RAID
bartech
RAID
#1 Post by bartech »
Hello everyone :)
Quick specs.:
Motherboard: ASUS P9X79 WS
Windows 7 Ultimate x64, Sp1
1x SSD Samsung 840 PRO series - with OS on it;
2x Seagate Barracuda 7200 ST2000DM001-ER164 2000,3 GB connected as RAID0
Last night I had a serious problem with my RAID0 partition.
I've turned computer right after cleaning it (compressed air, gently etc:) . When system started to work there was my RAID drive visible but I couldn't access it at all :?
I've jumped to BIOS to check what is going on. There was AHCI turned on instead of RAID like it was previous, so I've switched it to RAID. When it comes to reboot - just before windows suppose to start - I saw just a blue screen in a second and whole computer was restarting repeatedly. :cry:
So I get back to AHCI mode. During restart, I've opened CTRL+I menu and saw that RAID Volume had Status Failed - One Physical Device was at Non-RAID Disk status and second one was as Member Disk(0).
I was digging through the internet with my friend and we've found this thread:
http://www.overclock.net/t/478557/howto ... disk-error
So I did exactly like it was mentioned there by reseting both HDs to non-member.
After that I was trying to switch RAID mode in BIOS but still no luck. At AHCI mode i went back to windows, turn on TestDisk and somehow I'm able to copy files from one of the Barracudas.
I've also tried to do this:
http://www.tomshardware.co.uk/forum/320 ... -raid-mode
(after which I couldn't even work at AHCI or IDE)
...and this (#12)
https://www.techpowerup.com/forums/thre ... ry.180621/
Below you can find log file from TestDisk which I did after making steps from upper thread (#12) :
Tue Jul 25 01:40:06 2017
TestDisk 7.1-WIP, Data Recovery Utility, July 2017
Compiler: GCC 5.4, Cygwin 2005.2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=3800720998400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=3800720998400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=255953207296
filewin32_getfilesize(\\.\D:) GetFileSize err Niepoprawna funkcja.
filewin32_setfilepointer(\\.\D:) SetFilePointer err Niepoprawna funkcja.
Disk /dev/sda - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - Samsung SSD 840 PRO Seri, S/N:S1ATNSAF520545Y, FW:DXM0
Disk /dev/sdb - 3800 GB / 3539 GiB - CHS 462078 255 63, sector size=512 - Intel Raid 0 Volume, S/N:MAIN RAID, FW:1.0.
Disk /dev/sdb - 3800 GB / 3539 GiB - Intel Raid 0 Volume
Partition table type: EFI GPT
Analyse Disk /dev/sdb - 3800 GB / 3539 GiB - CHS 462078 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3907029167 (expected 7423283199)
hdr_lba_start=34
hdr_lba_end=3907029134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Reserved                   34     262177     262144 [Microsoft reserved partition]
 2 P MS Data                   264192 7813986303 7813722112 [Basic data partition] [MAIN RAID]
NTFS at 16/113/34
filesystem size           7813722112
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS part_offset=135266304, part_size=4000625721344, sector_size=512
NTFS at 16/113/34
mftmirr_lcn               2
     MS Data                   264192 7813986303 7813722112 [MAIN RAID]
     NTFS, blocksize=4096, 4000 GB / 3725 GiB
This partition ends after the disk limits. (start=264192, size=7813722112, end=7813986303, disk end=7423283200)
file_pread(5,2,buffer,7423283199(462078/2/4)) ReadFile Nie można odnaleźć na dysku żądanego sektora.
file_pread(5,1,buffer,7423283200(462078/2/5)) ReadFile Nie można odnaleźć na dysku żądanego sektora.
The harddisk (3800 GB / 3539 GiB) seems too small! (< 4000 GB / 3725 GiB)
NTFS at 16/113/34
mftmirr_lcn               2
NTFS at 16/113/34
mftmirr_lcn               2
Quick translation (correct I hope:):
"Niepoprawna funkcja" - Incorrect function
"Nie można odnaleźć na dysku żądanego sektora" - unable to find requested sector
Overall, things that makes me very sad is that after changing mode in BIOS from AHCI to RAID, it cause blue screen error and I can't get rid of it.
Second one.. I have no idea what was the reason of this crash :cry:
If you have any idea how to go forward with this issue, how to fix it without loosing and recover it like it was, I'll be very grateful!
Have a great day!
Re: RAID
- The partition "MAIN RAID" ends at sector 7813986303. (7813986303+1)*512=4000760987648 bytes
- The Raid0 device is 3800720998400 bytes long.
It means the partition ends after the end of the Raid0.
The recommended way to deal with this problem is to copy all your data, delete the existing partition, create and format a new partition, restore your files.
bartech
Re: RAID
#3 Post by bartech »
Thank you so much for your response.
Thank god I was able to recover all the data.
Still I have problems when switching to RAID mode in BIOS (blue screen appears).
Now I'm trying to do some "magic" by Seagate SeaTools - maybe this will solve the problem :?:
