So, the exfat partition on my secondary harddrive gets screwed up every now and then, but the usual fix wasn't working and I ended up attempting to use DD to fix it. WHOOPS, that erased the partition table for that partition and also the HFS partitions on the same drive.
I ran TestDisk and it detected the HFS partitions just fine, but the exFat partition is labeled "unknown", and I can't figure out how to select ExFat. Do I have to just copy all the files to an external HD (since I see it says testdisk can do that), or is there way to recover that partition also?
Restore ExFat Partition
Re: Restore ExFat Partition
Once the partition table has been rewritten, go in Advanced, select this partition, choose List and copy your files.
