Intel Raid 0 Recovery Issue.
IM0001
#1 Post by IM0001 »
Digging around for the better half of the day or more, and I am just stumped if I am at the limit of the software, or doing something wrong when trying to recover a Partition that is readable and able to recover files from (though It is interesting I have to take ownership of .exe files before I can use them again on the recovered drive) but I cannot for the life of me restore the partition fully.
My configuration is 2 2TB WD Blacks. Raid-0 (64K stripe) as a big storage/game drive.
Recreated the Raid-0 array exactly as it was before, however upon scanning for the Partition, TestDisk says that the partition is too big. (By only a handful of sectors it seems. No idea why except for the possible reason that these two drives started life as a Raid-1 array, and then were converted with IRST to Raid-0 which worked just fine until today when I downgraded my Bios on my P9X79 Deluxe after dealing with some terrible new OC issues. Before downgrading however the OC was removed and system was stable with working drives. Once I flashed the bios is when it removed one of the drives from the array.
The quick and deep scans both find the same single Partition, and when I resize my drive geometry to match, I am able to open the partition it finds, and recover the files, however I cannot write the partition to the disk in the correct format (GPT). It always gives me a Write Error.
If I scan as a Intel/PC (MBR) partition, it finds the same partition and I am able to write that to the disk, but upon reboot, I feel its running into the issue of MBR being a max size of 2TB. The partition that shows in Disk Manager has unallocated space before and after the partition that was created but it shows as RAW.
When I use a different app like EaseUS Partition Master, you can see the full partition, but it remains inaccessible and that software does nothing to find the lost partition itself.
So am I missing something or is my slight partition size difference the exact problem and I will have to just recover all the files, wipe the partition, and just restore from there?
Below is the log from the last attempt at messing around in there. I don't get how the partition is 1 MB smaller than the Raid Array, however it says it is too big unless I adjust the Sectors to allow it to fit which also allows me to browse and copy files off.
Thu Jun 29 23:23:12 2017
TestDisk 7.1-WIP, Data Recovery Utility, May 2017
OS: Windows 8 (9200)
Compiler: GCC 5.4, Cygwin 2005.2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=1000210432000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=4000762036224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=4398046511104
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=1000210432000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4000762036224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=4398046511104
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=966904512512
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=499971522560
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=4397910196224
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Intel Raid 0 Volume, S/N:EVORAID0, FW:1.0.
Disk /dev/sdb - 4000 GB / 3726 GiB - CHS 486398 255 63, sector size=512 - Intel Raid 0 Volume, S/N:TheSuperRaid, FW:1.0.
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - KWI TECH EZD-2536U3-USB-3, S/N:PROLIFICMP00000001D, FW:3.AA
Disk /dev/sdd - 4398 GB / 4096 GiB - CHS 534698 255 63, sector size=512 - FreeNAS iSCSI Disk, S/N:0015175b9c2a00, FW:0123
Disk /dev/sdb - 4000 GB / 3726 GiB - Intel Raid 0 Volume
Partition table type: EFI GPT
Analyse Disk /dev/sdb - 4000 GB / 3726 GiB - CHS 486398 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=7814032064 (expected 7813988351)
hdr_lba_start=34
hdr_lba_end=7814032031
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Data                   264192 7814045695 7813781504 [The Super Raid]
NTFS at 16/113/34
filesystem size           7813781504
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS part_offset=135266304, part_size=4000656130048, sector_size=512
NTFS at 16/113/34
mftmirr_lcn               2
     NTFS, blocksize=4096, 4000 GB / 3725 GiB
This partition ends after the disk limits. (start=264192, size=7813781504, end=7814045695, disk end=7813988352)
file_pread(5,2,buffer,7813988351(486398/71/9)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,7813988352(486398/71/10)) ReadFile The drive cannot find the sector requested.
