Fix XENIX bad blocks in a ExFAT drive?
n3wb13
#1 Post by n3wb13 »
I recently bought a 64GB Samsung microSD card formatted in ExFAT. I also tried to format it to NTFS but never succeeded. At first I tried to copy a 40GB file back and forth and the file checksums matched.
However, when I tried to use softwares to test the microSD card like H2testw and FakeFlashTest, both gave me an error message and couldn't process the test. Windows even asked me if I wanted to check and fix the drive or not after that. Even so, Chkdsk utility told that the drive was okay.
So I used TestDisk to check against the drive and the program listed that there were some sort of Xenix bad block. Here come the logs:
Disk \\.\PhysicalDrive1 - 64 GB / 59 GiB
Analyse Disk \\.\PhysicalDrive1 - 64 GB / 59 GiB - CHS 7783 255 63
check_part_i386 1 type FF: no test
check_part_i386 2 type FF: no test
check_part_i386 3 type FF: no test
check_part_i386 4 type FF: no test
 1 * Xenix bad block      267349  89  4 534698 178  6 4294967295
Warning: Bad starting head (CHS and LBA don't match)
 2 * Xenix bad block      267349  89  4 534698 178  6 4294967295
 3 * Xenix bad block      267349  89  4 534698 178  6 4294967295
 4 * Xenix bad block      267349  89  4 313426 126 42  740229375
     HPFS - NTFS              2  10  9  7783 139 36  125009920
     exFAT, blocksize=131072, 64 GB / 59 GiB
   * HPFS - NTFS              2  10  9  7783 139 36  125009920
Can anybody tell me how can I fix this please? The drive doesn't have any data so I can try whatever methods there are. Thank you very much for your help.
Re: Fix XENIX bad blocks in a ExFAT driev?
As listed by TestDisk, your device isn't partionned.
Using Windows Disk manager, it's possible to create an PC/Intel partition table and next create an NTFS partition.
If it doesn't work, use your warranty to get a new memory card.
n3wb13
Re: Fix XENIX bad blocks in a ExFAT drive?
#3 Post by n3wb13 »
Thanks for the reply. I opened the Windows Disk Management, but I could neither delete/shrink/extend the volume or mark it as active. The only options available was to format. So how can I create that PC/Intel partition?
