I was hoping someone might be able to help me recover an EXT4 partition. I lost 2 drives in my RAID5 the other day and trying to find some instructions online led me to hose the existing file system. For some reason, all the tools complain that my partition is larger than the space allowed, not by much, but it's still larger. I tried going to the section of the tool to adjust the disk geometry to try and get it to work but it doesn't let me enter any cylinder values that would result in a partition larger than 8 TiB. The partitions it finds I think are the correct ones.
Any assistance would be greatly appreciated. I'm copying some screen dumps below of the RAID itself and the output of the tool:
RAID rebuild
medusa ~ # mdadm --verbose --create /dev/md5 --level=5 --raid-devices 8 /dev/sd{c..i}1 missing
mdadm: layout defaults to left-symmetric
mdadm: chunk size defaults to 512K
mdadm: /dev/sdc1 appears to be part of a raid array:
level=raid5 devices=8 ctime=Mon Jun 18 19:20:37 2012
mdadm: /dev/sdd1 appears to be part of a raid array:
mdadm: /dev/sde1 appears to be part of a raid array:
mdadm: /dev/sdf1 appears to be part of a raid array:
mdadm: partition table exists on /dev/sdf1 but will be lost or
meaningless after creating array
mdadm: /dev/sdg1 appears to be part of a raid array:
mdadm: /dev/sdh1 appears to contain an ext2fs file system
size=1863368260K mtime=Sun Feb 26 11:52:06 2012
mdadm: /dev/sdh1 appears to be part of a raid array:
mdadm: partition table exists on /dev/sdh1 but will be lost or
mdadm: /dev/sdi1 appears to be part of a raid array:
mdadm: size set to 1953510400K
Continue creating array? y
mdadm: Defaulting to version 1.2 metadata
mdadm: array /dev/md5 started.
medusa ~ # mount /mnt/raid2/
Screen output
Disk /dev/md5 - 14 TB / 12 TiB - CHS 3418643200 2 4
The harddisk (14 TB / 12 TiB) seems too small! (< 14 TB / 12 TiB)
ext4 28743 1 2 3418674631 1 1 27349167104
ext4 1602567 1 2 3420248455 1 1 27349167104
> ext4 2651143 1 2 3421297031 1 1 27349167104
Log output
Tue Jun 19 08:57:06 2012
OS: Linux, kernel 3.0.6-gentoo (#3 SMP PREEMPT Sat Nov 5 22:28:43 PDT 2011) x86_64
Compiler: GCC 4.4
Compilation date: 2011-11-15T02:42:19
ext2fs lib: 1.41.9, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20100226
/dev/sda: size 117210240 sectors
/dev/sda: user_max 117210240 sectors
/dev/sda: native_max 117210240 sectors
/dev/sda: dco 117210240 sectors
/dev/sdb: size 117210240 sectors
/dev/sdb: user_max 117210240 sectors
/dev/sdb: native_max 117210240 sectors
/dev/sdb: dco 117210240 sectors
/dev/sdc: LBA, HPA, LBA48, DCO support
/dev/sdc: size 3907029168 sectors
/dev/sdc: user_max 3907029168 sectors
/dev/sdc: native_max 3907029168 sectors
/dev/sdc: dco 3907029168 sectors
/dev/sdd: LBA, HPA, LBA48, DCO support
/dev/sdd: size 3907029168 sectors
/dev/sdd: user_max 3907029168 sectors
/dev/sdd: native_max 3907029168 sectors
/dev/sdd: dco 3907029168 sectors
/dev/sde: LBA, HPA, LBA48, DCO support
/dev/sde: size 3907029168 sectors
/dev/sde: user_max 3907029168 sectors
/dev/sde: native_max 3907029168 sectors
/dev/sde: dco 3907029168 sectors
/dev/sdf: LBA, HPA, LBA48, DCO support
/dev/sdf: size 3907029168 sectors
/dev/sdf: user_max 3907029168 sectors
/dev/sdf: native_max 3907029168 sectors
/dev/sdf: dco 3907029168 sectors
/dev/sdg: LBA, HPA, LBA48, DCO support
/dev/sdg: size 3907029168 sectors
/dev/sdg: user_max 3907029168 sectors
/dev/sdg: native_max 3907029168 sectors
/dev/sdg: dco 3907029168 sectors
/dev/sdh: LBA, HPA, LBA48, DCO support
/dev/sdh: size 3907029168 sectors
/dev/sdh: user_max 3907029168 sectors
/dev/sdh: native_max 3907029168 sectors
/dev/sdh: dco 3907029168 sectors
/dev/sdi: LBA, HPA, LBA48, DCO support
/dev/sdi: size 3907029168 sectors
/dev/sdi: user_max 3907029168 sectors
/dev/sdi: native_max 3907029168 sectors
/dev/sdi: dco 3907029168 sectors
/dev/sdj: LBA, HPA, LBA48, DCO support
/dev/sdj: size 3907029168 sectors
/dev/sdj: user_max 3907029168 sectors
/dev/sdj: native_max 3907029168 sectors
/dev/sdj: dco 3907029168 sectors
/dev/sdk: LBA, HPA, LBA48, DCO support
/dev/sdk: size 3907029168 sectors
/dev/sdk: user_max 3907029168 sectors