The harddisk (4000 GB / 3726 GiB) seems too small! (< 4000 GB / 3726 GiB)
New geometry
Disk /dev/sdb - 4000 GB / 3726 GiB - CHS 486401 255 63 sector_size=512
Analyse Disk /dev/sdb - 4000 GB / 3726 GiB - CHS 486401 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=7814032064 (expected 7814032064)
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 16/113/34
mftmirr_lcn               2
NTFS at 16/113/34
mftmirr_lcn               2
file_pread(5,8,buffer,7814045696(486401/216/24)) lseek err Invalid argument
file_pread(5,1,buffer,7814045696(486401/216/24)) lseek err Invalid argument
file_pread(5,1,buffer,7814045697(486401/216/25)) lseek err Invalid argument
file_pread(5,14,buffer,7814045698(486401/216/26)) lseek err Invalid argument
file_pread(5,3,buffer,7814045712(486401/216/40)) lseek err Invalid argument
file_pread(5,3,buffer,7814045759(486401/217/24)) lseek err Invalid argument
file_pread(5,8,buffer,7814045775(486401/217/40)) lseek err Invalid argument
file_pread(5,11,buffer,7814045822(486401/218/24)) lseek err Invalid argument
file_pread(5,2,buffer,7814047744(486401/248/56)) lseek err Invalid argument
write!
file_pwrite(5,32,buffer,7814032032(486400/254/31)) seek err Invalid argument
Partition: Write error
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=7813988351 (expected 7814032064)
hdr_lba_start=34
hdr_lba_end=7813988318
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Reserved                   34     262177     262144 [Microsoft reserved partition]
NTFS at 16/113/34
mftmirr_lcn               2
NTFS at 16/113/34
mftmirr_lcn               2
write!
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 16/113/34
mftmirr_lcn               2
NTFS at 16/113/34
mftmirr_lcn               2
write!
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 16/113/34
mftmirr_lcn               2
NTFS at 16/113/34
mftmirr_lcn               2
dir_partition inode=5
       5 dr-xr-xr-x     0      0         0 28-Jun-2017 19:42 .
       5 dr-xr-xr-x     0      0         0 28-Jun-2017 19:42 ..
    8434 dr-xr-xr-x     0      0         0 22-Apr-2017 19:42 $RECYCLE.BIN
 2884743 dr-xr-xr-x     0      0         0 23-Apr-2017 15:05 Config.Msi
  440280 dr-xr-xr-x     0      0         0  2-Jun-2017 14:54 GalaxyClient
  540739 dr-xr-xr-x     0      0         0 11-May-2017 15:32 Games
  636648 dr-xr-xr-x     0      0         0 28-Jun-2017 16:34 Origin
      35 dr-xr-xr-x     0      0         0 13-Sep-2015 11:15 Other Games
   10010 dr-xr-xr-x     0      0         0 11-Apr-2017 17:42 Program Files (x86)
  636629 dr-xr-xr-x     0      0         0 29-Jun-2017 10:51 Steam
  585218 dr-xr-xr-x     0      0         0 22-Jan-2017 15:03 System Volume Information
   44603 dr-xr-xr-x     0      0         0 30-May-2017 10:06 Ubisoft Game Launcher
  538482 dr-xr-xr-x     0      0         0 27-Mar-2017 21:20 VMWare Virtual Machines
  427024 dr-xr-xr-x     0      0         0 10-May-2017 16:50 msdownld.tmp
  440280 -r--r--r--     0      0         0  2-Jun-2017 14:54 GalaxyClient:Win32App_1
  636648 -r--r--r--     0      0         0 28-Jun-2017 16:34 Origin:Win32App_1
  636629 -r--r--r--     0      0         0 29-Jun-2017 10:51 Steam:Win32App_1
   44603 -r--r--r--     0      0         0 30-May-2017 10:06 Ubisoft Game Launcher:Win32App_1
   63094 -r--r--r--     0      0    463958 24-Jul-2016 11:20 x264_lookahead.clbin
dir_partition inode=636648
Directory /Origin
  636648 dr-xr-xr-x     0      0         0 28-Jun-2017 16:34 .
