connection lost while coping data from USB-Diskdrive (OS X)
rollermann
#1 Post by rollermann »
Hey Folks...
First of all: i´m German and not well trained in english. But i promise, i will try not to screw your screens with my english. (and i will explain all questions in german too.)
So it begins:
I got a Harddisk, that has an defective contact. But, with some tricks, i am able to make the connection work. While trying to get my data of of the disk, i lost connection.
The task, i tried to do was, to copy all folders into one folder. My OS X took all the data and creates the new folder. But right in that moment the connection got lost.
now, when i open testdisk and go to these Folders, in order to copy them to a working disk drive all the (as just deleted shown) folders are empty or the massage "filesystem damaged" appears.
copying the folders only went wrong.
right at the moment i quick scan the disk drive by test disk but it seem do take a while.
The picture shows so, information about the disk drive. the partition which try to get back is "Projekte"
Ask me for informations yo need to know. I will post the results of the scan as soon as i could.
Is there any way, to help me, in basic english. :D
Thanks for reading..
Re: connevtion lost while coping data from USB-Diskdrive (OS X)
While using TestDisk, did you see read error messages during the Quick or Deeper Search ?
Please copy and paste the testdisk.log file content.
rollermann
#3 Post by rollermann »
the log-file seems pretty big...
i don't recognize any fail during the tests. but something with the portion tables seems to be wrong. some partitions could not be recovered. but thats not the point. i can use the disk drive by fixing the usb-plug. al data is shown, except the fileS on "Projekte"
the deeper search took about two an a half days. May the results are not in the log because its date is 21.5.2017.
the screenshot i took is the result of the deeper search. on the next screen i see hundreds of partitions. i accidentally discarded the results. :oops:
Sun May 21 20:21:44 2017
TestDisk 7.1-WIP, Data Recovery Utility, May 2017
OS: Darwin, kernel 15.6.0 (Darwin Kernel Version 15.6.0: Fri Feb 17 10:21:18 PST 2017; root:xnu-3248.6
Compiler: GCC 4.0
Compilation date: May 19 201706:49:46
Disk /dev/disk0 - 1000 GB / 931 GiB - 1953525168 sectors (RO), sector size=512
Disk /dev/disk2 - 1000 GB / 931 GiB - 1953525168 sectors, sector size=512
Disk /dev/rdisk0 - 1000 GB / 931 GiB - 1953525168 sectors (RO), sector size=512
Disk /dev/rdisk1 - 4111 MB / 3921 MiB - 2007568 sectors (RO), sector size=2048
Disk /dev/rdisk2 - 1000 GB / 931 GiB - 1953525168 sectors, sector size=512
Analyse Disk /dev/disk2 - 1000 GB / 931 GiB - 1953525168 sectors
HFSX magic value at 2048/0/1
HFSX magic value at 307200000/0/1
get_geometry_from_list_part_aux head=1 nbr=8
get_geometry_from_list_part_aux head=8 nbr=8
get_geometry_from_list_part_aux head=16 nbr=8
get_geometry_from_list_part_aux head=32 nbr=8
get_geometry_from_list_part_aux head=64 nbr=8
get_geometry_from_list_part_aux head=128 nbr=8
 1 P HFS                         2048  307199999  307197952
 2 * HFS                    307200000  634879999  327680000
 3 P HPFS - NTFS            634880000 1572863999  937984000
 4 P HPFS - NTFS           1572866048 1953519615  380653568
Backup partition structure
partition_save
NTFS at 64/0/1
filesystem size           689494401
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS part_offset=32768, part_size=353021133312, sector_size=512
NTFS at 64/0/1
mftmirr_lcn               2
     HPFS - NTFS                   64  689494464  689494401
     NTFS, blocksize=4096, 353 GB / 328 GiB
BAD_RS LBA=105764270 839
     FAT32                 4400731566 6882913182 2482181617
This partition ends after the disk limits. (start=4400731566, size=2482181617, end=6882913182, disk end=1953525168)
BAD_RS LBA=1749360972 269
