Bad jump in FAT partition
Re: Bad jump in FAT partition
#11 Post by cgrenier »
You can try TestDisk, Advanced, Boot, RepairMFT but it may be safer to use the software that list your files and use it to recover everything.
conandrum
#12 Post by conandrum »
I get 'MFT and MFT mirror are bad. Failed to repair them.'
Is there any hope?
Log follows:
Sat Apr 29 02:52:05 2017
TestDisk 7.1-WIP, Data Recovery Utility, April 2017
Compiler: GCC 5.4, Cygwin 2005.2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=600132550656
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdg)=32015679488
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=600132550656
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=32015679488
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=600130453504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=3000457232384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=32015678464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\O:)=0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\P:)=0
Warning: can't get size for \\.\P:
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Q:)=0
Warning: can't get size for \\.\Q:
Disk /dev/sda - 600 GB / 558 GiB - CHS 72961 255 63, sector size=512 - Intel Raid 0 Volume, S/N:VELOCIRAID, FW:1.0.
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30 EZRZ-00WN9B0, S/N:W -DCW4C6EVV9T54, FW:80.0
Disk /dev/sdg - 32 GB / 29 GiB - CHS 7663 255 32, sector size=512 - SanDisk Cruzer Glide, S/N:20051032001AFB12E9DC, FW:2.01
Disk /dev/sdb - 3000 GB / 2794 GiB - WDC WD30 EZRZ-00WN9B0
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=5860533167 (expected 5860533167)
hdr_lba_start=34
hdr_lba_end=5860533134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
2 P MS Data 264192 5860532223 5860268032 [Basic data partition]
ntfs_boot_sector
NTFS at 16/113/34
NTFS at 16/113/34
filesystem size 5860268032
mftmirr_lcn 2
Status: OK
Status: OK
Sectors are identical.
$MFT has invalid magic.
ntfs_mft_load(): Failed.
repair_MFT
NTFS at 16/113/34
ntfs_boot_sector
NTFS at 16/113/34
NTFS at 16/113/34
mftmirr_lcn 2
Status: OK
Status: OK
#13 Post by cgrenier »
You can always use PhotoRec on the whole space of the partition but it will not recover the original filenames, so you may want to use one of the commercial software that was able to list the filenames instead.
conandrum
#14 Post by conandrum »
unfortunately the commercial program is not able to recover the filesystem.
do u think i can do anything else with testdisk?
conandrum
#15 Post by conandrum »
i gave up.
i can only recover individual files.
thx