  636789 dr-xr-xr-x     0      0         0 27-Mar-2017 20:42 Installers
  430482 dr-xr-xr-x     0      0         0 28-Jun-2017 19:42 Origin Games
  103270 dr-xr-xr-x     0      0         0 28-Jun-2017 16:34 audio
  636653 dr-xr-xr-x     0      0         0 15-Nov-2013 07:17 codecs
  636658 dr-xr-xr-x     0      0         0 28-Jun-2017 16:34 imageformats
  636673 dr-xr-xr-x     0      0         0 28-Jun-2017 16:34 legacyPM
 1169075 dr-xr-xr-x     0      0         0 28-Jun-2017 16:34 mediaservice
 1608151 dr-xr-xr-x     0      0         0 28-Jun-2017 16:34 platforms
   12255 dr-xr-xr-x     0      0         0 15-Jul-2015 19:43 plugins
 1820184 dr-xr-xr-x     0      0         0 28-Jun-2017 16:34 printsupport
  636736 dr-xr-xr-x     0      0         0 28-Jun-2017 16:34 sounds
  636747 dr-xr-xr-x     0      0         0 28-Jun-2017 16:34 x64
  636648 -r--r--r--     0      0         0 28-Jun-2017 16:34 .:Win32App_1
    8319 -r--r--r--     0      0    219581 28-Jun-2017 16:34 3RDPARTYLICENSES.HTML
    8830 -r--r--r--     0      0    240272 28-Jun-2017 16:34 3RDPARTYLICENSES_FR.HTML
  274463 -r--r--r--     0      0         0 22-Feb-2015 21:27 EACore.ini
   15288 -r--r--r--     0      0       574 13-Oct-2016 18:27 EACore_App.ini
    9124 -r--r--r--     0      0   1815944 28-Jun-2017 16:34 EAProxyInstaller.exe
    9125 -r--r--r--     0      0     46984 28-Jun-2017 16:34 GetGameToken32.exe
    9126 -r--r--r--     0      0     52616 28-Jun-2017 16:34 GetGameToken64.exe
    9133 -r--r--r--     0      0   1236336 28-Jun-2017 16:34 IGO32.dll
    9152 -r--r--r--     0      0   2454400 28-Jun-2017 16:34 InstallerDLL.dll
    9352 -r--r--r--     0      0       215 28-Jun-2017 16:34 Origin.VisualElementsManifest.xml
    9351 -r--r--r--     0      0   3048312 28-Jun-2017 16:34 Origin.exe
    9353 -r--r--r--     0      0  41947520 28-Jun-2017 16:34 OriginClient.dll
    9355 -r--r--r--     0      0   2168208 28-Jun-2017 16:34 OriginClientService.exe
    9357 -r--r--r--     0      0   2320272 28-Jun-2017 16:34 OriginCrashReporter.exe
    9360 -r--r--r--     0      0       215 28-Jun-2017 16:34 OriginER.VisualElementsManifest.xml
    9358 -r--r--r--     0      0  10972024 28-Jun-2017 16:34 OriginER.exe
    9539 -r--r--r--     0      0  21182344 28-Jun-2017 16:34 OriginThinSetupInternal.exe
    9546 -r--r--r--     0      0    864656 28-Jun-2017 16:34 OriginUninstall.exe
  195755 -r--r--r--     0      0       318  8-Jan-2014 17:43 OriginUpdate_9_4_1_76.zip.part.map
    9627 -r--r--r--     0      0   3148184 28-Jun-2017 16:34 OriginWebHelperService.exe
   10492 -r--r--r--     0      0   4930048 28-Jun-2017 16:34 Qt5Core.dll
   10567 -r--r--r--     0      0   4540928 28-Jun-2017 16:34 Qt5Gui.dll
   10579 -r--r--r--     0      0    709632 28-Jun-2017 16:34 Qt5Multimedia.dll
   10580 -r--r--r--     0      0     94208 28-Jun-2017 16:34 Qt5MultimediaWidgets.dll
   10581 -r--r--r--     0      0   1052672 28-Jun-2017 16:34 Qt5Network.dll
   10582 -r--r--r--     0      0    306688 28-Jun-2017 16:34 Qt5OpenGL.dll
   10588 -r--r--r--     0      0    207360 28-Jun-2017 16:34 Qt5Positioning.dll
   10591 -r--r--r--     0      0    314368 28-Jun-2017 16:34 Qt5PrintSupport.dll