     FAT16 LBA             1749360972 5940931618 4191570647
This partition ends after the disk limits. (start=1749360972, size=4191570647, end=5940931618, disk end=1953525168)
BAD_RS LBA=133377916 1043
     FAT32 LBA             4428345212 4611787341  183442130
This partition ends after the disk limits. (start=4428345212, size=183442130, end=4611787341, disk end=1953525168)
[color=#FF0000]
here i shortened the logfile[/color]
filesystem size           1953520001
mftmirr_lcn               2
     HPFS - NTFS                   64 1953520064 1953520001
     NTFS found using backup sector, blocksize=4096, 1000 GB / 931 GiB
NTFS at 1953520064/0/1
mftmirr_lcn               2
NTFS: Can't read MFT
     HPFS - NTFS           1953520064 3907040064 1953520001
This partition ends after the disk limits. (start=1953520064, size=1953520001, end=3907040064, disk end=1953525168)
The harddisk (1000 GB / 931 GiB) seems too small! (< 5122 GB / 4770 GiB)
     FAT32                  798619192 2856643866 2058024675
     FAT16 LBA              820008746 4565694755 3745686010
     FAT16 >32M             926818804 2137475001 1210656198
     HPFS - NTFS           1013849930 4129674544 3115824615
 [color=#FF0000]
     FAT32                 5919446337 10004290631 4084844295
     FAT16 >32M            6030380895 7638397726 1608016832
get_geometry_from_list_part_aux head=1 nbr=6
     FAT16 >32M            1629311451 1855796268  226484818
[color=#FF0000]<here i shortened the logfile>[/color]
LVM magic value at 10688093/0/1
BAD_RS LBA=2392589101 500
     FAT16 >32M            2392589101 4871846103 2479257003
This partition ends after the disk limits. (start=2392589101, size=2479257003, end=4871846103, disk end=1953525168)
BAD_RS LBA=3239865804 560
     FAT16 >32M            3239865804 3294671515   54805712
This partition ends after the disk limits. (start=3239865804, size=54805712, end=3294671515, disk end=1953525168)
BAD_RS LBA=2031001887 228
     FAT16 >32M            2031001887 2779927797  748925911
This partition ends after the disk limits. (start=2031001887, size=748925911, end=2779927797, disk end=1953525168)
BAD_RS LBA=1103211955 623
     FAT16 LBA             1103211955 4964706867 3861494913
This partition ends after the disk limits. (start=1103211955, size=3861494913, end=4964706867, disk end=1953525168)
BAD_RS LBA=3578030612 1019
     FAT16 <32M            3578030612 7676951361 4098920750
[color=#FF0000]
     FAT16 >32M            3586539525 4475731444  889191920
This partition ends after the disk limits. (start=3586539525, size=889191920, end=4475731444, disk end=1953525168)
BAD_RS LBA=996397300 845
     FAT12                  996397300 1148621523  152224224
BAD_RS LBA=996647828 845
     FAT12                  996647828 1148872051  152224224
BAD_RS LBA=996898356 845
     FAT12                  996898356 1149122579  152224224
BAD_RS LBA=1024469764 845
     FAT12                 1024469764 1176693987  152224224
BAD_RS LBA=1024720292 845
     FAT12                 1024720292 1176944515  152224224
BAD_RS LBA=1024970820 845
     FAT12                 1024970820 1177195043  152224224
BAD_RS LBA=328810028 234
     FAT12                  328810028 2893209375 2564399348
This partition ends after the disk limits. (start=328810028, size=2564399348, end=2893209375, disk end=1953525168)
BAD_RS LBA=329705532 234
     FAT12                  329705532 2894104879 2564399348
This partition ends after the disk limits. (start=329705532, size=2564399348, end=2894104879, disk end=1953525168)
[color=#FF0000]
This partition ends after the disk limits. (start=1269651477, size=3626672248, end=4896323724, disk end=1953525168)
BAD_RS LBA=677074654 727
     FAT16 <32M             677074654 2476518436 1799443783
This partition ends after the disk limits. (start=677074654, size=1799443783, end=2476518436, disk end=1953525168)
HFSX magic value at 307199996/0/1
