NTFS readable with partition type 'none', windows wants to format the drive
axerqz
#1 Post by axerqz »
I recently moved a 3 TB hard drive from a usb docking station into my desktop, which resulted in the drive becoming corrupt (in Windows, at least). Linux happily mounts my drive as a NTFS filystem (on /dev/sdX, not /dev/sdX1). Testdisk detects partition type none, and finds the NTFS filesystem along with all files. Selecting Intel/PC, however, shows the following output:
Invalid NTFS or EXFAT boot
 1 * HPFS - NTFS          120527  49 53 234813 237 34 1836016416
Bad relative sector.
 2 * Sys=73               119380 132 62 153270  41 37  544437093
 3 * Sys=2B               113201  29 24 147074 114 59  544175136
 4 * SpeedStor            177063 118 26 177066 225 63      54974
Is there any way to restore the partition table (I'm guessing this is the issue?) without having to copy all files to another drive (which I don't have, otherwise I would have done that)?
Re: NTFS readable with partition type 'none', windows wants to format the drive
The safest solution may be to
- copy all the files
- create a partition
- reformat it as NTFS
- copy all the files back
