No partitions found - need to recreate partition table
morgana
#1 Post by morgana »
Hi All,
I accidentally deleted the boot partition and now in boot error state.
I have used testdisk to find the partition but somehow it only shows my USB drive:
Disk /dev/sda - 7761 MB / 7401 MiB - CHS 1022 239 62
>  EFI System                    40     409639     409600 [EFI]
   EFI System                    46     409645     409600 [EFI]
   MS Data                    38294      44291       5998 [GParted-EFI]
   MS Data                   411648   15157247   14745600 [CHELLA]
   MS Data                   411654   15157253   14745600 [CHELLA]
   MS Data                   445320     452701       7382 [OCS-EFI]
   MS Data                  8056982    8059861       2880 [EFISECTOR]
   MS Data                  8059862    8062741       2880 [EFISECTOR]
   MS Data                 10329194   10335191       5998 [GParted-EFI]
   MS Data                 10888310   10894307       5998 [GParted-EFI]
                P=Primary  D=Deleted
     Enter: to continue
root@partedmagic:~# ^C209 MB / 200 MiB
root@partedmagic:~#
Also in Gparted it only shows my USB i think because the size is only 7,23 GiB (unallocated).
http://imgur.com/00CNwNg
I think i need to recreate partition table to restore master boot but how do i go about fixin that?
This is the output of fdisk:
root@partedmagic:~# fdisk -l
Disk /dev/sda: 7761 MB, 7761035264 bytes, 15158272 sectors
Disk label type: dos
Disk identifier: 0x00000000
   Device Boot      Start         End      Blocks   Id  System
root@partedmagic:~#
Any ideas how te recreate the partition table or maybe i'm using different testdisk settings?
Re: No partitions found - need to recreate partition table
If /dev/sda is your USB key and not your HD, I have no solution until your physical disk is listed.
