Copy paste, Overwrite/replace existing file
supersaint71
#1 Post by supersaint71 »
Hi All,
I have been looking through the forum and been making google searches and I can't seem to find the solution to this problem.
I took some important pictures in April my wife took them off the SD card and put them into a folder in windows.
Photographs:
-Dsc_001.jpg 04/23/2016
-Dsc_002.jpg 04/23/2016
We then took some more photos and for some reason the camera named them the same file name. We dropped the photos into the photographs folder and windows 10 did a copy replace of the existing files. Now the folder is like so:
Photographs:
-Dsc_001.jpg 06/03/2016
-Dsc_002.jpg 06/03/2016
I tried using testdisk and photorec on the folder and the sd card with no success i have found a lot of other deleted images but not the ones i want. I tried using windows backup recover but both sets of images were copied onto the pc after the last image.
Does anyone have any suggestions on what to do? I really want this pictures back!!
Thank you
sd
Re: Copy paste, Overwrite/replace existing file
Unfortunately it's not possible to recover overwritten files.
supersaint71
#3 Post by supersaint71 »
I thought this may have been the case. Any suggestions on why the SD card doesn't have the images as they were deleted, I have found a lot of other deleted images on the card but the images that I want aren't part of it.
The way I look at it there are three ways the images can be removed from the SD card. Cut, delete through Windows and delete on the camera. I don't know what happens when they are cut or when they are deleted on the camera but if they are deleted through Windows would they have been sent to the recycle bin?
Thanks
Sd