   10592 -r--r--r--     0      0   3322880 28-Jun-2017 16:34 Qt5Qml.dll
   10593 -r--r--r--     0      0   3126784 28-Jun-2017 16:34 Qt5Quick.dll
   11639 -r--r--r--     0      0    181760 28-Jun-2017 16:34 Qt5Sensors.dll
   11820 -r--r--r--     0      0    187904 28-Jun-2017 16:34 Qt5Sql.dll
  575223 -r--r--r--     0      0   3227648 11-Sep-2014 19:13 Qt5V8.dll
   13392 -r--r--r--     0      0    108544 28-Jun-2017 16:34 Qt5WebChannel.dll
   29272 -r--r--r--     0      0    229376 28-Jun-2017 16:34 Qt5WebEngine.dll
   44650 -r--r--r--     0      0  41751552 28-Jun-2017 16:34 Qt5WebEngineCore.dll
   46502 -r--r--r--     0      0    177152 28-Jun-2017 16:34 Qt5WebEngineWidgets.dll
  125142 -r--r--r--     0      0  17347072  9-Jun-2016 06:42 Qt5WebKit.dll
  125143 -r--r--r--     0      0    218112  9-Jun-2016 06:42 Qt5WebKitWidgets.dll
   77918 -r--r--r--     0      0    143872 28-Jun-2017 16:34 Qt5WebSockets.dll
   77961 -r--r--r--     0      0   5105664 28-Jun-2017 16:34 Qt5Widgets.dll
   87852 -r--r--r--     0      0    183296 28-Jun-2017 16:34 Qt5Xml.dll
   88014 -r--r--r--     0      0   3401728 28-Jun-2017 16:34 Qt5XmlPatterns.dll
  636766 -r--r--r--     0      0   2966528  8-Jan-2014 19:29 QtCore4.dll
  636767 -r--r--r--     0      0   9679872  8-Jan-2014 19:29 QtGui4.dll
    9528 -r--r--r--     0      0   1232896  8-Jan-2014 19:29 QtNetwork4.dll
  636768 -r--r--r--     0      0    914432  8-Jan-2014 19:29 QtOpenGL4.dll
   88546 -r--r--r--     0      0     22928 28-Jun-2017 16:34 QtWebEngineProcess.exe
  636769 -r--r--r--     0      0  18662400  8-Jan-2014 19:29 QtWebKit4.dll
  636770 -r--r--r--     0      0    412160  8-Jan-2014 19:29 QtXml4.dll
  636771 -r--r--r--     0      0   3514368  8-Jan-2014 19:29 QtXmlPatterns4.dll
  117545 -r--r--r--     0      0    258944 28-Jun-2017 16:34 UpdateTool.exe
    9122 -r--r--r--     0      0    246332 28-Jun-2017 16:34 avutil-ttv-51.dll
  636748 -r--r--r--     0      0    250605  8-Jan-2014 19:28 curl-ca-bundle.crt
    9123 -r--r--r--     0      0   3466856 28-Jun-2017 16:34 d3dcompiler_47.dll
  411513 -r--r--r--     0      0    346919 29-Jun-2017 10:51 debug.log
    9127 -r--r--r--     0      0  22324736 28-Jun-2017 16:34 icudt51.dll
    9128 -r--r--r--     0      0  10206624 28-Jun-2017 16:34 icudtl.dat
    9130 -r--r--r--     0      0   1381376 28-Jun-2017 16:34 icuin51.dll
    9131 -r--r--r--     0      0   1060864 28-Jun-2017 16:34 icuuc51.dll
    9138 -r--r--r--     0      0   1410928 28-Jun-2017 16:34 igo64.dll
    9140 -r--r--r--     0      0     42872 28-Jun-2017 16:34 igoproxy.exe
    9141 -r--r--r--     0      0     46976 28-Jun-2017 16:34 igoproxy64.exe
    9342 -r--r--r--     0      0     12288 28-Jun-2017 16:34 libEGL.dll
    9343 -r--r--r--     0      0    148992 28-Jun-2017 16:34 libEGL_Swift.dll
    9344 -r--r--r--     0      0   2493440 28-Jun-2017 16:34 libGLESv2.dll
    9345 -r--r--r--     0      0   5201408 28-Jun-2017 16:34 libGLESv2_Swift.dll
  636755 -r--r--r--     0      0    338944  8-Jan-2014 19:28 libcurl.dll
    9339 -r--r--r--     0      0   1544704 28-Jun-2017 16:34 libeay32.dll
    9346 -r--r--r--     0      0  16196504 28-Jun-2017 16:34 libmfxsw32.dll
  636758 -r--r--r--     0      0    394810  8-Jan-2014 19:29 libmp3lame-0.dll
