPT as it is detected( wonder should choose Intel type instead?)
After Analyse, it shows:
Warning: the current number of heads per cylinder is 255
but the correct value may be 128.
You can use the Geometry menu to change this value.
Shall I change the value to 128 and if this can be changed back to 255 afterwards?
Merci!
Re: Recovering a NTFS partition corrupted by Mac
Use TestDisk 7.1-WIP, it will not display this warning message useless for EFI GPT.
mcfchan
#3 Post by mcfchan »
Hi I using EFI FPT type and the Quick Search shows below:
Warning: number of heads/cylinder mismatches 16 (FAT) != 255 (HD)
EFI System 40 409639 409600 [EFI System Partition]
Mac HFS 9474092 17862701 8388610 [~?~?~?M-:D^A]
it is processing per cylinder and probably take more than 10 hrs to complete. will this recover the whole partition after Quick Analyse?
Thanks
cgrenier wrote:Use TestDisk 7.1-WIP, it will not display this warning message useless for EFI GPT.
For a fast check, choose Stop, Deeper Search, Stop. If you see your NTFS partition, set it to P(rimary). On next screen, choose Write, confirm, Quit and restart your computer.
mcfchan
#5 Post by mcfchan »
Hi As shown in last post, can you show me if the partition can be recovered? Thanks!
