Hi, I am using testdisk 7-0, included in system rescue cd
I deleted a partition or several (yes, I am not sure what I did) but didn't write anything to that disc after that. I didn't delete the first one, which is a swap partition. The size of the disk is 320GB.
One of them (if I deleted several...) is the biggest one, NTFS format, with lots of folders and files.
Testdisk told me that I had a GPT partition table (hint) So I chose that.
But then I got the error that the hard drive is too small.
Anyway, I chose one of the partitions that appeared to be the big important one, listed the files, the files were there. Nothing in red, at least not on main screen, but inside of one of the many folders who knows.
I selected all files (a) and then copied them to another drive.
At the end I got that a lot of files had been copied but 555 failed.
If I check the testdisk.log, the only weird thing I can find is many lines at the end of file containing "Cannot find attribute type 0x80"
The number of these lines is more than 555 times >>> EDIT: There are in fact 555 lines with that error.
I would like to know where those files were, their names or something.
I have repeated the same choosing "intel" at the beginning, and then I got 2 partitions listed, both in green color (don't know why the green color now)
I again chose the big one and copied files again to another hardrive. Same thing. 555 files failed.
I don't know where to look that tells me which files are the problematic ones... Plus I would like to understand the problem about "hard drive too small", when I go the GPT route. In the meantime I will do a deep search.
Thanks for any help.
555 files failed
555 files failed
Re: 555 files failed
Without the testdisk.log file, it's difficult to help you.
Otherwise the MFT attribute 0x80 is the $DATA attribute.
https://digital-forensics.sans.org/blog ... ft-entries
Hi, thanks for your reply.
One thing I want to correct is that indeed there are 555 lines with the error, I don't know why, maybe I was viewing the logfile while it was doing the copy or something and then I closed it and the file changed.
Anyway, those are the 555 lines with that error. I still don't know after your reply if it means there are 555 files that I am not going to recover, or if it means they are "really small" bunches of data that are not important.
Another detail, the size of the existing swap partition is 1GB.
About the logs, I am going to attach 2 of them, the first small one with a normal scan (quick search), the second one is really big, with the deeper search.
For a quick idea, I am going to copy here the resulting screen after each of the scans/searches
Log with quicksearch (I wrote some notes on it)
https://mega.nz/#!iAsmSBxZ!JAA9zWjRjRZ- ... JlHZsW8tBw
Resulting screen after quick search (choosing GPT partition)
Resulting screen after quick search (choosing intel partition)
Log containing deeper search
https://mega.nz/#!2AtVVYbL!5ihZel_MnsfH ... 5XbqMTJcwI
Resulting screen after deeper search
So far, what makes more sense to me is when I choose Intel partition, because I really think that was all, a 1GB swap partition (that I didn't delete) and a big NTFS partition (the one that I deleted).
But if I check this drive with gparted (where I can see the 1 GB swap partition and rest unallocated), it really says GPT partition table...
With testdisk and the GPT option, all the numbers referring to starting sector, end sector and total of sectors don't make sense because they go beyond the real amount of sectors (as displayed in gparted for the total of the disk)
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63
The harddisk (320 GB / 298 GiB) seems too small! (< 639 GB / 595 GiB)
> MS Data 625139711 1248180215 623040505
MS Data 625141759 651526142 26384384Code: Select all
>* Linux Swap 0 32 33 130 170 40 2097152
P HPFS - NTFS 130 170 41 38913 37 36 623040512https://mega.nz/#!2AtVVYbL!5ihZel_MnsfH ... 5XbqMTJcwI
The harddisk (320 GB / 298 GiB) seems too small! (< 2305843 TB / 2097152 TiB)
> MS Data 466723007 4503600094429169 4503599627706162 [ck: %04x tv: %lu %lu adj: %d
MS Data 466723135 1792123198 1325400064
MS Data 625139704 1248180208 623040505
MS Data 625141759 651526142 26384384But if I check this drive with gparted (where I can see the 1 GB swap partition and rest unallocated), it really says GPT partition table...
