RAID5 EXT4 4 Disk Recovery
mikenai
#1 Post by mikenai »
My Synology NAS RAID5 x04 disk EXT4, had x02 disk dropped out of the array. After troubleshooting, I found that 2 of the synology hdd slots were faulty.
I followed the guide initially but did not manage to assemble the array. Error message is logged below.
https://www.synology.com/en-us/knowledg ... using_a_PC
root@ubuntu:~# mdadm -Asf && vgchange -ay
mdadm: /dev/md/2 assembled from 2 drives - not enough to start the array.
root@ubuntu:~# mdadm --examine /dev/sd*3
/dev/sda3:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Array UUID : b8899307:d41db469:d2da917c:5943634c
  Creation Time : Sat Aug  2 16:54:55 2014
     Raid Level : raid5
   Raid Devices : 4
 Avail Dev Size : 5851088833 (2790.02 GiB 2995.76 GB)
     Array Size : 8776632768 (8370.05 GiB 8987.27 GB)
  Used Dev Size : 5851088512 (2790.02 GiB 2995.76 GB)
    Data Offset : 2048 sectors
   Super Offset : 8 sectors
   Unused Space : before=1968 sectors, after=321 sectors
          State : clean
    Device UUID : 7cf404e5:3078928a:e14811c9:4bc24508
    Update Time : Sat Jan 28 03:33:36 2017
       Checksum : a3c71a8c - correct
         Events : 67
         Layout : left-symmetric
     Chunk Size : 64K
   Device Role : Active device 1
   Array State : .A.. ('A' == active, '.' == missing, 'R' == replacing)
/dev/sdb3:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Raid Level : raid5
   Raid Devices : 4
          State : clean
    Device UUID : 989e8320:0da2d57f:34b382dd:6c026501
    Update Time : Sat Jan 28 03:29:01 2017
       Checksum : e21597e7 - correct
         Events : 63
     Chunk Size : 64K
   Device Role : Active device 2
   Array State : ..A. ('A' == active, '.' == missing, 'R' == replacing)
/dev/sdc3:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Raid Level : raid5
   Raid Devices : 4
          State : clean
    Device UUID : 1f55310d:d707240b:2e18c5c7:98535992
    Update Time : Sat Jan 28 03:00:58 2017
       Checksum : d54b63ca - correct
         Events : 67
     Chunk Size : 64K
   Device Role : Active device 0
   Array State : AA.. ('A' == active, '.' == missing, 'R' == replacing)
/dev/sdd3:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Raid Level : raid5
   Raid Devices : 4
          State : clean
    Device UUID : fad32fc1:73cc6310:c075ef4f:71fab83a
    Update Time : Sat Jan 28 02:36:18 2017
       Checksum : bf15a5e5 - correct
         Events : 65
     Chunk Size : 64K
   Device Role : Active device 3
   Array State : A..A ('A' == active, '.' == missing, 'R' == replacing)
root@ubuntu:~# lsblk
NAME   MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
sda      8:0    0  2.7T  0 disk
├─sda1   8:1    0  2.4G  0 part
├─sda2   8:2    0    2G  0 part [SWAP]
└─sda3   8:3    0  2.7T  0 part
sdb      8:16   0  2.7T  0 disk
├─sdb1   8:17   0  2.4G  0 part
├─sdb2   8:18   0    2G  0 part [SWAP]
└─sdb3   8:19   0  2.7T  0 part
sdc      8:32   0  2.7T  0 disk
├─sdc1   8:33   0  2.4G  0 part
├─sdc2   8:34   0    2G  0 part [SWAP]
└─sdc3   8:35   0  2.7T  0 part
sdd      8:48   0  2.7T  0 disk
├─sdd1   8:49   0  2.4G  0 part
├─sdd2   8:50   0    2G  0 part [SWAP]
└─sdd3   8:51   0  2.7T  0 part
sde      8:64   1 14.3G  0 disk
└─sde1   8:65   1 14.3G  0 part /cdrom
loop0    7:0    0  1.4G  1 loop /rofs
After some assistance from Synology Support, we were able to build the array. But we were not able to mount nor see the filesystem of the array.