part_size 307197952
     HFS                    307199996  614397947  307197952
     HFSX blocksize=4096, 157 GB / 146 GiB
HFSX magic value at 307199998/0/1
part_size 307197952
     HFS+ found using backup sector!, 157 GB / 146 GiB
[color=#FF0000]
sectors : 409600
cluster_size : 1
FAT differs, FAT sectors=0-16/3151
sect/track 32 (FAT) != 1 (HD)
FAT32 at 314544768/0/1
     FAT32 LBA              314544768  314954367     409600 [EFI System Partition] [EFI]
FAT32 at 314544774/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT differs, FAT sectors=16-32/3151
     FAT32 LBA              314544774  314954373     409600 [EFI System Partition] [EFI]
HFSX magic value at 314694996/0/1
part_size 327008176
     HFS                    314694996  641703171  327008176
     HFSX blocksize=4096, 167 GB / 155 GiB
HFSX magic value at 314694998/0/1
[color=#FF0000]
HFSX magic value at 319257572/0/1
HFSX magic value at 319257899/0/1
part_size 327008176
     HFS                    319257899  646266074  327008176
HFSX magic value at 319257901/0/1
HFSX magic value at 319258260/0/1
part_size 327008176
     HFS                    319258260  646266435  327008176
HFSX magic value at 319258262/0/1
HFSX magic value at 319258389/0/1
part_size 327008176
     HFS                    319258389  646266564  327008176
HFSX magic value at 319258391/0/1
HFSX magic value at 319258518/0/1
part_size 327008176
     HFS                    319258518  646266693  327008176
HFSX magic value at 319258520/0/1
BAD_RS LBA=2926234671 973
     FAT32                 2926234671 3518641025  592406355
This partition ends after the disk limits. (start=2926234671, size=592406355, end=3518641025, disk end=1953525168)
BAD_RS LBA=1657372337 252
     FAT16 LBA             1657372337 3767032696 2109660360
This partition ends after the disk limits. (start=1657372337, size=2109660360, end=3767032696, disk end=1953525168)
BAD_RS LBA=2258495528 932
     FAT32                 2258495528 5880370102 3621874575
This partition ends after the disk limits. (start=2258495528, size=3621874575, end=5880370102, disk end=1953525168)
BAD_RS LBA=1040604851 947
[color=#FF0000]
This partition ends after the disk limits. (start=2825199368, size=2116149384, end=4941348751, disk end=1953525168)
BAD_RS LBA=3752096016 971
     FAT16 >32M            3752096016 7646484387 3894388372
This partition ends after the disk limits. (start=3752096016, size=3894388372, end=7646484387, disk end=1953525168)
BAD_RS LBA=3753249040 971
     FAT16 >32M            3753249040 7647637411 3894388372
This partition ends after the disk limits. (start=3753249040, size=3894388372, end=7647637411, disk end=1953525168)
HFS+ magic value at 673140140/0/1
part_size 44520
     HFS                    673140140  673184659      44520
     HFS+ blocksize=2048 + Backup, 22 MB / 21 MiB
HFS+ magic value at 673140142/0/1
part_size 44520
     HFS                    673095624  673140143      44520
     HFS+ found using backup sector!, 22 MB / 21 MiB
HFS+ magic value at 673140296/0/1
part_size 43360
     HFS                    673140296  673183655      43360
     HFS+ blocksize=4096 + Backup, 22 MB / 21 MiB
HFS+ magic value at 673140298/0/1
part_size 43360
     HFS                    673096940  673140299      43360
HFS+ magic value at 673183652/0/1
part_size 43360
     HFS                    673183652  673227011      43360
     HFS+ blocksize=4096, 22 MB / 21 MiB
HFS+ magic value at 673183654/0/1
part_size 43360
HFS+ magic value at 673184656/0/1
part_size 44520
     HFS                    673184656  673229175      44520
     HFS+ blocksize=2048, 22 MB / 21 MiB
HFS+ magic value at 673184658/0/1
part_size 44520
BAD_RS LBA=3579826053 657
     FAT16 <32M            3579826053 6684054554 3104228502
This partition ends after the disk limits. (start=3579826053, size=3104228502, end=6684054554, disk end=1953525168)
BAD_RS LBA=1464953372 845