    9347 -r--r--r--     0      0    394810 28-Jun-2017 16:34 libmp3lame-ttv.dll
    9348 -r--r--r--     0      0     58012 28-Jun-2017 16:34 logreader.html
   98056 -r--r--r--     0      0     17816 22-Feb-2015 21:25 production.wad
   92739 -r--r--r--     0      0   6833521 28-Jun-2017 16:34 qtwebengine_resources.pak
   92971 -r--r--r--     0      0    415020 28-Jun-2017 16:34 qtwebengine_resources_100p.pak
   93065 -r--r--r--     0      0    476671 28-Jun-2017 16:34 qtwebengine_resources_200p.pak
   93362 -r--r--r--     0      0    393728 28-Jun-2017 16:34 ssleay32.dll
   93592 -r--r--r--     0      0    113171 28-Jun-2017 16:34 swresample-ttv-0.dll
  636775 -r--r--r--     0      0     64000  8-Jan-2014 19:29 tufao.dll
  636776 -r--r--r--     0      0    440664  8-Jan-2014 19:29 twitch32.dll
  103831 -r--r--r--     0      0   1086976 28-Jun-2017 16:34 twitchsdk_32_release.dll
  124696 -r--r--r--     0      0   7194312 28-Jun-2017 16:34 vcredist_x64.exe
  124741 -r--r--r--     0      0   5673816 28-Jun-2017 16:34 vcredist_x64_vs2010.exe
  124775 -r--r--r--     0      0   6503984 28-Jun-2017 16:34 vcredist_x86.exe
  124845 -r--r--r--     0      0   4995416 28-Jun-2017 16:34 vcredist_x86_vs2010.exe
dir_partition inode=430482
Directory /Origin/Origin Games
  430482 dr-xr-xr-x     0      0         0 28-Jun-2017 19:42 .
  636648 dr-xr-xr-x     0      0         0 28-Jun-2017 16:34 ..
  430483 dr-xr-xr-x     0      0         0 28-Jun-2017 19:10 Battlefield 1
  176544 dr-xr-xr-x     0      0         0 27-Mar-2017 21:33 Battlefield 4
 2109633 dr-xr-xr-x     0      0         0 14-Dec-2013 14:57 CNC and The Covert Operations
 2123418 dr-xr-xr-x     0      0         0 19-Dec-2013 10:57 Command and Conquer Generals Zero Hour
  431819 dr-xr-xr-x     0      0         0 27-Mar-2017 21:53 Command and Conquer Red Alert
 2139508 dr-xr-xr-x     0      0         0 14-Dec-2013 21:26 Command and Conquer Red Alert II
 2142800 dr-xr-xr-x     0      0         0 14-Dec-2013 21:19 Command and Conquer Tiberian Sun
   10930 dr-xr-xr-x     0      0         0  8-Oct-2015 07:16 Dragon Age Inquisition
 2087518 dr-xr-xr-x     0      0         0 19-Nov-2013 23:22 Mass Effect 3
    8352 dr-xr-xr-x     0      0         0 17-Jan-2017 21:51 STAR WARS Battlefront
   93739 dr-xr-xr-x     0      0         0 28-Jun-2017 21:24 STAR WARS Battlefront II Closed Alpha
   88150 dr-xr-xr-x     0      0         0 10-Mar-2017 19:28 SimCity
 2110900 dr-xr-xr-x     0      0         0 21-Dec-2016 21:27 Star Wars - The Old Republic
    8307 dr-xr-xr-x     0      0         0  1-Apr-2015 18:58 Titanfall
  440109 dr-xr-xr-x     0      0         0 28-Jun-2017 19:41 Titanfall2
  424064 dr-xr-xr-x     0      0         0  4-May-2015 19:25 Ultima 8
  636648 -r--r--r--     0      0         0 28-Jun-2017 16:34 ..:Win32App_1
  430483 -r--r--r--     0      0         0 28-Jun-2017 19:10 Battlefield 1:Win32App_1
  176544 -r--r--r--     0      0         0 27-Mar-2017 21:33 Battlefield 4:Win32App_1
 2109633 -r--r--r--     0      0         0 14-Dec-2013 14:57 CNC and The Covert Operations:Win32App_1
 2123418 -r--r--r--     0      0         0 19-Dec-2013 10:57 Command and Conquer Generals Zero Hour:Win32App_1
