8GB pen drive to 8mb
chisimalu
#1 Post by chisimalu »
I have a 8GB memory pen drive.
I tried to format fat32 but something has gone wrong.
Now it is impossible to read/write both under linux and windows.
the drive now appear 8Mb (not 8Gb)
when I use testdisk
this is my testdrive log file
Sat May  6 16:33:29 2017
OS: Linux, kernel 3.16.0-4-amd64 (#1 SMP Debian 3.16.7-ckt25-2+deb8u3 (2016-07-02)) x86_64
Compiler: GCC 4.9
Compilation date: 2014-10-19T15:35:24
ext2fs lib: 1.42.12, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
/dev/sda: LBA, LBA48, DCO support
/dev/sda: size       976773168 sectors
/dev/sda: user_max   976773168 sectors
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - HGST HTS545050A7E380, S/N:TM8514ZN2S5LNP, FW:GG2OACA0
Disk /dev/sdb - 8388 KB / 8192 KiB - CHS 1024 1 16, sector size=512 - Generic Flash Disk 2.0, FW:2.60
Disk /dev/sdb - 8388 KB / 8192 KiB - Generic Flash Disk 2.0
Analyse Disk /dev/sdb - 8388 KB / 8192 KiB - CHS 1024 1 16
Store new MBR code
Partition table type: None
   P Unknown                  0   0  1  1023   0 16      16384
Change partition type:
   P FAT32                    0   0  1  1023   0 16      16384
fat32_boot_sector
Bad
Bad
First sectors (Boot code and partition information) are not identical.
Third sectors (Second part of boot code) are not identical.
I tried also to change geometry , but I am not able to fix the difference.
I have another identical pendrive and I have seen that it has a different geometry
the broken disk is
the new (never used) disk is
disk /dev/sdb - 8241 MB / 7860 MiB - USB Disk CHS 1022 254 62 - sector size=512
Can you help me?
Thank you
Re: 8GB pen drive to 8mb
It's probably an electronic problem. You should replace the pen drive.