     FAT12                 1464953372 1617177595  152224224
BAD_RS LBA=1465204252 845
     FAT12                 1465204252 1617428475  152224224
[color=#FF0000]
     FAT12                 2342432109 3647998588 1305566480
This partition ends after the disk limits. (start=2342432109, size=1305566480, end=3647998588, disk end=1953525168)
BAD_RS LBA=2138686797 602
     FAT16 >32M            2138686797 5897456977 3758770181
This partition ends after the disk limits. (start=2138686797, size=3758770181, end=5897456977, disk end=1953525168)
BAD_RS LBA=2914258276 967
     FAT32 LBA             2914258276 6365173329 3450915054
This partition ends after the disk limits. (start=2914258276, size=3450915054, end=6365173329, disk end=1953525168)
FAT32 at 1073240616/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
     FAT32 LBA             1073240616 1073650215     409600 [EFI System Partition] [EFI]
FAT32 at 1073240622/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
     FAT32 LBA             1073240622 1073650221     409600 [EFI System Partition] [EFI]
BAD_RS LBA=1209688006 670
     FAT32                 1209688006 5104911905 3895223900
This partition ends after the disk limits. (start=1209688006, size=3895223900, end=5104911905, disk end=1953525168)
BAD_RS LBA=2199208248 293
     FAT32 LBA             2199208248 6336318068 4137109821
This partition ends after the disk limits. (start=2199208248, size=4137109821, end=6336318068, disk end=1953525168)
BAD_RS LBA=3832419493 530
     HPFS - NTFS           3832419493 4805178405  972758913
This partition ends after the disk limits. (start=3832419493, size=972758913, end=4805178405, disk end=1953525168)
BAD_RS LBA=2853679007 500
     FAT16 LBA             2853679007 4256839910 1403160904
This partition ends after the disk limits. (start=2853679007, size=1403160904, end=4256839910, disk end=1953525168)
BAD_RS LBA=4093273984 305
     FAT16 >32M            4093273984 6270077833 2176803850
This partition ends after the disk limits. (start=4093273984, size=2176803850, end=6270077833, disk end=1953525168)
HFSX magic value at 1092466728/0/1
part_size 327008176
     HFS                   1092466728 1419474903  327008176
HFSX magic value at 1092466730/0/1
part_size 327008176
     HFS                    765458556 1092466731  327008176
     HFS+ found using backup sector!, 167 GB / 155 GiB
[color=#FF0000]
HFSX magic value at 1093735138/0/1
part_size 327008176
     HFS                    766726964 1093735139  327008176
HFSX magic value at 1093735474/0/1
part_size 327008176
     HFS                   1093735474 1420743649  327008176
HFSX magic value at 1093735476/0/1
part_size 327008176
     HFS                    766727302 1093735477  327008176
HFSX magic value at 1093735803/0/1
part_size 327008176
     HFS                   1093735803 1420743978  327008176
HFSX magic value at 1093735805/0/1
part_size 327008176
     HFS                    766727631 1093735806  327008176
HFSX magic value at 1093736164/0/1
part_size 327008176
     HFS                   1093736164 1420744339  327008176
HFSX magic value at 1093736166/0/1
part_size 327008176
     HFS                    766727992 1093736167  327008176
HFSX magic value at 1093736293/0/1
part_size 327008176
     HFS                   1093736293 1420744468  327008176
HFSX magic value at 1093736295/0/1
part_size 327008176
     HFS                    766728121 1093736296  327008176
HFSX magic value at 1093736422/0/1
part_size 327008176
     HFS                   1093736422 1420744597  327008176
HFSX magic value at 1093736424/0/1
part_size 327008176
     HFS                    766728250 1093736425  327008176
BAD_RS LBA=3087765395 894
     HPFS - NTFS           3087765395 3803856466  716091072
This partition ends after the disk limits. (start=3087765395, size=716091072, end=3803856466, disk end=1953525168)
BAD_RS LBA=2974789311 598
