Testdisk Partition Recovery HELP!! Topic is solved
Elija786s1
#1 Post by Elija786s1 »
So I accidentally deleted my partitions using clean command in diskpart. :oops:
Now i've used testdisk and i was able to write back a lot but there is still 700+ gb (out of 3 terabyte) of unallocated space.
What should i do now? How can i recover data from that unallocated space?
Re: Testdisk Partition Recovery HELP!!
Please post the testdisk.log file.
Note that you should use EFI GPT partition table as your disk is over 2 TB.
Elija786s1
#3 Post by Elija786s1 »
cgrenier wrote: 19 Apr 2017, 06:21 Please post the testdisk.log file.
I am using win 10 and i can't find the log file (i do set it to create at the start)
So i followed your instructions and this is how it goes
1) Selected the disk
http://imgur.com/kAqzqXw
2) Selected Efi Gpt
http://imgur.com/M36NDRk
3) Selected Analyze
http://imgur.com/oe3BviP
4) Bad partition message
http://imgur.com/zDbIc3i
5) Quick search (during)
http://imgur.com/2bP2fFz
6) Following partition can't be recovered
http://imgur.com/u7w8Io0
7) After quick search
http://imgur.com/qtF4xNm
8) I can see my files in list after i hit p.
So please tell me.. what should i do?
Elija786s1
#4 Post by Elija786s1 »
Data is recovered.
#5 Post by cgrenier »
Perfect!
