exFat rewritten to NTFS boot disk from ISO
Slawkos
#1 Post by Slawkos »
I would like to say hello to everybody as a new be on this "book of wisdom".
I have got in trouble when preparing bootable USB from ISO and unfortunately got confused with too many disks connected to de computer.
The good news is that I have got log and I can see the reformatted exFAT partitions and I can list the files after Deep Search (took 3 days).
Despite Ive created bkup of the disk but I am affraid to recover it on my own as the partitions are starting and ending like they're overlapped. It was a regular disk with no bootable partition, can't remember if it was two logical or extended if it matters. Those partitions was equal 500GB each or close to it, one of them was before Mac partition.
Fri Aug  5 22:07:03 2016
OS: Darwin, kernel 14.5.0 (Darwin Kernel Version 14.5.0: Thu Apr 21 20:40:54 PDT 2016; root:xnu-2782.5
Compiler: GCC 4.0
Compilation date: 2015-04-18T13:01:34
Disk /dev/disk0 - 250 GB / 232 GiB - 488397168 sectors (RO), sector size=512
Disk /dev/disk2 - 1000 GB / 931 GiB - 1953504688 sectors, sector size=512
Disk /dev/rdisk0 - 250 GB / 232 GiB - 488397168 sectors (RO), sector size=512
Disk /dev/rdisk2 - 1000 GB / 931 GiB - 1953504688 sectors, sector size=512
Analyse Disk /dev/rdisk2 - 1000 GB / 931 GiB - 1953504688 sectors
BAD_RS LBA=63 1
NTFS at 63/0/1
check_part_i386 2 type EA: no test
get_geometry_from_list_part_aux head=1 nbr=4
Warning: number of heads/cylinder mismatches 255 (NTFS) != 1 (HD)
Warning: number of sectors per track mismatches 63 (NTFS) != 1 (HD)
 1 * HPFS - NTFS                   63 1953504566 1953504504
 2 P Sys=EA                1953504567 1953504629         63
.............................................deleted many entries.............................................
     FAT16 >32M            4819916519 4983048766  163132248
This partition ends after the disk limits. (start=4819916519, size=163132248, end=4983048766, disk end=1953504688)
HFS+ magic value at 977014584/0/1
part_size 976490040
     HFS                    977014584 1953504623  976490040
     HFS+ blocksize=4096, 499 GB / 465 GiB
     HPFS - NTFS            977014584 1953504629  976490046
     exFAT, blocksize=131072, 499 GB / 465 GiB
HFS+ magic value at 977014586/0/1
part_size 976490040
     HFS                       524548  977014587  976490040
     HFS+ found using backup sector!, 499 GB / 465 GiB
HFS+ magic value at 977014596/0/1
part_size 976490040
     HFS                    977014596 1953504635  976490040
     HPFS - NTFS            977014596 1953504641  976490046
HFS+ magic value at 977014598/0/1
part_size 976490040
     HFS                       524560  977014599  976490040
BAD_RS LBA=2822020870 460
     FAT32 LBA             2822020870 3448490556  626469687
This partition ends after the disk limits. (start=2822020870, size=626469687, end=3448490556, disk end=1953504688)
BAD_RS LBA=3027511925 435
     FAT12                 3317383056 7103432760 3786049705
This partition ends after the disk limits. (start=3317383056, size=3786049705, end=7103432760, disk end=1953504688)
NTFS at 1953504566/0/1
filesystem size           1953504504
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     NTFS found using backup sector, blocksize=4096, 1000 GB / 931 GiB
mftmirr_lcn               2
NTFS: Can't read MFT
     HPFS - NTFS           1953504566 3907009069 1953504504
This partition ends after the disk limits. (start=1953504566, size=1953504504, end=3907009069, disk end=1953504688)
The harddisk (1000 GB / 931 GiB) seems too small! (< 5057 GB / 4710 GiB)
     FAT16 <32M              23889844 2369073339 2345183496
     FAT16 LBA              135321497 3483154496 3347833000
     FAT16 >32M             175803015 2516389150 2340586136
     FAT32                  235299285 3757607616 3522308332
     FAT16 LBA              259771959 2109462310 1849690352
     FAT16 >32M             282342851 2858870811 2576527961
Now Im trying to copy some files but TestDisk is copying but it says failed.
Screen Shot 2016-08-08 at 22.21.36.png (26.23 KiB) Viewed 2250 times
I can't stop the copying process (can I :?: )
Screen Shot 2016-08-08 at 19.07.33.png (192.54 KiB) Viewed 2250 times
I don't won't to wait another 3 days to finish Deep Scan again when I close the program, is there any way to fix the disk knowing the data from the log?
Please for help, thanks.
Re: exFat rewritten to NTFS boot disk from ISO
Renamed your testdisk.log to avoid to overwrite it with new values.
After Quick Search, choose Stop, use 'a' to manually add the partitions to recover using the values found in the log file.
Set the partitions to P(imary). On next screen, choose Write, confirm.
Go in Advanced, for each partition, choose Boot. If the boot sector is damaged (Bad), choose BackupBS, confirm.
Quit and restart your computer.
Slawkos
#3 Post by Slawkos »
cgrenier thank you for the replay and help :)
I try to do as you suggested but there was no option to type manually the partitions after the quick search I had to do another "deeper search" then I could do it. I can only set one of the partitions as primary otherwise the program says "Structure: Bad"
Screen Shot 2016-08-09 at 10.52.57.png (37.44 KiB) Viewed 2242 times
Screen Shot 2016-08-09 at 10.55.42.png (41.11 KiB) Viewed 2242 times
they seems to overlap or something as both of them are starting very close to each other.
I'm also confused with the "HFS+ found using backup sector!, 499 GB / 465 GiB" - can we not use of the backup sector
and then it says it's exFAT
don't know what to do next