     FAT12                 2974789311 3311056213  336266903
This partition ends after the disk limits. (start=2974789311, size=336266903, end=3311056213, disk end=1953525168)
BAD_RS LBA=2974825663 598
     FAT12                 2974825663 3311092565  336266903
This partition ends after the disk limits. (start=2974825663, size=336266903, end=3311092565, disk end=1953525168)
BAD_RS LBA=2503369000 713
     FAT16 LBA             2503369000 6248124988 3744755989
This partition ends after the disk limits. (start=2503369000, size=3744755989, end=6248124988, disk end=1953525168)
BAD_RS LBA=1473845861 518
     FAT32                 1473845861 2287522517  813676657
This partition ends after the disk limits. (start=1473845861, size=813676657, end=2287522517, disk end=1953525168)
BAD_RS LBA=4232592643 898
     FAT16 LBA             4232592643 5278735730 1046143088
This partition ends after the disk limits. (start=4232592643, size=1046143088, end=5278735730, disk end=1953525168)
BAD_RS LBA=1327407783 915
     FAT32                 1327407783 5353939635 4026531853
This partition ends after the disk limits. (start=1327407783, size=4026531853, end=5353939635, disk end=1953525168)
BAD_RS LBA=2183282017 534
     FAT32                 2183282017 5336492213 3153210197
This partition ends after the disk limits. (start=2183282017, size=3153210197, end=5336492213, disk end=1953525168)
BAD_RS LBA=1343924615 471
     FAT12                 1343924615 1881992332  538067718
BAD_RS LBA=2998765247 598
     FAT12                 2998765247 3335032149  336266903
This partition ends after the disk limits. (start=2998765247, size=336266903, end=3335032149, disk end=1953525168)
BAD_RS LBA=1608295734 1031
     HPFS - NTFS           1608295734 3517108866 1908813133
This partition ends after the disk limits. (start=1608295734, size=1908813133, end=3517108866, disk end=1953525168)
HFSX magic value at 1128367828/0/1
part_size 327008176
     HFS                   1128367828 1455376003  327008176
HFSX magic value at 1128367830/0/1
part_size 327008176
     HFS                    801359656 1128367831  327008176
BAD_RS LBA=3079540798 377
     FAT32                 3079540798 3979600997  900060200
This partition ends after the disk limits. (start=3079540798, size=900060200, end=3979600997, disk end=1953525168)
BAD_RS LBA=2426748915 867
     HPFS - NTFS           2426748915 3486418269 1059669355
This partition ends after the disk limits. (start=2426748915, size=1059669355, end=3486418269, disk end=1953525168)
BAD_RS LBA=2502088170 743
     FAT16 >32M            2502088170 4274214627 1772126458
This partition ends after the disk limits. (start=2502088170, size=1772126458, end=4274214627, disk end=1953525168)
BAD_RS LBA=4163335086 938
[color=#FF0000]
mftmirr_lcn               2
mftmirr_lcn               2
The harddisk (1000 GB / 931 GiB) seems too small! (< 11894294 TB / 10817797 TiB)
     FAT12                   39376216 4214853184 4175476969
     FAT16 LBA               97498850 3843184859 3745686010
     FAT12                  133268633 3138814915 3005546283
     FAT16 LBA              164974248 3787228040 3622253793
     FAT32                  201025247 4124274355 3923249109
     FAT16 <32M             218756300 3892301139 3673544840
     FAT12                  330601036 2895000383 2564399348
     FAT32                  333636223 4483957826 4150321604
     FAT32                  430267039 2199337955 1769070917
     FAT32                  489729830 4384953729 3895223900
     HPFS - NTFS            492969410 3608794024 3115824615
     FAT12                  550487028 3114886375 2564399348
     HPFS - NTFS            657184231 4893439837 4236255607
     HPFS - NTFS            661680635 4897936241 4236255607
     FAT16 >32M             674051994 2734576546 2060524553
     FAT16 <32M             675077366 2474521148 1799443783
     FAT16 <32M             677074654 2476....
