Accidental format of 2TB external drive Topic is solved
remy
Re: Accidental format of 2TB external drive
#11 Post by remy »
Use 6.14. You work under gnu/linux, it's quite easy :
wget http://www.cgsecurity.org/testdisk-6.14-WIP.linux26.tar.bz2
tar -xjf testdisk-6.14-WIP.linux26.tar.bz2
mv testdisk-6.14-WIP/*_static ~/
sudo ~/testdisk_static /dev/sdb
I can't see in your log the result of deepersearch. Are you sure you've done it this time ?
If no, please try to find a similar partition with "D" status, and try to list.
If yes, as far as I can guess what happened, it seems that the filesystem has been reformatted, not a nerw partition created. That means corruption on MFT, because new MFT were created in the same place. You'll then probably have to use commercial DR software in that case, or ask help of a specialized Cie.
Scooby
#12 Post by Scooby »
Does anyone have any other ideas, as I am fresh out?
If not should I just proceed with my backup plan from the 1st post (skipping the image creation step)?
Scooby
#13 Post by Scooby »
Ok, I will try 6.14 and get back to you. I am sure I did a deepsearch but perhaps I sent the wrong log file.
PS
Just ignore the last message as I sent it before I saw the posting prior to that.
Scooby
#14 Post by Scooby »
I installed and ran testdisk 6.14 as instructed. Here is the log file:
testdisk.zip
testdisk 6.14 log with deepsearch
(1.92 KiB) Downloaded 1303 times
In case it helps here is what testdisk showed after the deepsearch:
The harddisk (2000 GB / 1863 GiB) seems too small! (< 2634 GB / 2453 GiB)
>  FAT16 <32M           209156  52 59 320310 188 19 1785697539
And after that it listed this partition. I see the status column you mentioned and it is set to * so I guess the drive must have been reformatted.
>* HPFS - NTFS              0   1  1 243200 254 63 3907024002 [NexStar3: ]
     Enter: to continue
NTFS, blocksize=512, 2000 GB / 1863 GiB
Looks like I will have to use a professional DR software. Do you have any recommendations?
Thanks for all your help remy!
#15 Post by Fiona »
TestDisk didn't find another partition.
Datarecovery software might be a good idea.
PhotoRec would be able to recover data from a seriously damaged file system.
But it doesn't keep file names and directories.
If you'd like to test software where you'd be able to recover it, you can check scavenger and Restorer Ultimate.
Scooby
#16 Post by Scooby »
Thanks Fiona, I'll give those a try.
Scooby
#17 Post by Scooby »
Sorry for taking so long to get back to you on my results but things have been crazy busy lately.
So far I have recovered a lot of my files by using a different app as suggested. Still working on it but looks like I won't be recovering some (somewhat) important backups. But these are not important enough to pay a lot of money for a professional service.
Thanks again for all your help everyone :D
