large video file recovered into 3 seperate identical clip sizes
clinteastwood11
#1 Post by clinteastwood11 »
hi guys
i just recovered a big video file with photorec, its a mov. however it seems to have broken it into three .mov's of all the exact same size 3.98GB and doesn't play. I'm pretty sure it is the same file. how to I either get these together to play as one or run the scan again and get photorec to recognise this is all the same file. thaks in advance
Re: large video file recovered into 3 seperate identical clip sizes
Do not store the recovered files on FAT filesystem. Do you have the same problem if you use NTFS or exFAT instead ?
Do you recover the video from a digital camera memory card or from a harddisk ?
If it's from a digital camera, which brand and model ?
Do you have an approximate idea of the original filesize ?
clinteastwood11
#3 Post by clinteastwood11 »
thanks for the reply. the files are coming from an external hard drive that they were deleted from. orignal file size I'm not too sure about but i think it was about 12gb. I am recovereing them to an NTFS hard drive. thanks again for coming back to me on this