root@ubuntu:~# mdadm -C /dev/md2 -l5 -n4 -e1.2 -u b8899307:d41db469:d2da917c:5943634c --assume-clean /dev/sdf3 /dev/sdd3 /dev/sdb3 /dev/sda3
mdadm: /dev/sdf3 appears to be part of a raid array:
       level=raid5 devices=4 ctime=Fri Feb  3 15:47:33 2017
mdadm: /dev/sdd3 appears to be part of a raid array:
mdadm: /dev/sdb3 appears to be part of a raid array:
mdadm: /dev/sda3 appears to be part of a raid array:
Continue creating array? yes
mdadm: array /dev/md2 started.
root@ubuntu:~# vgchange -ay
root@ubuntu:~# mdadm -S /dev/md2
mdadm: stopped /dev/md2
The support is unable to continue, as they are not comfortable with Ubuntu platform, compared to installing in synology nas platform.
Then after i tried to see what information i can extract more.
Ubuntu is able to auto assemble the array /dev/md2 but does not seem to be able to mount the volume.
But I am not sure why there is no superblock information.
Furthermore the chunk size has changed to 512k instead.
root@NAS:~# cat /proc/mdstat
Personalities : [raid6] [raid5] [raid4] [linear] [multipath] [raid0] [raid1] [raid10]
md2 : active raid5 sda3[2] sdb3[1] sdc3[3] sdd3[0]
      8776241664 blocks super 1.2 level 5, 512k chunk, algorithm 2 [4/4] [UUUU]
      bitmap: 0/22 pages [0KB], 65536KB chunk
unused devices: <none>
root@NAS:~# mdadm -E /dev/md2
mdadm: No md superblock detected on /dev/md2.
root@NAS:~# mdadm --detail /dev/md2
/dev/md2:
        Version : 1.2
  Creation Time : Fri Feb  3 17:50:44 2017
     Raid Level : raid5
     Array Size : 8776241664 (8369.68 GiB 8986.87 GB)
  Used Dev Size : 2925413888 (2789.89 GiB 2995.62 GB)
   Raid Devices : 4
  Total Devices : 4
    Persistence : Superblock is persistent
  Intent Bitmap : Internal
    Update Time : Fri Feb  3 17:50:44 2017
          State : clean
 Active Devices : 4
Working Devices : 4
 Failed Devices : 0
  Spare Devices : 0
     Chunk Size : 512K
         Events : 0
    Number   Major   Minor   RaidDevice State
       0       8       51        0      active sync   /dev/sdd3
       1       8       19        1      active sync   /dev/sdb3
       2       8        3        2      active sync   /dev/sda3
       3       8       35        3      active sync   /dev/sdc3
root@NAS:~# mdadm -E /dev/sd*3
/dev/sda3:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x1
     Raid Level : raid5
   Raid Devices : 4
 Avail Dev Size : 5850828737 (2789.89 GiB 2995.62 GB)
  Used Dev Size : 5850827776 (2789.89 GiB 2995.62 GB)
    Data Offset : 262144 sectors
   Unused Space : before=262056 sectors, after=961 sectors
          State : clean
    Device UUID : c99621f4:e29a38c6:579966bc:e32b5fe3
Internal Bitmap : 8 sectors from superblock
  Bad Block Log : 512 entries available at offset 72 sectors
       Checksum : 48e9a91c - correct
         Events : 0
     Chunk Size : 512K
   Array State : AAAA ('A' == active, '.' == missing, 'R' == replacing)
/dev/sdb3:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x1
     Raid Level : raid5
   Raid Devices : 4
          State : clean
    Device UUID : 67de2afa:4132b674:b01121d9:a4a2f65e
       Checksum : 95c27731 - correct
         Events : 0
     Chunk Size : 512K
/dev/sdc3:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x1
     Raid Level : raid5
   Raid Devices : 4
          State : clean
    Device UUID : 82523814:d76384ec:3f86b3b1:7c024714
       Checksum : b580f14a - correct
         Events : 0
     Chunk Size : 512K
/dev/sdd3:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x1
     Raid Level : raid5
   Raid Devices : 4
          State : clean
    Device UUID : 6da1893d:e5a63446:41cac1cd:db84d155
       Checksum : 961b49a1 - correct
         Events : 0
     Chunk Size : 512K
I have also run testdisk to see if any partition can be recovered. But looks like a lot of errors. Not sure if it is due to wrong order of array or something else?
