Hi all,
Ive searched high and low for possible solutions with test disk with no luck.
I have a San Disk Ultra 64gb microSD card plugged into the appropriate adapter going straight into my mac. On it are videos Im trying to retrieve that were deleted by the GoPro importer app because of the "automatically delete after import" option. They were deleted after a failed import due to multiple GoPro cameras having same name.
No other data has been written on the card since, so there should be nothing that has overwritten them yet.
I have tried PhotoRec. It is able to find and restore damaged versions of the videos, which I was able to try and repair, however that will not suffice for the video I am trying to make - 360 video requiring 6 videos of the same FPS etc...
I have tried
- Undelete - only shows the folder the files were in. When trying to open that folder, I get "No file found, filesystem may be damaged"
- Geometry fix - I was getting the error saying "head is showing 1 but it may be 128"
- Making a clone of the disk and using testdisk on the clone image and trying to change values further with no luck
- Analyzing - I get a "Warning: Bad ending head (CHS and LBA dont match)
___________________________________________________
Disk /dev/disk3 - 63 GB / 59 GiB - 124735488 sectors (RO)
1 * HPFS - NTFS 32768 124735487 124702720
After quick search:
Enter: to continue
exFAT, blocksize=131072, 63 GB / 59 GiB
_________________________________________________________
Based on all of the searching Ive done, I cannot seem to find any other options to what should be a very easy fix. The same problem happened again to a different card and I was able to Undelete those files instantly using testdisk.
A couple questions I had:
Should I be writing a partition table to the card after it did a deep search? Test disk says Write access for this media is not available.
My card is also easily recognizable by my mac, so the card seems to be working fine. The issue seems to be in finding the lost partition or filesystem with my files on it.
Any help would be greatly appreciated!
Chris
Filesystem damaged/Undelete Micro SD Card GoPro Videos
chriscombs
Re: Filesystem damaged/Undelete Micro SD Card GoPro Videos
Can you provide a disk image of the memory card ? Run TestDisk Advanced, Image Creation. Once done, compress (ie. zip) the image.dd file and share it via Google Drive or similar service.
