I have windows 10 and it would not load to windows 10, my hard drive says 117 partitions, then another program says 10 partitions on a 280 gig hard drive, I cannot get to my folders on my hard drive, so where to I start to recover my hard drive partitions, or where do I start to repair my hard drive?
Chris
How do i fix my hard drive?
Re: How do i fix my hard drive?
Run TestDisk, Advanced, check the number of partitions, if the number of partitions or the partition table looks corrupted, choose Analyze, Quick Search...
Read https://www.cgsecurity.org/testdisk.pdf the chapter about partition recovery
If you need help, please post the testdisk.log file content or some information about your partitions before the problem
