Hello guys and girls!
I 've accidentally deleted some initial portion (little I think) of my drive through the following command: openssl enc -aes-256-ctr -pass pass:"$(dd if=/dev/urandom bs=128 count=1 2>/dev/null | base64)" -nosalt < /dev/zero > /dev/sda
The following partitions existed prior to my fault:
sda1/2 (Windows) - about 100GB
sda3 (Extended) - about 100GB
sda4 Veracrypt - about 700GB
some Unallocated space
With the above command I wanted to fill with noise the sda3 partition, but due to a mistake while typing the number 3, didn't reach the command, so as soon as I noticed it (pretty quickly) I hit CTRL+C (about 1 sec after the initial ENTER).
What I 've done already:
1) Run testdisk with the following outputs:
Intel/PC partition option prior to analyzing https://paste.linux.community/view/ac96223c
Non partitioned media option prior analysis https://paste.linux.community/view/a352742e
So the first scan only came up with:
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
Linux 12858 253 4 24340 40 20 184444928
Enter: to continue
ext4 blocksize=4096 Large_file Sparse_SB, 94 GB / 87 GiB
so that should be the Extended Linux partition (that is sda3, before sda4)
and the second one with those (among other little FAT partitions):
P NTFS 6436 37 34 19282 67 17 206372864
Structure: Ok.
Keys T: change type, P: list files,
Enter: to continue
NTFS, blocksize=4096, 105 GB / 98 GiB
P ext4 12858 253 2 24340 40 18 184444928
Structure: Ok.
Enter: to continue
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 94 GB / 87 GiB
2) Run gpard /dev/sda with the following output after 24+ hours of the command running:
Begin scan...
Possible partition(DOS FAT), size(10mb), offset(6720mb)
Possible partition(Windows NT/W2K FS), size(0mb), offset(31042mb)
Possible partition(Windows NT/W2K FS), size(3mb), offset(33462mb)
Possible partition(Windows NT/W2K FS), size(3mb), offset(33466mb)
Possible partition(Windows NT/W2K FS), size(3mb), offset(33469mb)
Possible partition(Windows NT/W2K FS), size(3mb), offset(34282mb)
Possible partition(Windows NT/W2K FS), size(0mb), offset(38780mb)
Possible partition(Windows NT/W2K FS), size(100767mb), offset(50486mb)
Possible partition(Windows NT/W2K FS), size(953866mb), offset(953867mb)
** Fatal error: dev(/dev/sda): seek failure.
3) Run MiniTool partition recovery option & EaseUS one, through mounting the disk to Windows pc, with the scans not showing the veracrypt partition, but one of the (MiniTool) showing the above linux one (87.95GB)
My question is, do you know any possible way that I should proceed in order to recover the Veracrypt partition (previous sda4)? In the end thats the only data that I care of.
I look forward to your insights, as I am available for any clarifications! Thank you in advance for your time!
Restore Veracrypt partition after accidental deletion of partition table
Re: Restore Veracrypt partition after accidental deletion of partition table
Choose PC Intel and post the testdisk.log file
