Filesystem Seems Damaged
jp1809
#1 Post by jp1809 »
When I select what I believe to be the correct partition *HTFS - NTFS and try to list the files. I get a message Can't open filesystem. Filesystem seems damaged. Not sure where to go from here. I know my files are on the drive as EaseUS file recovery shows them. I would buy the software but can't afford it and I need to learn how to use testdisk.
