2TB drive shows up as RAW after windows 10 upgrade
MortarWolf
#1 Post by MortarWolf »
Long story short.
This drive I tried to recovered was on windows 7 and it was accelerated with intel rapid storage technology.
I then upgraded to windows 10 without undoing this.
Windows kept on crashing, so I went back windows 7.
Back to windows 7, the hard-drive suddenly shows up as unformatted/RAW.
I somehow went back to windows 10 again and ran testdisk. I ran quick scan and received this log file. I'm not sure where to go from here.
Any advice would be appreciated.
Disk /dev/sdb - 2000 GB / 1863 GiB
1 P HPFS - NTFS 0 32 33 243200 203 11 3907018752
ntfs_boot_sector
filesystem size 1 7889892233288307698
sectors_per_cluster 0 57
mft_lcn 0 2331110192
mftmirr_lcn 0 606914529
clusters_per_mft_record 0 64
clusters_per_index_record 0 -99
Status: Bad
Status: Bad
Sectors are not identical.
rebuild_NTFS_BS
mft at 16
ntfs_find_mft: mft_lcn 786432
ntfs_find_mft: mftmirr_lcn 2
New / Current boot sector
filesystem size 3907018752 1
sectors_per_cluster 8 0
mft_lcn 786432 0
mftmirr_lcn 2 0
clusters_per_mft_record -10 0
clusters_per_index_record 1 0
mft_lcn 786432 0
mftmirr_lcn 2 0
ntfs_boot_sector
Status: Bad
Status: Bad
Invalid NTFS or EXFAT boot
BAD_RS LBA=2991118879 5084706
FAT16 <32M 186188 137 29 192073 160 51 94543997
BAD_RS LBA=3841799935 4246609
FAT12 239140 251 23 384976 143 31 2342848545
This partition ends after the disk limits. (start=3841799935, size=2342848545, end=6184648479, disk end=3907029168)
file_pread(5,2,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(5,14,buffer,3907031041(243201/110/47)) lseek err Invalid argument
file_pread(5,3,buffer,3907031055(243201/110/61)) lseek err Invalid argument
file_pread(5,3,buffer,3907031102(243201/111/45)) lseek err Invalid argument
file_pread(5,8,buffer,3907031118(243201/111/61)) lseek err Invalid argument
file_pread(5,11,buffer,3907031165(243201/112/45)) lseek err Invalid argument
file_pread(5,2,buffer,3907033087(243201/143/14)) lseek err Invalid argument
The harddisk (2000 GB / 1863 GiB) seems too small! (< 3166 GB / 2949 GiB)
L FAT16 <32M 186188 137 29 192073 160 51 94543997
dir_partition inode=0
181647391 -rwxr-xr-x 0 0 908018678 26-Jul-1930 07:53 ￧J￲ᅧJ￶ᅨ.
251298585 -r-xr-xr-x 0 0 2518985759 4-May-2015 21:32 ᅠEヌ￁사ᄌヘ.￯cᆭ
248203078 dr-xr-xr-x 0 0 2197005773 21-Jul-2022 07:42 ᄈ↑ᄃ?�ᄅ￰ᆲ.テᆱ
159006326 drwxr-xr-x 0 0 779895899 28-Nov-1932 18:27 ᄀムpᅯT￲¬B.ᄚ[
225331867 -r-xr-xr-x 0 0 1401584959 25-Jan-1947 06:06 &ホ*￞z→ᆳ.トホ1
228887528 -r-xr-xr-x 0 0 2049732876 11-Jun-2007 12:26 ￳Xヌ￀ᅭa￴ᅴ.k`ᅳ
193331121 dr-xr-xr-x 0 0 2254429820 8-Nov-1945 18:42 ᄚ ゚ "M N.ᅮ￀m
117000180 -r-xr-xr-x 0 0 1066394562 21-May-2014 03:44 gメc,hᆳ8￸.ᅧᅧ1
129204127 -rwxr-xr-x 0 0 3643226539 16-Sep-1993 22:48 n￵ᅰW-ᅴ.￿0
110888190 dr-xr-xr-x 0 0 2374162124 13-Aug-2019 19:50 ￧ユW^IC￷ . ̄ᅦᄑ
222808606 drwxr-xr-x 0 0 2768155759 14-Jan-2003 04:03 0]￉→ᅤ`ᄉツ.ᄎ￾\
15464627 dr-xr-xr-x 0 0 2070680270 1-Nov-1952 23:01
ヘ(-￙
﾿ホ.Rᄐ￀
109251525 dr-xr-xr-x 0 0 3576700670 20-May-1933 06:27 ワW↑ニヒワᅯ./ ;
104926854 -rwxr-xr-x 0 0 2119703216 4-Oct-1968 22:13 ᅵモK￾ ᆵᅴ
Re: 2TB drive shows up as RAW after windows 10 upgrade
Run TestDisk, Analyse, Quick Search, use 'p' on each partition. If you see your files, choose Write, confirm, Quit and restart your computer.
If it doesn't work, use PhotoRec to recover your data. Note that it will not recover the original filenames.
https://www.cgsecurity.org/wiki/PhotoRec_Step_By_Step
MortarWolf
#3 Post by MortarWolf »
Quick search gave me the error log that I've posted above. All the files shows up as a garbled mess. Are you saying that deeper search is a waste of my time?
Is there any other solutions than PhotoRec?
MortarWolf
#4 Post by MortarWolf »
Well I did a deeper search and was able to find my lost partition.
What freaked me out was when I pressed Q and then enter, I somehow ended up in the "select drive" screen.
I thought I had to do the deep search again. After mucking about and choosing "backup BS", I was able to find the "Write" command. I wish the flow was a bit less nerve racking.
I any case, Deeper Search somehow lead me back to a functioning drive. :D