Wed Feb  8 19:04:15 2017
OS: Linux, kernel 4.4.0-62-generic (#83-Ubuntu SMP Wed Jan 18 14:10:15 UTC 2017) x86_64
Compiler: GCC 4.4
Compilation date: 2015-04-18T13:05:16
ext2fs lib: 1.42.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504, curses lib: ncurses 5.7
/dev/sda: size       5860533168 sectors
/dev/sda: user_max   5860533168 sectors
/dev/sda: native_max 5860533168 sectors
/dev/sdb: size       5860533168 sectors
/dev/sdb: user_max   5860533168 sectors
/dev/sdb: native_max 5860533168 sectors
/dev/sdc: LBA, HPA, LBA48, DCO support
/dev/sdc: size       5860533168 sectors
/dev/sdc: user_max   5860533168 sectors
/dev/sdc: native_max 5860533168 sectors
/dev/sdd: LBA, HPA, LBA48, DCO support
/dev/sdd: size       5860533168 sectors
/dev/sdd: user_max   5860533168 sectors
/dev/sdd: native_max 5860533168 sectors
Warning: can't get size for Disk /dev/md - 0 B - 0 sectors (RO), sector size=512
Disk /dev/sda - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30EFRX-68AX9N0, S/N:WD-WCC1T0549413, FW:80.00A80
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30EFRX-68AX9N0, S/N:WD-WCC1T0528534, FW:80.00A80
Disk /dev/sdc - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30EFRX-68EUZN0, S/N:WD-WCC4N0811191, FW:80.00A80
Disk /dev/sdd - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30EFRX-68EUZN0, S/N:WD-WCC4N0822317, FW:80.00A80
Disk /dev/sde - 15 GB / 14 GiB - CHS 14663 64 32, sector size=512 - SanDisk Ultra, FW:1.00
Disk /dev/md2 - 8986 GB / 8369 GiB - CHS 2194060416 2 4, sector size=512
Partition table type: EFI GPT
Analyse Disk /dev/md2 - 8986 GB / 8369 GiB - CHS 2194060416 2 4
Trying alternate GPT
block_group_nr 3
recover_EXT2: part_offset problem
block_group_nr 5
block_group_nr 5
block_group_nr 5
block_group_nr 7
block_group_nr 7
block_group_nr 7
block_group_nr 7
block_group_nr 9
block_group_nr 9
block_group_nr 9
block_group_nr 9
block_group_nr 25
block_group_nr 25
block_group_nr 25
block_group_nr 25
block_group_nr 27
block_group_nr 27
block_group_nr 27
block_group_nr 27
block_group_nr 49
block_group_nr 49
block_group_nr 49
block_group_nr 49
block_group_nr 81
block_group_nr 81
block_group_nr 81
block_group_nr 81
block_group_nr 125
block_group_nr 125
block_group_nr 125
block_group_nr 125
block_group_nr 243
block_group_nr 243
block_group_nr 243
block_group_nr 243
block_group_nr 343
block_group_nr 343
block_group_nr 343
block_group_nr 343
block_group_nr 625
block_group_nr 625
block_group_nr 625
block_group_nr 625
block_group_nr 729
block_group_nr 729
block_group_nr 729
block_group_nr 729
block_group_nr 2187
block_group_nr 2187
block_group_nr 2187
block_group_nr 2187
block_group_nr 2401
block_group_nr 2401
block_group_nr 2401
block_group_nr 2401
block_group_nr 2401
block_group_nr 2401
block_group_nr 2401
block_group_nr 2401
block_group_nr 2401
block_group_nr 2401
block_group_nr 2401
block_group_nr 2401
