Hello
I am trying to recover my external hard drive on a windows 10 computer. With the quick search I recovered 25 gb of 100, in a 1TB drive. Then, I started a deep search. So far, it has been working for one day and just finished 20%. since it is an external portable hard drive I am a bit concern about a so long period of time working continuously. Two questions: is it safe for the disk to continue working four more days? If I put the computer to sleep, can it damage the disk? (some posts suggest it is ok, but some others indicated an error happened because the computer went to sleep)
Thanks for your help
Carlos Alberto
Newbie question: is safe to sleep?
Re: Newbie question: is safe to sleep?
When recovering data from a disk with bad sectors, I had to run ddrescue for more than 2 weeks without interruption.
I didn't had problem.
There should be no problem putting the computer to sleep.
Thanks!
The program run smoothly.
Now, I got this issue: I found the main partition with data (the FAT32 LBA, the NTFS does not have any valid file):
HPFS - NTFS 0 32 33 121601 25 24 1953519616
NTFS found using backup sector, blocksize=4096, 1000 GB / 931 GiB
FAT32 LBA 0 32 33 121601 25 24 1953519616 [NO NAME]
But as you can see, there is nothing in the first part of the disk (CHS 0 1 1 to 0 32 32): how can I fix it? Should I add a new partition? if so, where can I find documentation or guidelines to do it? My guess is that the missing partition should be 0 1 1 to 0 32 34.
Also, is there a missing partition at the end? (the end sector is at x 25 24, but the beginning is at 32 33, which suggested me that there could be at least 32 heads per cylinder and 33 sectors per head)
Thanks again for your help
Carlos Alberto
Carlos Alberto
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=999390445568
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000202043392
Drive C: - 999 GB / 930 GiB - CHS 121502 255 63, sector size=512
Drive E: - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Disk /dev/sdb - 1000 GB / 931 GiB
Partition table type: Mac
Bad MAC partition, invalid block0 signature
read_part_mac: bad DPME signature
test_FAT()
1 P FAT32 LBA 0 32 33 121601 25 24 1953519616
sector_size 65295
cluster_size 255
reserved 4095
fats 255
dir_entries 65535
sectors 1551
media 00
fat_length 0
secs_track 7
heads 0
hidden 8
total_sect 9
test_FAT()
sector_size 65295
cluster_size 255
reserved 4095
fats 255
dir_entries 65535
sectors 1551
media 00
fat_length 0
secs_track 7
heads 0
hidden 8
total_sect 9
Invalid FAT boot sector
file_pread(5,14,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(5,3,buffer,1953525775(121601/90/41)) lseek err Invalid argument
file_pread(5,3,buffer,1953525822(121601/91/25)) lseek err Invalid argument
file_pread(5,8,buffer,1953525838(121601/91/41)) lseek err Invalid argument
file_pread(5,11,buffer,1953525885(121601/92/25)) lseek err Invalid argument
file_pread(5,2,buffer,1953527807(121601/122/57)) lseek err Invalid argument
$MFT has invalid magic.
ntfs_mft_load(): Failed.
FAT32 at 0/32/39
FAT1 : 32-238440
FAT2 : 238441-476849
start_rootdir : 476850 root cluster : 2
Data : 476850-1953519601
sectors : 1953519616
cluster_size : 64
no_of_cluster : 30516293 (2 - 30516294)
fat_length 238409 calculated 238409
FAT32 at 0/32/39
FAT32, blocksize=32768, 1000 GB / 931 GiB
NTFS at 121601/25/24
filesystem size 1953519616
mftmirr_lcn 2
file_pread(5,8,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(5,8,buffer,1953525376(121601/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,1953525504(121601/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,1953525632(121601/88/24)) lseek err Invalid argument
Not an exFAT boot sector.
dir_partition inode=0
FAT: cluster=2(0x2), pos=478898
FAT: cluster=2105376(0x202020), pos=135222834
1 P FAT32 LBA 0 32 33 121601 25 24 1953519616 [NO NAME]
Don't worry about partition alignement. If you can see your files, use the arrow keys to switch the partition to P(rimary).
On next screen, choose Write, confirm, Quit
Thanks!
will give it a try
will give it a try
Hello
I followed the steps and selected write. The two FAT sections are now equal... but I'm still unable to mount the drive in a mac or see it in windows.
why can be that?
also, if i run now photorec, will photorec recognize the files I can see using testDisk as existent or deleted files?
Carlos Alberto
why can be that?
Carlos Alberto