     [color=#FF0040]here i shortened the log file[/color]
get_geometry_from_list_part_aux head=1 nbr=1072
get_geometry_from_list_part_aux head=8 nbr=221
get_geometry_from_list_part_aux head=16 nbr=113
get_geometry_from_list_part_aux head=32 nbr=65
get_geometry_from_list_part_aux head=64 nbr=42
get_geometry_from_list_part_aux head=128 nbr=25
get_geometry_from_list_part_aux head=240 nbr=4
     HFSX blocksize=4096 + Backup, 157 GB / 146 GiB
     HFS                        11638  307209589  307197952
     HFS                        11903  307209854  307197952
    [color=#FF0000]
     HFS                        43436  307241387  307197952
     FAT16 LBA               88716639 1143645157 1054928519
     FAT32 LBA              244584211 1101143924  856559714
     HFSX blocksize=4096 + Backup, 167 GB / 156 GiB
  [color=#FF0000]
     HFS                    314474758  641482933  327008176
     HFS                    314544528  641552703  327008176
  [color=#FF0000]
     HFS                    317685206  644693381  327008176
     HPFS - NTFS            317702927  570410660  252707734
     HFS                    319256863  646265038  327008176
     HFS                    319257232  646265407  327008176
     HFS                    319257570  646265745  327008176
     FAT16 LBA              400674340  561757758  161083419
     Linux                  552960000  880639999  327680000
     XFS 6.2+ - bitmap version, blocksize=4096, 167 GB / 156 GiB
     FAT32                  570422438  731928258  161505821
     FAT16 <32M             616282447 1713651693 1097369247
     FAT32 LBA              621874267 1525908753  904034487
     HFS                    634879996  962559995  327680000
     HFSX blocksize=4096, 167 GB / 156 GiB
     exFAT, blocksize=131072, 480 GB / 447 GiB
     HFS                    634880000 1572863999  937984000
     HFS+ blocksize=4096, 480 GB / 447 GiB
     HFS                    634880012 1572864011  937984000
     FAT32 LBA              635505531 1539540017  904034487
     FAT32 LBA              651184559  821471526  170286968
     FAT16 LBA              663197593  986640163  323442571
     FAT16 <32M             669494481 1927001587 1257507107
     FAT32 LBA              692519603  717735733   25216131
     FAT12                  704271415 1932668962 1228397548
     FAT32                  727090429 1540767085  813676657
     FAT12                  738638055 1276705772  538067718
     HFS                    765468684 1092476859  327008176
     HFS                    765470751 1092478926  327008176
    [color=#FF0000]
     FAT16 >32M             821955118 1337211134  515256017
     FAT16 <32M             848647437 1804987237  956339801
     FAT32 LBA              902642999  936142881   33499883
     FAT16 >32M            1040604851 1267089668  226484818
     HPFS - NTFS           1048578048 1572866047  524288000
     NTFS found using backup sector, blocksize=4096, 268 GB / 250 GiB
     FAT16 >32M            1073021078 1588277094  515256017
     HFS                   1092476856 1419485031  327008176
  [color=#FF0000]
     HFS                   1093734052 1420742227  327008176
     HFS                   1093734349 1420742524  327008176
     HFS                   1093734566 1420742741  327008176
     HFS                   1093734767 1420742942  327008176
     HFSX blocksize=4096
rollermann
#4 Post by rollermann »
now this is shown... i think i have to chose expat, becausee this is the partigionformat
i added screenshots to this post... but they are not shown.. two *.tiff-pictures
rollermann
Re: connection lost while coping data from USB-Diskdrive (OS X)
#5 Post by rollermann »
i found some more data, but got problems with copying.
106fils are ok, but about 5000 are failed..