block_group_nr 3125
block_group_nr 3125
block_group_nr 3125
block_group_nr 3125
block_group_nr 6561
block_group_nr 6561
block_group_nr 6561
block_group_nr 6561
block_group_nr 6561
block_group_nr 6561
block_group_nr 6561
block_group_nr 6561
block_group_nr 6561
block_group_nr 6561
block_group_nr 6561
block_group_nr 6561
LVM magic value at 224379272/0/1
LVM magic value at 224387739/0/1
LVM magic value at 335940760/1/3
     MS Data               3922719958 4629022203  706302246
     FATX, 361 GB / 336 GiB
block_group_nr 19683
SYSV4 Marker at 757575011/0/4
recover_sysv4
     MS Data               6060600091 30118946532122 30112885932032 [žžðÙÑD]
     SysV4, 15417 TB / 14022 TiB
This partition ends after the disk limits. (start=6060600091, size=30112885932032, end=30118946532122, disk end=17552483328)
SYSV4 Marker at 814007470/1/1
recover_sysv4
     Unknown               6512059764 6113002420315507 6112995908255744 [.Êþ2ÐÇ]
     SysV4, 3129853 TB / 2846585 TiB
Partition not added.
cramfs Marker at 839163897/0/4
recover_cramfs
     MS Data               6713311179 6721336247    8025068 [ý^:òC×z¤è80îÀ]
     cramfs, 4108 MB / 3918 MiB
SYSV4 Marker at 848854566/1/1
recover_sysv4
     Unknown               6790836532 25501569259 18710732728 [ ¹ð¨ßw]
     SysV4, 9579 GB / 8921 GiB
     Unknown               7140932470 8686052393 1545119924
     FATX, 791 GB / 736 GiB
LVM magic value at 912302832/0/2
SYSV4 Marker at 1033821955/1/2
recover_sysv4
     Unknown               8270575645 8270575644          0 [Ž’ð-]
     SysV4, 0 B
     Unknown               8351551539 5005260159094834 5005251807543296
     WBFS, 2562688 TB / 2330752 TiB
recover_EXT2: s_block_group_nr=0/22340, s_mnt_count=20/38, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 732043776
recover_EXT2: part_size 5856350208
     MS Data               8761242728 14617592935 5856350208
     ext3 blocksize=4096 Large_file Sparse_SB Recover, 2998 GB / 2792 GiB
recover_EXT2: "e2fsck -b 644972544 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=19683/22340, s_mnt_count=0/38, s_blocks_per_group=32768, s_inodes_per_group=8192
     MS Data               10296730622 16153080829 5856350208
     ext3 blocksize=4096 Large_file Sparse_SB Backup_SB, 2998 GB / 2792 GiB
     Unknown               17132501598 17838803843  706302246
The harddisk (8986 GB / 8369 GiB) seems too small! (< 15420 TB / 14025 TiB)
Not sure what to do now, i have also tried using windows software Reclaime
But funny thing is that the disk order shown here is different from what the original information i saw from the first recovery effort.
Order from Synology Support Logs (Disk 2,0,1,3)
Order from Reclaime Log (Disk 0,1,2,3)
Hence now, I need advise and help on how I should proceed on further.
This is a plain-text general description of the reconstructed array layout.
The array type is RAID5.
The array consists of 4 disks.