 2139508 -r--r--r--     0      0         0 14-Dec-2013 21:26 Command and Conquer Red Alert II:Win32App_1
  431819 -r--r--r--     0      0         0 27-Mar-2017 21:53 Command and Conquer Red Alert:Win32App_1
 2142800 -r--r--r--     0      0         0 14-Dec-2013 21:19 Command and Conquer Tiberian Sun:Win32App_1
   10930 -r--r--r--     0      0         0  8-Oct-2015 07:16 Dragon Age Inquisition:Win32App_1
 2087518 -r--r--r--     0      0         0 19-Nov-2013 23:22 Mass Effect 3:Win32App_1
   93739 -r--r--r--     0      0         0 28-Jun-2017 21:24 STAR WARS Battlefront II Closed Alpha:Win32App_1
    8352 -r--r--r--     0      0         0 17-Jan-2017 21:51 STAR WARS Battlefront:Win32App_1
   88150 -r--r--r--     0      0         0 10-Mar-2017 19:28 SimCity:Win32App_1
 2110900 -r--r--r--     0      0         0 21-Dec-2016 21:27 Star Wars - The Old Republic:Win32App_1
  440109 -r--r--r--     0      0         0 28-Jun-2017 19:41 Titanfall2:Win32App_1
    8307 -r--r--r--     0      0         0  1-Apr-2015 18:58 Titanfall:Win32App_1
  424064 -r--r--r--     0      0         0  4-May-2015 19:25 Ultima 8:Win32App_1
Directory /Origin
gpt_change_part_type
Change partition type:
   P NTFS                      264192 7814045695 7813781504 [The Super Raid]
write!
Re: Intel Raid 0 Recovery Issue.
You should be able to copy the files using TestDisk, Advanced, List.
It may be possible to reduce the partition size, after Analyse, Quick Search, Stop, use 'a' to manually add a partition starting at 264192 and ending 7814032031 (or less), set this partition as P(rimary).
Check that you list the files. On next screen, choose Write, confirm, Quit
In Advanced, select the partition, Boot, RebuildBS, List, if you can see the files, choose Write, confirm, Quit and restart your computer.
IM0001
#3 Post by IM0001 »
Copy files did work but considering the amount (3.5TB'ish) that would take weeks.
Luckily some form of combination of what I did got the partition accessible again that I was able to get 99.9% of everything off it and onto my NAS before I wipe and recreate the Raid/Partition to make sure everything is peachy again.
When I tried to write the partition info after adjusting the geometry and scanning for PC/Intel which also found the same partition, it wrote it incorrectly as an MBR disk, but I believe I rebooted again, removed the raid disk and recreated the raid once more, then initialized the disk as GPT but did not format, then rebooted, brought up the partition (with 128MB before the partition per disk manager, but wasn't touchable or expandable as it would throw a driver error. Checked after the files were all backed up.) It was either that, or the fact that I tried to restore the GPT partition after I initialized it as GPT also, but it said Write Error as before so really I am not 100% sure exactly what got me back up, but I will definitely be keeping this thread around for the future incase it happens again.
During the backup at this point, I had a handful of files that couldn't be copied because the Sector was invalid/missing or something. No biggie as I said as I was happy I got this far.
Thank you for your tool and help. Hopefully this also helps someone else who runs into nearly the same issue.
