not enough space available
I am running kali linux usb and trying to recover some deleted files using photorec. I have updated photorec to version 7, but each time i run the program i keep getting not enough space available. I am trying to recover files from a 1tb hard disk to a 3tb external (ntfs format). I have followed your step by step instructions, but no matter what i do, i still get the "not enough space available". I will confess, i am no expert when it comes to linux and do find the file structure a bit different. At the moment, my external drive should be in the /dev/sdb1 directory. I have checked it is mounted. i have also checked the /media, /mnt or /run/media directories, but cannot find the external drive listed. Please help.
Re: not enough space available
/dev/sdb1 is a device, not a directory.
Run the command "mount", if /dev/sdb1 is listed, you will see the mount point (directory).
If it's missing, as root, run "mount /dev/sdb1 /mnt" to mount the partition in /mnt
My apologies for using the word "directory" when i should have used device. All i am trying to do is to recover my files to an external seagate drive, not a folder/directory. However, everytime I try and use the C to select my destination, i get no free space available. At the terminal, i have type mount as you suggested. This command lists /dev/sdc1 on /media/root/seagate. I therefore, started photorec again and attempted to use /media/root/seagate for my destination. Once again, i get no free space available. Please note, there is nothing on the seagate 3tb drive.