The disks are ordered as follows:
#00: Disk 0 - WDC WD30EFRX-68AX9N0, Serial number WCC1T0549413, \\.\PhysicalDrive0
#01: Disk 1 - WDC WD30EFRX-68AX9N0, Serial number WCC1T0528534, \\.\PhysicalDrive1
#02: Disk 2 - WDC WD30EFRX-68EUZN0, Serial number WCC4N0811191, \\.\PhysicalDrive2
#03: Disk 3 - WDC WD30EFRX-68EUZN0, Serial number WCC4N0822317, \\.\PhysicalDrive3
Block size is 64.0 KB , same as 128 sectors.
The data starts at sector (LBA) 0 (this is often called "offset" or "start offset").
Block map is as follows:
    1    2    3    P
    5    6    P    4
    9    P    7    8
    P  10  11  12
Re: RAID5 EXT4 4 Disk Recovery
Run TestDisk, select /dev/md2, choose None for the partition table type, Advanced, Type, set it to ext4, Superblock.
If it works, you should be able to use the returned values to run fsck.ext4 and repair this filesystem.
mikenai
#3 Post by mikenai »
Hi cgrenier,
I have placed the output below, doesnot seem like it located any superblock information.
>   P ext4                     0   0  1 2194060415   1  4 17552483328
Would you suggest that i manual assemble myself the disk array with what Windows Reclaime Software suggested?
madam --create /dev/md0 --assume-clean --chunk=64 -e1.2 --level=5 --verbose --raid-devices=4 /dev/sda3 /dev/sdb3 /dev/sdc3 /dev/sdd3
mdadm --detail --scan
mikenai
#4 Post by mikenai »
Update
I have reassembled with the suggested order by reclaime software in ubuntu.
But the results is still the same from testdisk. No superblock info.
Any suggestion on how i should proceed?
mikenai
#5 Post by mikenai »
I have created the array with the following command.
This is based on the order recommended by Reclaime (Windows Software)
Then i ran disk analysis again using ubuntu - testdisk
Disk /dev/md0 - 8986 GB / 8369 GiB - CHS 2194060752 2 4
The harddisk (8986 GB / 8369 GiB) seems too small! (< 9133 GB / 8506 GiB)
>  Sys=0C               2141562827   1  3 2229850608   0  4  706302246
[ Continue ]
After pressing next, i was presented with 4 partitions.
I tried changing to ext4 but was not successful in previewing any files.
It mentioned about no valid filesystem.
 P Sys=0C               462411188   0  1 682631021   0  2 1761758666
 P Sys=0C               750464539   0  1 970684372   0  2 1761758666
 P ext3                 1095155357   0  1 1827199132   1  4 5856350208
>P ext3                 1287091199   1  3 2019134975   1  2 5856350208
Structure: Ok.
Keys T: change type, P: list files,
     Enter: to continue
testdisk log output as follows
Fri Feb 10 17:30:00 2017
Compiler: GCC 4.4
Warning: can't get size for Disk /dev/md2 - 0 B - CHS 1 2 4, sector size=512
Disk /dev/sdf - 6979 KB / 6816 KiB - CHS 973 1 14 (RO), sector size=512 - Linux File-Stor Gadget, FW:0000
Disk /dev/md0 - 8986 GB / 8369 GiB - CHS 2194060752 2 4, sector size=512
Partition table type: None
   P Unknown                  0   0  1 2194060751   1  4 17552486016
Change partition type:
   P ext4                     0   0  1 2194060751   1  4 17552486016
search_superblock
Analyse Disk /dev/md0 - 8986 GB / 8369 GiB - CHS 2194060752 2 4
block_group_nr 3
block_group_nr 5
block_group_nr 5
block_group_nr 5
block_group_nr 7
block_group_nr 7
block_group_nr 7
block_group_nr 7
block_group_nr 9
block_group_nr 9
block_group_nr 9
block_group_nr 9
block_group_nr 25
block_group_nr 25
