I then tested the drive with testdisk and the geometry was fine 255 heads
I then installed Windows 7 32bit and run the test again and now its telling me that the geometry is incorrect, its telling me my heads value that now reads 240 is incorrect and should be changed to 255.
The HDD works fine and windows 7 works as it should, no errors what so ever so how is it that testdisk wants me to change to 255.
I tested this and changed to 255 but that was the end, no more windows 7