log shows things like:
xfat_ucstoutf8: iconv failed Illegal byte sequence
exfat_ucstoutf8: iconv failed Illegal byte sequence
exfat_ucstoutf8: iconv failed Invalid argument
ERROR: Couldn't set the file's date and time for /Users/MarcusSchoeneich/Desktop/festplatte/System Volume Information/볍맗샇볁뤻색볅뫯샥볡뱏섋봇묳삓/ၯ꒽獻拢掠礦㱺Ӽ妽ﺜꉛ鷖炖쟢୾憓廊彡ó亜豏멐秓㣞뇯唍⓾櫏袣㠏㌮鿉챕㭣ঽ뢄쿗熣ꛒ喇//ᰃꌴꀧꔂ耀鋳憎ꓴ瀂悪榎///樐噺뎨媼哅肤ߌ⯹褼꜆韁ᐬ悓高ɋ€0â䬝´©‚://ꫵ䬆σꦴ鞖ु㇠忮ᾕ씸왾迚ꧼ㿜⟸붰݆ᱹ푒鞖ࡌ蔺譳꿤瀎䁂䧂肯섹///疈﯀ᶣ搅駝冴왎掖憎憸㥧搜ꝴᛩ//ꪭ黎恚ҙ趷쪭껜鬨ᝁ殷㇐鈆ኮ魌ꙷ㶣줻뻷狙㉟⯌큑ങట摇/ꣷ遦Ḫფﵟ튡ࢩ볂辳镑敡⇊弻룻/䣨눢론⮝鍚䞥츊즕즰㽛仐Ἢ葛㭴輿᭬⚊感坐厜狼죱꼓㒁倔䁠霘虌/ゼ誧뼯掦⧣㋄⌄嚥饷ꨯ䖜䳹엇쑵/츳䬘⃝葏衩兯熬ࠬ㏚㈇䡈颵/B‚e²€e>UàýW‹¤//날틪ᙚĊ慈팴胞Ŵ那⓳㼘䃾☔FeÑ
:”,AÊ¡/à/ߔ䈪ᵉ縤ধꑱ鋿䃒⃷ኽ⁎햼쨘ῤ냵阜ౘ펉➫漑̜驛洏쥆㔅嫳梮晎/ቀ訁ᱸ≶ඐ俆剳撢ﱴ耩ອz蘩県槼/////µ]–êaº¶ßÿâÁwbßÝ///š—¢BF“Oñj…Oã//
Can't create file /Users/MarcusSchoeneich/Desktop/festplatte/System Volume Information/볍맗샇볁뤻색볅뫯샥볡뱏섋봇묳삓/ၯ꒽獻拢掠礦㱺Ӽ妽ﺜꉛ鷖炖쟢୾憓廊彡ó亜豏멐秓㣞뇯唍⓾櫏袣㠏㌮鿉챕㭣ঽ뢄쿗熣ꛒ喇//ᰃꌴꀧꔂ耀鋳憎ꓴ瀂悪榎///樐噺뎨媼哅肤ߌ⯹褼꜆韁ᐬ悓高ɋ€0â䬝´©‚://ꫵ䬆σꦴ鞖ु㇠忮ᾕ씸왾迚ꧼ㿜⟸붰݆ᱹ푒鞖ࡌ蔺譳꿤瀎䁂䧂肯섹///疈﯀ᶣ搅駝冴왎掖憎憸㥧搜ꝴᛩ//ꪭ黎恚ҙ趷쪭껜鬨ᝁ殷㇐鈆ኮ魌ꙷ㶣줻뻷狙㉟⯌큑ങట摇/ꣷ遦Ḫფﵟ튡ࢩ볂辳镑敡⇊弻룻/䣨눢론⮝鍚䞥츊즕즰㽛仐Ἢ葛㭴輿᭬⚊感坐厜狼죱꼓㒁倔䁠霘虌/ゼ誧뼯掦⧣㋄⌄嚥饷ꨯ䖜䳹엇쑵/츳䬘⃝葏衩兯熬ࠬ㏚㈇䡈颵/B‚e²€e>UàýW‹¤//날틪ᙚĊ慈팴胞Ŵ那⓳㼘䃾☔FeÑ
:”,AÊ¡/à/ߔ䈪ᵉ縤ধꑱ鋿䃒⃷ኽ⁎햼쨘ῤ냵阜ౘ펉➫漑̜驛洏쥆㔅嫳梮晎/ቀ訁ᱸ≶ඐ俆剳撢ﱴ耩ອz蘩県槼/////µ]–êaº¶ßÿâÁwbßÝ///š—¢BF“Oñj…Oã//:
exFAT: Can't read directory cluster.
#6 Post by cgrenier »
Please run the command "sudo fsck /dev/disk2s4". What is the result ?
If it doesn't work, you can use PhotoRec on this partition, after selecting the partition (4 NTFS), choose Search and [Whole] instead of [Free]
