I have a 4TB HD that contained a partition formatted in exFAT by OS X.
When I using it in Fedora I mistakenly removed this partition.
Regardless of the steps I perform in testdisk,
I get the message "Partition is corrupt" despite their label name is appearing.
I think that the problem is in the selection table partition between intel and GPT (default is intel) or in format of the partition (exFAT dont appear in intel options).
Anybody help me?
ExFat created by OS X and deleted in Fedora.
Re: ExFat created by OS X and deleted in Fedora.
The partition table type should be PC Intel only if the disk is actually using 4k sectors, otherwise it can be EFI GPT (with 512 bytes or 4096 bytes sector size).
Please copy/paste the testdisk.log file info if you want more information. It may be a good idea to try TestDisk, Advanced, Boot, List.
jonatasrenan
Thank you cgreiner,
This is my last try.
TestDisk > Intel > Advanced > "No partition Available"
TestDisk > EFI > Advanced > "No partition Available"
TestDisk > EFI > Analyse > "Trying alternate GPT" > QuickSearch (Stop in 38%) > See 2 partitions (EFI System (tiny), MS Data (half size of disc)) > Select MS Data > Deeper Search (Stop in 01%) > See 6 partitions:
1 EFI System > Press p > No file found, filesystem may be damaged.
2 EFI System > Press p > No file found, filesystem may be damaged.
3 MS Data > Press p > Can't open filesystem. Filesystem seems damaged.
4 MS Data > Press p > No file found, filesystem may be damaged.
5 MS Data > Press p > See Files!!!!! > Press h (hide deleted) > Press a (select all) > Press C (Copy selected) > Copy results (1/3 Ok 2/3 failed)
6 MS Data > Press p > See unknown files
7 MS Data > Press p > See unknown files
Log file: https://drive.google.com/file/d/0B6VAPu ... sp=sharing
jonatasrenan
Grenier,
I ran again with the above steps, this time, I let complete the quick and deep search.
https://drive.google.com/open?id=0B6VAP ... klWaHUxa28
