I am trying to use testdisk but cannot get past the Search stage. After Quick Search is complete, it reports that there are no partitions. Same happens after Deep Search.
Here is the log (the partition in question is /dev/sdb1):
Sat Jun  9 09:18:48 2012
Command line: TestDisk /log /dev/sdb1
OS: Linux, kernel 2.6.18-194.8.1.el5 (#1 SMP Thu Jul 1 19:04:48 EDT 2010) x86_64
Compiler: GCC 4.4
Compilation date: 2011-11-15T02:42:19
ext2fs lib: 1.41.9, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20100226
Disk /dev/sdb1 - 2000 GB / 1863 GiB - CHS 243200 255 63, sector size=512 - WDC WD2003FYYS-02W0B1, S/N:WD-WMAY04712663, FW:01.01D02
Disk /dev/sdb1 - 2000 GB / 1863 GiB - WDC WD2003FYYS-02W0B1
Analyse Disk /dev/sdb1 - 2000 GB / 1863 GiB - CHS 243200 255 63
Ask the user for vista mode
Computes LBA from CHS for Disk /dev/sdb1 - 2000 GB / 1863 GiB - CHS 243201 255 63
search_vista_part: 1
> fsck /dev/sdb
fsck 1.39 (29-May-2006)
e2fsck 1.39 (29-May-2006)
Couldn't find ext2 superblock, trying backup blocks...
fsck.ext2: Bad magic number in super-block while trying to open /dev/sdb
The superblock could not be read or does not describe a correct ext2
filesystem.  If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
    e2fsck -b 8193 <device>
On the other hand, photorec and fdisk appear to recognize the partition (at least, partially). Here is the photorec log:
Sat Jun  9 22:06:03 2012
Command line: PhotoRec /log /dev/sdb1
PhotoRec 6.13, Data Recovery Utility, November 2011
Compiler: GCC 4.4
ext2fs lib: 1.41.9, ntfs lib: libntfs-3g, ewf lib: 20100226, libjpeg: 62
Disk /dev/sdb1 - 2000 GB / 1863 GiB - CHS 243200 255 63 (RO), sector size=512 - WDC WD2003FYYS-02W0B1, S/N:WD-WMAY04712663, FW:01.01D02
Can't open photorec.ses file: No such file or directory
   P Unknown                  0   0  1 243200 253 63 3907024002
New options :
 Paranoid : Yes
 Brute force : No
 Keep corrupted files : No
 ext2/ext3 mode : No
 Expert mode : No
 Low memory : No
> fdisk -lu /dev/sdb
Disk /dev/sdb: 2000.3 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors
   Device Boot      Start         End      Blocks   Id  System
/dev/sdb1              63  3907024064  1953512001   83  Linux
> parted /dev/sdb
GNU Parted 1.8.1
Using /dev/sdb
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) p
Model: ATA WDC WD2003FYYS-0 (scsi)
Disk /dev/sdb: 2000GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Number  Start   End     Size    Type     File system  Flags
 1      32.3kB  2000GB  2000GB  primary
Any suggestions for fixing this issue would be greatly appreciated.
