Help! Deleted Bootcamp partition on OS X
Dilbert
#1 Post by Dilbert »
I deleted the bootcamp created partition for Windows 7 on my Mac running Os X 10.6.8
i have tried testdisk and the response is:
MS Data 3907028991 4231448574 324419584
NTFS, blocksize=4096, 166 GB / 154 GiB
What can I do?
Sun Jun 17 15:41:45 2012
OS: Darwin, kernel 10.8.0 (Darwin Kernel Version 10.8.0: Tue Jun 7 16:33:36 PDT 2011; root:xnu-1504.1
Compiler: GCC 4.0
Compilation date: 2012-06-14T10:10:33
ext2fs lib: 1.41.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504
Disk /dev/disk0 - 2000 GB / 1863 GiB - CHS 3907029168 1 1 (RO), sector size=512
Disk /dev/rdisk0 - 2000 GB / 1863 GiB - CHS 3907029168 1 1 (RO), sector size=512
Media is opened in read-only.
Disk /dev/rdisk0 - 2000 GB / 1863 GiB (RO)
Partition table type: EFI GPT
Analyse Disk /dev/rdisk0 - 2000 GB / 1863 GiB - CHS 3907029168 1 1 (RO)
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3907029167 (expected 3907029167)
hdr_lba_start=34
hdr_lba_end=3907029134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P EFI System 40 409639 409600 [EFI System Partition]
2 P Mac HFS 409640 3906766983 3906357344 [Customer]
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
sect/track 32 (FAT) != 1 (HD)
FAT32 at 40/0/1
EFI System 40 409639 409600 [EFI]
part_size 3906357344
HFS+ blocksize=4096, 2000 GB / 1862 GiB
NTFS at 3907028991/0/1
filesystem size 324419584
mftmirr_lcn 2
NTFS: Can't read MFT
This partition ends after the disk limits. (start=3907028991, size=324419584, end=4231448574, disk end=3907029168)
The harddisk (2000 GB / 1863 GiB) seems too small! (< 2166 GB / 2017 GiB)
P EFI System 40 409639 409600 [EFI]
1 P EFI System 40 409639 409600 [EFI]
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
FAT32 at 46/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 46/0/1
EFI System 46 409645 409600 [EFI]
Re: Help! Deleted Bootcamp partition on OS X
Your MS Data-partition ends beyond the disk limit.
Your HFS-partitions size is 2000 GB
HFS+ blocksize=4096, [b]2000 GB[/b] / 1862 GiB
It looks like your HFS partition uses the whole disk space.
Disk /dev/[b]rdisk0 - 2000 GB[/b] / 1863 GiB - CHS 3907029168 1 1 (RO)
Did you check your disk utilities that you still have 166 GB free space?
Dilbert
#3 Post by Dilbert »
Hi Fiona and thanks for your reply.
I think the bootcamp application created a single partition when it deleted the MS one.
According to Disk Utility my HDD is a Hitachi HDS722020ALA330 Media
Partition Map Scheme : GUID Partition Table
Disk Identifier : disk0
Media Name : Hitachi HDS722020ALA330 Media
Media Type : Generic
Connection Bus : SATA
Device Tree : IODeviceTree:/PCI0@0/SATA@1F,2/PRT0@0/PMP@0
Total Capacity : 2 TB (2,000,398,934,016 Bytes)
S.M.A.R.T. Status : Verified
Disk Number : 0
Partition Number : 0
The Partition is:
Typ : Volume
Disk Identifier : disk0s2
Mount Point : /
System Name : Mac OS X
System Version : 10.6.8
System Build : 10K549
File System : Mac OS Extended (Journaled)
Writable : Yes
Capacity : 2 TB (2,000,054,960,128 Bytes)
Free Space : 1.76 TB (1,756,114,857,984 Bytes)
Used : 243.94 GB (243,940,102,144 Bytes)
Number of Files : 771,999
Number of Folders : 220,922
Owners Enabled : Yes
Can Turn Owners Off : Yes
Can Repair Permissions : Yes
Can Be Verified : Yes
Can Be Repaired : Yes
Can Be Formatted : Yes
Bootable : Yes
Supports Journaling : Yes
Journaled : Yes
Disk Number : 0
Partition Number : 2
Any suggestions?
Many thanks,
Benny
Dilbert
#4 Post by Dilbert »
Hi, Fiona or someone else,
Has anyone any ideas as to a solution for my deleted partition?
I.E Should i just move on and forget about the "lost" partition?
any help would be greatly appreciated.
Regards,
Benny
Dilbert
#5 Post by Dilbert »
Hi again,
I understand that this forum is moderated and attended to by probably volunteers and non paid staff, which is great!
I am a little disappointed in the seemingly lack of focus on most topics posted (a couple of replies at the most), but a "massive" response on a few.
I just cold not wait any longer for a possibly answer so I found another software that successfully recovered the files I needed.
Boomerang Data Recovery Software.
Worked a treat!
It is not free, but cost me only $9.95 as I only needed to recover 5MB of data.
You can set this post to solved.
Regards,
