Ran the analyze feature and 3 partitions showed up. The info looked accurate (I'm working on someone else's drive) Had the Dell part, Recovery, and System partitions all in RAW fs. I changed the Dell to DE per instructions then ran the deep scan. The scan came back with nothing at all. I ran analyze again and I have a tiny partition and nothing else.
Did I miss something? Am I hosed and the drive is now toast? Any help would be greatly appreciated.
They were there, then they weren't
Re: They were there, then they weren't
If you do not write the new partition table, changing the partition type is useless.
Can you post the testdisk.log file content ?
Re: They were there, then they weren't continued
Thanks for the reply Christophe, If I knew where it was I could. I'm running off the TRK USB stick. The last thing I saw was "log file corrupt". It's not looking good is it?
When it showed the partitions I did write down the CHS values for all three listed. I guess I should have stopped while I was ahead. Don't want to make any moves to avoid any further loss or damage.
If you can't provide the log file, try to post screenshots...
Christophe, I was able to finally get a log file. Also have the backup file. Does getting the I/O error indicate a head or control board issue or am I just missing something still? Thanks for your input and the work you have put into this project.
Backup:
#1479660884 Disk /dev/sdd - 500 GB / 465 GiB - CHS 60801 255 63
1 : start= 63, size= 80262, Id=DE, P
2 : start= 81920, size= 30720000, Id=07, P
3 : start= 30801920, size=945969200, Id=07, *
I also have the start and end points written down from one of the screens I got early on. If that is needed I can put it together on here.
TestDisk:Mon Nov 21 19:56:07 2016
OS: Windows XP SP2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=80000000000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=80000000000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=74932300800
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=15728640000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=484336230400
Disk /dev/sda - 80 GB / 74 GiB - CHS 9726 255 63, sector size=512 - Maxtor 6Y080M0, S/N:325934313258434d202020202020202020202020, FW:YAR51HW0
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500620AS, FW:DE13
Disk /dev/sdb - 500 GB / 465 GiB - ST3500620AS
Partition: Read error
file_pread(5,16,buffer,32(0/0/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,48(0/0/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,95(0/1/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,111(0/1/49)) ReadFile The request could not be performed because of an I/O device error.
* Truncated to keep post small
Backup:
OS: Windows XP SP2
The disk is correctly identified but all read operations failed, it's probably a damaged head. You will have to contact a data recovery company.
