Greetings, I have an Iomega 2tb home media network hard drive. After a power outage, I got this message in windows "The volume does not contain a recognized file system" and I am not able to access drive and files in it. After searching the web, I found your page, but don't know how to recover my partition(s). Your help will be, greatly, appreciated. Attached is the screenshot of the partition table for hd.
TestDisk 7.1-WIP, Data Recovery Utility, April 2017
Disk /dev/sdf - 2000 GB / 1863 GiB - CHS 243201 255 63
>P Linux LVM 65536 42008447 41942912
P Linux Raid 42008448 42008575 128 [md0]
D Linux Raid 42008584 42008591 8 [hmnhd-TI27XO:1]
D Linux LVM 42008584 3907028999 3865020416
P=Primary D=Deleted
Keys A: add partition, L: load backup, T: change type,
Enter: to continue
This is the message I get when I try to change the "Deleted" partition to "Primary
P Linux Raid 42008584 42008591 8 [hmnhd-TI27XO:1]
>P Linux LVM 42008584 3907028999 3865020416
Structure: Bad. Use Up/Down Arrow keys to select partition.
P=Primary D=Deleted
Enter: to continue
Iomega 2tb external HDD, help!!!
Re: Iomega 2tb external HDD, help!!!
Is your NAS containing a single disk or several ? It may been using Raid 1.
As your NAS is running Linux, you have to use Linux to repair it correctly.
Read https://www.cgsecurity.org/testdisk.pdf chapters "Creating a live USB" and "Installation of official binaries for Linux"
Boot from Linux, run testdisk... Please copy/paste the whole testdisk.log file content.
Thank you for your quick response. This is a single disc NAS. I will try your suggestion and update you on it.
Mon May 22 23:50:49 2017
TestDisk 7.1-WIP, Data Recovery Utility, May 2017
OS: Linux, kernel 4.4.0-53-generic (#74-Ubuntu SMP Fri Dec 2 15:58:04 UTC 2016) i686
Compiler: GCC 4.4
ext2fs lib: 1.42.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504, curses lib: ncurses 5.7
/dev/sda: size 976773168 sectors
/dev/sda: user_max 976773168 sectors
/dev/sda: dco 976773168 sectors
Warning: can't get size for Disk /dev/md0_vg - 0 B - 0 sectors (RO), sector size=512
Warning: can't get size for Disk /dev/loop0 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop1 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop2 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop3 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop4 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop5 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop6 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop7 - 0 B - 0 sectors, sector size=512
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000BPKT-00PK4T0, S/N:WD-WXL1AC0F0946, FW:01.01A01
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST320005 42AS
Disk /dev/mapper/md0_vg-BFDlv - 4294 MB / 4096 MiB - 8388608 sectors, sector size=512 - ST320005 42AS
Disk /dev/mapper/md0_vg-vol1 - 17 GB / 15 GiB - 33546240 sectors, sector size=512 - ST320005 42AS
Disk /dev/dm-0 - 4294 MB / 4096 MiB - 8388608 sectors, sector size=512 - ST320005 42AS
Disk /dev/dm-1 - 17 GB / 15 GiB - 33546240 sectors, sector size=512 - ST320005 42AS
Disk /dev/sdb - 2000 GB / 1863 GiB - ST320005 42AS
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3907029167 (expected 3907029167)
hdr_lba_start=34
hdr_lba_end=3907029134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P Linux LVM 65536 42008447 41942912
2 P Linux Raid 42008448 42008575 128 [md0]
Compiler: GCC 4.4
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
As root, can you run "pvdisplay", "vgdisplay" and "lvdisplay" ?
