"error 2133571387" when trying to list files
spariant4
#1 Post by spariant4 »
Hi all.
I am trying to retrieve data from an overwritten ext4 partition, labelled "Home". I have found possible target partitions via testdisk, but cannot list their files.
Initially Testdisk found 2 such possible partitions, but could not display them because of the "This partition ends after the disk limits" error.
OS: Linux, kernel 4.11.3-200.fc25.x86_64 (#1 SMP Thu May 25 19:03:07 UTC 2017) x86_64
Compiler: GCC 6.0
Compilation date: 2016-03-28T13:31:33
ext2fs lib: 1.43.3, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.0
/dev/sda: size       250069680 sectors
/dev/sda: user_max   250069680 sectors
/dev/sda: native_max 250069680 sectors
Disk /dev/sda - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512 - LITEONIT L8T-128L6G-HP, S/N:002345142118, FW:D871701
Disk /dev/sda - 128 GB / 119 GiB - LITEONIT L8T-128L6G-HP
Partition table type: None
---break---
LVM magic value at 10237/103/25
LVM magic value at 10985/66/38
recover_EXT2: s_block_group_nr=0/781, s_mnt_count=8/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 25602560
recover_EXT2: part_size 204820480
     ext4                 13015  40 16 25764 163 61  204820480 [Home]
     ext4 blocksize=4096 Large_file Sparse_SB Recover, 104 GB / 97 GiB
     This partition ends after the disk limits. (start=209088510, size=204820480, end=413908989, disk end=250069680)
LVM magic value at 14551/41/6
     ext4                 14712  50 57 27461 174 39  204820480 [Home]
     This partition ends after the disk limits.[/b] (start=236351486, size=204820480, end=441171965, disk end=250069680)
I searched the forums and tried changing the disk geometry, which was successful in showing those partitions.
New geometry
Disk /dev/sda - 211 GB / 197 GiB - CHS 25765 255 63 sector_size=512
New options :
 Dump : No
 Align partition: No
 Expert mode : Yes
---break---
But when I try to list the files in these partitions, the "filesystem may be damaged" error is shown, and the log shows ext2fs_dir_iterate failed with error 2133571387.
dir_partition inode=2
   P ext4                 14712  50 57 27461 174 39  204820480 [Home]
   P ext4                 13015  40 16 25764 163 61  204820480 [Home]
What is error 2133571387? And why does the log mention LVM and NTFS when handling these partitions, when they are ext4 formatted on a GPT disk?
I'm also curious about expert options in testdisk, can these help? And do i maybe need to install additional libraries in linux to read these partitions?
As a secondary solution, photorec seems to scan only current partitions, so how do i direct photorec to scan these deleted partitions?
A similar issue has been raised on the forums before, but I did not find a solution: Topic 1 and Topic 2
Thank you for your suggestions.
Re: "error 2133571387" when trying to list files
COncerning the possibility use PhotoRec on a deleted partition. After starting PhotoRec when you see the list of partitions, press the key 'a' and manually add the values corresponding to the partition/area you want to recover from.
spariant4
#3 Post by spariant4 »
Thanks for this.
By entering partition sectors manually, I'm recovering an unholy number of "riff" extension/ wav files. Doesn't seem right. Is this some generic container which photorec recovers data in?
I am experimenting with manually added sectors, will keep trying different possibilities.
Btw, is there any information to be found on the 'error 2133571387' when using testdisk? I would like to bump my earlier post, because accessing that lost partition would greatly help with my problem.
