anyway to re-login to Testdisk?
Hi, I am sure I am not alone in that I have started a search for a patition using Testdisk, only to have the computer go to sleep and logout. I have disabled sleep altogether including the drives and somehow it went to sleep anyway. After logging back into the iMac, (Yosemite 10.10.5), I try to restore the Testdisk session only to have to start all over again. Anyway to pick up where I left off? Thanks.
Re: anyway to re-login to Testdisk?
Unless TestDisk has been left, it should continue to search partitions when your computer returns from sleep.
Ok not sure why Testdisk seems to be quitting on its own then. I have run "analyze" trying to repair a Mac HFS partition on a WD 4 TB external drive. I run it for a few days and I have disconnected the keyboard so no family member accidentally logs out of my user. Several times I have discovered what looks like a reboot. Its logged out and the state of the terminal window looks like this:
The initial find looks like this:
Here is the log:
Mon Jun 20 11:33:17 2016
TestDisk 7.1-WIP, Data Recovery Utility, April 2016
OS: Darwin, kernel 14.5.0 (Darwin Kernel Version 14.5.0: Thu Apr 21 20:40:54 PDT 2016; root:xnu-2782.5
Compiler: GCC 4.0
Compilation date: 2016-04-20T15:53:57
Disk /dev/disk0 - 1000 GB / 931 GiB - 1953525168 sectors (RO), sector size=512
Disk /dev/disk1 - 4000 GB / 3725 GiB - 976746240 sectors, sector size=4096
Disk /dev/rdisk0 - 1000 GB / 931 GiB - 1953525168 sectors (RO), sector size=512
Disk /dev/rdisk1 - 4000 GB / 3725 GiB - 976746240 sectors, sector size=4096
Partition table type: EFI GPT
Analyse Disk /dev/rdisk1 - 4000 GB / 3725 GiB - 976746240 sectors
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=976746239 (expected 976746239)
hdr_lba_start=6
hdr_lba_end=976746234
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
2 P Mac HFS 77056 976713466 976636411 [Apple_HFSX_Untitled_2]
1 P EFI System 6 76805 76800 [EFI System Partition]
No HFS or HFS+ structure
Any ideas why it will not finish the scan?
Maybe it doesn't need to?
Can I just create the partition from this info?
Thanks.
Compiler: GCC 4.0
hdr_size=92
hdr_lba_self=1
hdr_lba_start=6
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
Thanks.
- Screen Shot 2016-06-18 at 5.05.44 PM.png (66.88 KiB) Viewed 3023 times
- Screen Shot 2016-06-18 at 5.07.21 PM.png (75.32 KiB) Viewed 3023 times