alex@Linux-PC ~ $ su
Password:
Linux-PC alex # "pvdisplay"
--- Physical volume ---
PV Name /dev/sdc1
VG Name md0_vg
PV Size 20.00 GiB / not usable 3.94 MiB
Allocatable yes (but full)
PE Size 4.00 MiB
Total PE 5119
Free PE 0
Allocated PE 5119
PV UUID X4Hifc-yZm3-zcec-uzWs-wviJ-10FH-12X3BM
Linux-PC alex # "vgdisplay"
--- Volume group ---
VG Name md0_vg
System ID
Format lvm2
Metadata Areas 1
Metadata Sequence No 3
VG Access read/write
VG Status resizable
MAX LV 0
Cur LV 2
Open LV 2
Max PV 0
Cur PV 1
Act PV 1
VG Size 20.00 GiB
PE Size 4.00 MiB
Total PE 5119
Alloc PE / Size 5119 / 20.00 GiB
Free PE / Size 0 / 0
VG UUID TLFuu7-2a5g-0X7C-9NK5-hl2y-ZfbA-6POgzj
Linux-PC alex # "lvdisplay"
--- Logical volume ---
LV Path /dev/md0_vg/BFDlv
LV Name BFDlv
VG Name md0_vg
LV UUID 58fZkD-nNrr-n04Q-8xIo-6xra-9Tt7-S0sz9O
LV Write Access read/write
LV Creation host, time ,
LV Status available
# open 3
LV Size 4.00 GiB
Current LE 1024
Segments 1
Allocation inherit
Read ahead sectors auto
- currently set to 256
Block device 252:0
LV Path /dev/md0_vg/vol1
LV Name vol1
VG Name md0_vg
LV UUID 5DnoJ0-e6Dm-3ntx-RviS-61c6-T2V4-7DmUOq
LV Status available
# open 3
LV Size 16.00 GiB
Current LE 4095
Segments 1
Allocation inherit
Block device 252:1
Linux-PC alex #
Password:
PV Name /dev/sdc1
VG Name md0_vg
PE Size 4.00 MiB
Total PE 5119
Free PE 0
Allocated PE 5119
VG Name md0_vg
System ID
Format lvm2
Metadata Areas 1
VG Status resizable
MAX LV 0
Cur LV 2
Open LV 2
Max PV 0
Cur PV 1
Act PV 1
VG Size 20.00 GiB
PE Size 4.00 MiB
Total PE 5119
LV Name BFDlv
VG Name md0_vg
LV Status available
# open 3
LV Size 4.00 GiB
Current LE 1024
Segments 1
Allocation inherit
Block device 252:0
LV Name vol1
VG Name md0_vg
LV Status available
# open 3
LV Size 16.00 GiB
Current LE 4095
Segments 1
Allocation inherit
Block device 252:1
Linux-PC alex #
I did a deeper search yesterday, and this is the log:
Thu May 25 11:02:19 2017
Compiler: GCC 4.4
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
LVM2 magic value at 4/20/17
part_size 41942912
LVM2, 21 GB / 19 GiB
Raid magic value at 2614/230/49
Raid apparent size: 0 sectors
Raid chunk size: 65536 bytes
md0 md 0.90.0 L.Endian Raid 4294967295: devices 0(8,1)*
md 0.90.0 L.Endian Raid 4294967295: devices 0(8,1)*, 65 KB / 64 KiB
LVM2 magic value at 2614/232/59
part_size 3865020416
LVM2, 1978 GB / 1842 GiB
Raid magic value at 243201/79/39
Raid apparent size: 3504134864 sectors
hmnhd-TI27XO:1 md 1.x L.Endian Raid 4294967295 - Array Slot : 0 (0)
md 1.x L.Endian Raid 4294967295 - Array Slot : 0 (0), 4096 B
Raid magic value at 243201/79/47
echo "0 41942912 linear /dev/sdb 65536" | dmsetup create test0
echo "0 128 linear /dev/sdb 42008448" | dmsetup create test1
echo "0 8 linear /dev/sdb 42008584" | dmsetup create test2
echo "0 3865020416 linear /dev/sdb 42008584" | dmsetup create test3
Invalid partition structure.
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
part_size 41942912
part_size 41942912
recover_EXT2: s_block_group_nr=0/32, s_mnt_count=192/32, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 1048576
recover_EXT2: part_size 8388608
Filesystem created: Wed Dec 31 19:02:40 1969
Last mount time: Thu May 25 11:00:21 2017
MS Data 65920 8454527 8388608
ext2 blocksize=4096 Large_file Sparse_SB, 4294 MB / 4096 MiB
block_group_nr 1
recover_EXT2: s_block_group_nr=1/32, s_mnt_count=0/32, s_blocks_per_group=32768, s_inodes_per_group=8192
MS Data 65918 8454525 8388608
ext2 blocksize=4096 Large_file Sparse_SB Backup_SB, 4294 MB / 4096 MiB
block_group_nr 1
block_group_nr 3
recover_EXT2: s_block_group_nr=3/32, s_mnt_count=0/32, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 3
recover_EXT2: s_block_group_nr=0/53, s_mnt_count=0/20, s_blocks_per_group=8136, s_inodes_per_group=488
recover_EXT2: s_blocks_count 439259
recover_EXT2: part_size 878518
MS Data 1196416 2074933 878518
ext2 blocksize=1024, 449 MB / 428 MiB
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/32, s_mnt_count=0/32, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 5
recover_EXT2: s_block_group_nr=0/1, s_mnt_count=1/20, s_blocks_per_group=5120, s_inodes_per_group=1248
recover_EXT2: s_blocks_count 5120
recover_EXT2: part_size 10240
Last mount time: Wed Dec 31 19:00:03 1969
MS Data 1382808 1393047 10240
ext2 blocksize=1024, 5242 KB / 5120 KiB
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/32, s_mnt_count=0/32, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 7
cramfs Marker at 130/223/21
recover_cramfs
MS Data 2102519 2102622 104 [Compressed]
cramfs, 53 KB / 52 KiB
cramfs Marker at 130/223/22
recover_cramfs
MS Data 2102520 2102623 104 [Compressed]
