My 64G flash drive went RAW and TestDisk said No partition available. Topic is solved
kkofg
#1 Post by kkofg »
My 64G flash drive accidental went RAW during using. When I run testdisk-7.0 (32-bit), it said No partition available.
When I checked my flash drive.
When I press deepscan.
After deepscan and press enter.
When press advance
So I quit and re-run testdisk. This is the massage when I press analyze.
And when I run deepscan.
What can I do? Is it possible for me to recovery my flash drive?
Thank you for any suggestion.
Re: My 64G flash drive went RAW and TestDisk said No partition available.
You searched a partition inside your partition F:, it's useless.
Start TestDisk, select the PhysicalDrive1, Advanced, select your partition, Boot, RebuildBS, List.
If you can see your files, choose Write, confirm, Quit
If it doesn't work, use PhotoRec.
kkofg
#3 Post by kkofg »
Thank you for your reply.
After I posted the question, I try "testdisk-7.1-WIP.win32" and it's work!!!
Really appreciated for your hard work.
