ESD-USB
harshcat
ESD-USB
#1 Post by harshcat »
HI, i made a big booboo and i'm really hoping i can reverse or at least get the files off my external harddrive
My old harddrive was failing and i didn't have a usb stick so i decided to used external harddrive, didn't think that it would now converte the external harddrive to this ESD-USB where my content is gone. It shows as 32 gig while normally its a 600 gig external or so. I'm hoping that my file is still on the external i just don't know where to start and how. Please any help would be appreciated. I can reformat i just wanna get my stuff off the external. I'm trying to use testdrive and i don't what the first step is. I guess i can submit any log or picture if needed. THank you
Re: ESD-USB
Some drivers may be missing to handle disk of big capacity...
Check if you can update the system on your key.
It's also possible to install a Linux LiveUSB on another key, see https://www.cgsecurity.org/testdisk.pdf
There is an example using Fedora, there will be no problem to handle big disk, NTFS, exFAT...
harshcat
Re: ESD-USB
#3 Post by harshcat »
Its not the driver since it recongized what it use to be i guess the mypassport i'm just trying to use testdrive to backup the external harddrive and i'm just wanting to know if its still possible or should i just move on knowing my external HD is ruined
Again it use to be around 600 gig but i'm getting only 32