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/32, s_mnt_count=0/32, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 9
block_group_nr 25
recover_EXT2: s_block_group_nr=25/32, s_mnt_count=0/32, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 25
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/32, s_mnt_count=0/32, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 27
XFS Marker at 526/68/55
recover_xfs
MS Data 8454528 42000767 33546240
XFS 6.2+ - bitmap version, blocksize=4096, 17 GB / 15 GiB
Linux Swap 8454640 29924804879 29916350240
SWAP2 version 124090480, pagesize=8192, 15 TB / 13 TiB
This partition ends after the disk limits. (start=8454640, size=29916350240, end=29924804879, disk end=3907029168)
Linux Swap 8454648 9503207 1048560
SWAP2 version 1, pagesize=4096, 536 MB / 511 MiB
XFS Marker at 1048/78/55
recover_xfs
MS Data 16841088 50387327 33546240
XFS Marker at 1570/88/55
recover_xfs
MS Data 25227648 58773887 33546240
XFS Marker at 2092/98/55
recover_xfs
MS Data 33614208 67160447 33546240
XFS Marker at 2614/239/2
recover_xfs
MS Data 42008968 3907027335 3865018368
XFS 6.2+ - bitmap version, blocksize=4096, 1978 GB / 1842 GiB
XFS Marker at 62761/128/32
recover_xfs
MS Data 1008263560 4873281927 3865018368
This partition ends after the disk limits. (start=1008263560, size=3865018368, end=4873281927, disk end=3907029168)
FAT12 at 63916/169/18
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
fat_length 9 calculated 9
MS Data 1026821204 1026824083 2880 [NO NAME]
FAT12 at 66425/201/41
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
EFI System 1067130328 1067133207 2880 [EFI System Partition] [EFISECTOR]
NTFS at 66426/105/16
filesystem size 6174
sectors_per_cluster 1
mft_lcn 2058
mftmirr_lcn 5162
clusters_per_mft_record 2
clusters_per_index_record 8
MS Data 1067134147 1067140320 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1067140320 1067146493 6174 [Boot]
FAT12 at 94728/101/30
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
EFI System 1521811712 1521814591 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 94728/147/12
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
EFI System 1521814592 1521817471 2880 [EFI System Partition] [EFISECTOR]
XFS Marker at 122908/17/62
recover_xfs
MS Data 1974518152 5839536519 3865018368
This partition ends after the disk limits. (start=1974518152, size=3865018368, end=5839536519, disk end=3907029168)
FAT12 at 126959/240/58
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
EFI System 2039611512 2039614391 2880 [EFI System Partition] [EFISECTOR]
NTFS at 126960/144/33
mft_lcn 2058
mftmirr_lcn 5162
MS Data 2039615331 2039621504 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 2039621504 2039627677 6174 [Boot]
FAT12 at 161288/73/50
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
EFI System 2591096368 2591099247 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 161288/119/32
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
EFI System 2591099248 2591102127 2880 [EFI System Partition] [EFISECTOR]
XFS Marker at 183054/162/29
recover_xfs
MS Data 2940772744 6805791111 3865018368
This partition ends after the disk limits. (start=2940772744, size=3865018368, end=6805791111, disk end=3907029168)
FAT12 at 218798/130/37
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 34-11517
sectors : 11520
cluster_size : 4
no_of_cluster : 2871 (2 - 2872)
heads/cylinder 4 (FAT) != 255 (HD)
sect/track 36 (FAT) != 63 (HD)
MS Data 3514998096 3515009615 11520
FAT12, blocksize=2048, 5898 KB / 5760 KiB
LVM magic value at 219122/22/53
The harddisk (2000 GB / 1863 GiB) seems too small! (< 15 TB / 13 TiB)
MS Data 197451815
Compiler: GCC 4.4
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
part_size 41942912
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
part_size 41942912
part_size 41942912
block_group_nr 1
block_group_nr 1
block_group_nr 3
block_group_nr 3
block_group_nr 5
block_group_nr 5
block_group_nr 7
block_group_nr 7
recover_cramfs
recover_cramfs
block_group_nr 9
block_group_nr 9
block_group_nr 25
block_group_nr 25
block_group_nr 27
block_group_nr 27
recover_xfs
recover_xfs
recover_xfs
recover_xfs
recover_xfs
recover_xfs
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
mft_lcn 2058
mftmirr_lcn 5162
mft_lcn 2058
mftmirr_lcn 5162
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
recover_xfs
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
mft_lcn 2058
mftmirr_lcn 5162
mft_lcn 2058
mftmirr_lcn 5162
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
recover_xfs
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 34-11517
sectors : 11520
cluster_size : 4
MS Data 197451815