/dev/sdk: native_max 3907029168 sectors
/dev/sdk: dco 3907029168 sectors
/dev/sdl: LBA, HPA, LBA48, DCO support
/dev/sdl: size 3907029168 sectors
/dev/sdl: user_max 3907029168 sectors
/dev/sdl: native_max 3907029168 sectors
/dev/sdl: dco 3907029168 sectors
/dev/sdm: LBA, HPA, LBA48, DCO support
/dev/sdm: size 3907029168 sectors
/dev/sdm: user_max 3907029168 sectors
/dev/sdm: native_max 3907029168 sectors
/dev/sdm: dco 3907029168 sectors
/dev/sdn: LBA, HPA, LBA48, DCO support
/dev/sdn: size 3907029168 sectors
/dev/sdn: user_max 3907029168 sectors
/dev/sdn: native_max 3907029168 sectors
/dev/sdn: dco 3907029168 sectors
/dev/sdo: LBA, HPA, LBA48, DCO support
/dev/sdo: size 3907029168 sectors
/dev/sdo: user_max 3907029168 sectors
/dev/sdo: native_max 3907029168 sectors
/dev/sdo: dco 3907029168 sectors
/dev/sdp: LBA, HPA, LBA48 support
/dev/sdp: size 3907029168 sectors
/dev/sdp: user_max 3907029168 sectors
/dev/sdp: native_max 3907029168 sectors
/dev/sdq: LBA, HPA, LBA48, DCO support
/dev/sdq: size 3907029168 sectors
/dev/sdq: user_max 3907029168 sectors
/dev/sdq: native_max 3907029168 sectors
/dev/sdq: dco 3907029168 sectors
/dev/sdr: LBA, HPA, LBA48, DCO support
/dev/sdr: size 3907029168 sectors
/dev/sdr: user_max 3907029168 sectors
/dev/sdr: native_max 3907029168 sectors
/dev/sdr: dco 3907029168 sectors
Disk /dev/sda - 60 GB / 55 GiB - CHS 7296 255 63, sector size=512 - TOSHIBA MK6037GSX, S/N:674MT0A4T, FW:DL330G
Disk /dev/sdb - 60 GB / 55 GiB - CHS 7296 255 63, sector size=512 - TOSHIBA MK6037GSX, S/N:674MT0A5T, FW:DL330G
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EADS-00R6B0, S/N:WD-WCAVY1357327, FW:01.00A01
Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EADS-00R6B0, S/N:WD-WCAVY1333756, FW:01.00A01
Disk /dev/sde - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EARX-00PASB0, S/N:WD-WMAZA6953333, FW:51.0AB51
Disk /dev/sdf - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EADS-22R6B0, S/N:WD-WCAVY5208359, FW:01.00A01
Disk /dev/sdg - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EADS-22R6B0, S/N:WD-WCAVY5187468, FW:01.00A01
Disk /dev/sdh - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EADS-00R6B0, S/N:WD-WCAVY5447218, FW:01.00A01
Disk /dev/sdi - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EADS-00S2B0, S/N:WD-WCAVY5376419, FW:01.00A01
Disk /dev/sdj - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EADS-00S2B0, S/N:WD-WCAVY4671438, FW:01.00A01
Disk /dev/sdk - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EARX-00PASB0, S/N:WD-WMAZA6949978, FW:51.0AB51
Disk /dev/sdl - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EADS-00R6B0, S/N:WD-WCAVY1067600, FW:01.00A01
Disk /dev/sdm - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EARX-00PASB0, S/N:WD-WMAZA6948967, FW:51.0AB51
Disk /dev/sdn - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EADS-00R6B0, S/N:WD-WCAVY1358850, FW:01.00A01
Disk /dev/sdo - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EADS-00S2B0, S/N:WD-WCAVY1316914, FW:01.00A01
Disk /dev/sdp - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EADS-00W4B0, S/N:WD-WCAVY4624704, FW:01.00A01
Disk /dev/sdq - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EARX-00PASB0, S/N:WD-WMAZA6836631, FW:51.0AB51
Disk /dev/sdr - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EARX-00PASB0, S/N:WD-WCAZAD171957, FW:51.0AB51
Disk /dev/md1 - 41 MB / 39 MiB - CHS 10016 2 4, sector size=512
Disk /dev/md2 - 12 GB / 11 GiB - CHS 2931840 2 4, sector size=512
Disk /dev/md3 - 47 GB / 44 GiB - CHS 11709360 2 4, sector size=512
Disk /dev/md4 - 14 TB / 12 TiB - CHS 3418645888 2 4, sector size=512
Disk /dev/md5 - 14 TB / 12 TiB - CHS 3418643200 2 4, sector size=512
Partition table type: None
New options :
Dump : No
Cylinder boundary : Yes
Expert mode : Yes
Analyse Disk /dev/md5 - 14 TB / 12 TiB - CHS 3418643200 2 4
recover_EXT2: s_block_group_nr=0/104328, s_mnt_count=3/21, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 3418643200
recover_EXT2: part_size 1579341824
P ext4 0 0 1 3418643199 1 4 27349145600
EXT4 Sparse superblock Recover, 14 TB / 12 TiB
Write isn't available because the partition table type "None" has been selected.
