Recovering a lost Mac partition
camomoab
#1 Post by camomoab »
Hi I just downloaded Test Disk because I can't boot into mac os. When I went to disk utility in windows, It said the partition was unallocated space. I did not format or delete any of the partitions but just randomly disappeared. In the mac installer, disk utility also could not detect the disk. After looking for ways to recovering lost partitions I ended up here and I am currently running test disk to analyze the mac drive. Could you guys give me advice on how to solve this problem because this is the first time I have used test disk.
Re: Recovering a lost Mac partition
Read https://www.cgsecurity.org/testdisk.pdf
If you want specific help, please post the testdisk.log file content.
camomoab
#3 Post by camomoab »
Hi, thank you for the fast reply. I checked out the testdisk pdf and it was helpful. However, when I ran the analysis of the disk, It detected the problem but said that the "write" method was not supported for mac drives. Here is the log
Mon Jan 16 23:19:00 2017
Compiler: GCC 4.9, MinGW 3.11
ext2fs lib: none, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20120504, curses lib: pdcurses build  3401
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=164696555520
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=126035288064
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2020872192
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=8004304896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=126032543744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=76823337472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=437085274112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=5074965504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=2020872192
Disk \\.\PhysicalDrive0 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 164 GB / 153 GiB - CHS 20023 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 126 GB / 117 GiB - CHS 15322 255 63, sector size=512
Disk \\.\PhysicalDrive3 - 2020 MB / 1927 MiB - CHS 245 255 63, sector size=512
Disk \\.\PhysicalDrive4 - 8004 MB / 7633 MiB - CHS 973 255 63, sector size=512
Drive C: - 126 GB / 117 GiB - CHS 15322 255 63, sector size=512
Drive D: - 76 GB / 71 GiB - CHS 9339 255 63, sector size=512
Drive E: - 437 GB / 407 GiB - CHS 53139 255 63, sector size=512
Drive G: - 5074 MB / 4839 MiB - CHS 616 255 63, sector size=512
Partition table type: Mac
Analyse Disk \\.\PhysicalDrive1 - 164 GB / 153 GiB - CHS 20023 255 63
Bad MAC partition, invalid block0 signature
read_part_mac: bad DPME signature
NTFS at 616/254/63
filesystem size           9912042
sectors_per_cluster       8
mft_lcn                   262144
mftmirr_lcn               2
clusters_per_mft_record   -10
     Unknown                  9912104   19824145    9912042
     NTFS, blocksize=4096, 5074 MB / 4839 MiB
Partition not added.
HFS+ magic value at 9957/29/57
part_size 38813696
     HFS                    159961088  198774783   38813696
     HFS+ blocksize=4096 + Backup, 19 GB / 18 GiB
HFS+ magic value at 12373/40/20
part_size 122894336
     HFS                    198774784  321669119  122894336
     HFS+ blocksize=4096 + Backup, 62 GB / 58 GiB
file_win32_pread(96,3,buffer,321672958(20023/54/62)) read err: read after end of file
file_win32_pread(96,8,buffer,321672959(20023/54/63)) read err: read after end of file
   P HFS                    159961088  198774783   38813696
   P HFS                    198774784  321669119  122894336
Function write_part_mac not implemented
"HFS+ blocksize=4096 + Backup, 62 GB / 58 GiB" is the partition that was lost. I cannot access it in any way and windows recognizes it as unallocated space. A normal hfs partition appears as "Healthy" with no disk format listed. In my screenshot attached,
The 18gb partition is a normally working mac drive and the one saying "unallocated space" is the lost one. I hope you can tell me the solution for repairing the drive.
Thanks Camomoab
camomoab
#4 Post by camomoab »
By the way in case this would help, I have a mac installer flash drive.
camomoab
#5 Post by camomoab »
Solved THANK YOU SO MUCH cgrenier!!! I made a mistake in which file system I chose. Instead of mac file system, I chose EFI GUID which was actually correct and was able to use the write function to fix the disk. Although it still appears unallocated in disk manager, I can now boot into macos and access my files. Is there anything I should do to prevent this problem from occuring again?
MrAnssaien
#6 Post by MrAnssaien »
camomoab wrote: 18 Jan 2017, 22:32 Solved THANK YOU SO MUCH cgrenier!!! I made a mistake in which file system I chose. Instead of mac file system, I chose EFI GUID which was actually correct and was able to use the write function to fix the disk. Although it still appears unallocated in disk manager, I can now boot into macos and access my files. Is there anything I should do to prevent this problem from occuring again?
If you want to avoid this problem, don't install a new OS in a new partition on the same drive -- especially a Linux-based OS. I had Win10 and OS Mojave on the same SSD both working flawlessly, and when I created a new partition for Kali Linux, it must've messed with the APFS container when it created the SWAP partition -- maybe Kali even changed the block size or something. A few minutes ago, I could still access Win10 and Kali, but the macOS partition became "unknown". I ruined the whole partition table when I tried to recover macOS using TestDisk. Now, nothing works, so I'm trying a deep search, and hopefully, it'll allow me to recover macOS and win10, while removing the Kali Linux partition, so I'll just stick to using the USB live version for now. It was challenging enough to have Mojave and Win10 on the same SSD. Didn't see it coming. All this crap happened because I couldn't afford a new SSD. Dx