block_group_nr 25
block_group_nr 25
block_group_nr 27
block_group_nr 27
block_group_nr 27
block_group_nr 27
block_group_nr 49
block_group_nr 49
block_group_nr 49
block_group_nr 49
block_group_nr 81
block_group_nr 81
block_group_nr 81
block_group_nr 81
block_group_nr 125
block_group_nr 125
block_group_nr 125
block_group_nr 125
block_group_nr 243
block_group_nr 243
block_group_nr 243
block_group_nr 243
block_group_nr 343
block_group_nr 343
block_group_nr 343
block_group_nr 343
block_group_nr 625
block_group_nr 625
block_group_nr 625
block_group_nr 625
block_group_nr 729
block_group_nr 729
block_group_nr 729
block_group_nr 729
LVM magic value at 60068995/0/2
block_group_nr 2187
block_group_nr 2187
block_group_nr 2187
block_group_nr 2187
block_group_nr 2401
block_group_nr 2401
block_group_nr 2401
block_group_nr 2401
block_group_nr 2401
block_group_nr 2401
block_group_nr 2401
block_group_nr 2401
SYSV4 Marker at 98942029/1/2
recover_sysv4
     SysV 4               98942029   1  2 98942029   1  1          0 [Ž’ð-]
     SysV4, 0 B
block_group_nr 3125
block_group_nr 3125
block_group_nr 3125
block_group_nr 3125
block_group_nr 6561
block_group_nr 6561
block_group_nr 6561
block_group_nr 6561
block_group_nr 6561
block_group_nr 6561
block_group_nr 6561
block_group_nr 6561
LVM magic value at 224379304/0/1
LVM magic value at 224387803/0/1
LVM magic value at 335940568/1/3
LVM magic value at 351104282/1/4
     FATX, 902 GB / 840 GiB
SYSV4 Marker at 1033821699/1/2
recover_sysv4
     SysV 4               1033821699   1  2 1033821699   1  1          0 [Ž’ð-]
     SysV4, 0 B
recover_EXT2: s_block_group_nr=19683/22340, s_mnt_count=0/30, s_blocks_per_group=32768, s_inodes_per_group=8192
This partition ends after the disk limits. (start=17132502622, size=706302246, end=17838804867, disk end=17552486016)
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 1761758666 linear /dev/md0 3699289504" | dmsetup create test0
echo "0 1761758666 linear /dev/md0 6003716312" | dmsetup create test1
echo "0 5856350208 linear /dev/md0 8761242856" | dmsetup create test2
echo "0 5856350208 linear /dev/md0 10296729598" | dmsetup create test3
dir_partition inode=2
ext2fs_dir_iterate failed with error 1.
   P ext4                 1287091199   1  3 2019134975   1  2 5856350208
   P ext4                 462411188   0  1 682631021   0  2 1761758666
   P SysV 4               462411188   0  1 682631021   0  2 1761758666
   P Linux md 1.x RAID    462411188   0  1 682631021   0  2 1761758666
   P ext3                 462411188   0  1 682631021   0  2 1761758666
   P FAT32                462411188   0  1 682631021   0  2 1761758666
dir_partition inode=0
FAT: cluster=2865337202(0xaac99372), pos=494046944
FAT: Can't read directory cluster.
   P Linux LVM            462411188   0  1 682631021   0  2 1761758666
   P Linux md 1.x RAID    750464539   0  1 970684372   0  2 1761758666
   P Linux md 1.x RAID    1095155357   0  1 1827199132   1  4 5856350208
   P Linux md 1.x RAID    1287091199   1  3 2019134975   1  2 5856350208
Write isn't available because the partition table type "None" has been selected.
   P Linux md 1.x RAID        0   0  1 2194060751   1  4 17552486016
search_superblock
block_group_nr 3
block_group_nr 5
block_group_nr 5
block_group_nr 5
block_group_nr 7
block_group_nr 7
block_group_nr 7
block_group_nr 7