recover_EXT2: s_block_group_nr=0/104328, s_mnt_count=10/30, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 3418645888
recover_EXT2: part_size 1579363328
EXT4 Large file Sparse superblock Recover, 14 TB / 12 TiB
This partition ends after the disk limits. (start=229949, size=1579363328, end=1579593276, disk end=1579341824)
block_group_nr 1
recover_EXT2: part_offset problem
block_group_nr 1
recover_EXT2: s_block_group_nr=1/104328, s_mnt_count=0/21, s_blocks_per_group=32768, s_inodes_per_group=8192
EXT4 Sparse superblock Backup superblock, 14 TB / 12 TiB
block_group_nr 3
block_group_nr 3
recover_EXT2: s_block_group_nr=3/104328, s_mnt_count=0/21, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 5
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/104328, s_mnt_count=0/21, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 7
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/104328, s_mnt_count=0/21, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 9
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/104328, s_mnt_count=0/21, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 25
block_group_nr 25
recover_EXT2: s_block_group_nr=25/104328, s_mnt_count=0/21, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 27
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/104328, s_mnt_count=0/21, s_blocks_per_group=32768, s_inodes_per_group=8192
This partition ends after the disk limits. (start=12820541, size=1579363328, end=1592183868, disk end=1579341824)
block_group_nr 49
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/104328, s_mnt_count=0/21, s_blocks_per_group=32768, s_inodes_per_group=8192
This partition ends after the disk limits. (start=21209149, size=1579363328, end=1600572476, disk end=1579341824)
block_group_nr 81
block_group_nr 81
recover_EXT2: "e2fsck -b 2654208 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=81/104328, s_mnt_count=0/21, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 125
block_group_nr 125
recover_EXT2: "e2fsck -b 4096000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=125/104328, s_mnt_count=0/21, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 243
block_group_nr 243
recover_EXT2: "e2fsck -b 7962624 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=243/104328, s_mnt_count=0/21, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 343
block_group_nr 343
recover_EXT2: "e2fsck -b 11239424 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=343/104328, s_mnt_count=0/21, s_blocks_per_group=32768, s_inodes_per_group=8192
Unable to force disk geometry past 8TB for recovery
Re: Unable to force disk geometry past 8TB for recovery
Would it be possible to use the version 6.14 to have another try?
So a little more progress. The latest test version of the program does allow me to change the cylinders to be > 8 TiB. I ran a deeper scan again and it came back with the same partitions as before. When I try to list files in it I get:
P ext4 28743 1 2 3418674631 1 1 27349167104
No file found, filesystem may be damaged.
I've selected NONE for the partition type so I can't write the old partition table to the disk. This is a PC running Linux. I formatted originally with the EXT4 file system. Should I choose a different partition type, try to reload the partition table and do a file system repair of some sort?
Some more information. I think I may have created the RAID array right on top of the underlying partitioned drives. So I don't think there is a "partition" per se on my /dev/md5 device.
Have I totally messed myself up?
Hopefully that you created your RAID exactly like before.I think I may have created the RAID array right on top of the underlying partitioned drives. So I don't think there is a "partition" per se on my /dev/md5 device.Have I totally messed myself up?
Your disks must be in sequential order and you stripe size must fit also.
8 TB must be a GPT disk.
It's a lot better not to write anything to your disk.
If TestDisk doesn't find a partition (to write it to tha GUID partition table) then it might be possible to create an empty partition exactly like before (infos will follow).
Don't format your partition or disk, you'd override your previous file system.
On this partition you could have a superblock diagnose.
Some infos about;
http://www.cgsecurity.org/wiki/Advanced ... SuperBlock
Ext4 has the same procedure like ext2/3 (asked our Linux tech savvy).
I'm sure I recreated the RAID correctly. I had tried using the foremost tool and I was able to at least recover some files, however with the foremost tool most of the files are corrupt, it only recovers certain files that it knows the signature for and there are no file names.
What I'm afraid of is that when I tried to repair the file system on my own, I ran mkfs.ext4 -S on top of the array because it was complaining about the size of the old file system being incorrect.
I followed the link you provided about restoring a superblock. How can I restore a super block from the old filesystem? I created a new ext4 on top of the old array, hoping that would allow me to undelete files, but that wasn't the case.
My ideal case I guess would be somehow restore the old file system super blocks but I don't know how to do that.
Any suggestions on how to restore a super block from partition that is found via a deep scan? Restoring the super blocks from the current partition won't help.
If you'd like to diagnose a superblock from a partition found during Deeper Search, you have to write it first to your GUID partition table in TestDisk using the menu Write.
Then your partition would be available to use the menu Advanced to have a boot sector diagnose.
If you have the values from a screen, you can stop Quick Search and press a to add this partition.
GPT is always primary.
