PhotoRec how to select DNG files only
awalker
#1 Post by awalker »
Hey all really dumb question but im trying to recover .dng files only but cannot find in the options where you can select it, i have found the list of all the types where u can select and deselect items but dng is not listed in there
Please help
Cheers
Andrew
Re: PhotoRec how to select DNG files only
If your file type is not available and PhotoRec didn't find it, you can ask/suggest it to the developer;
http://www.cgsecurity.org/wiki/PhotoRec#Problems_.3F at Problems.
Also you can have a try to add your custom signatur;
http://www.cgsecurity.org/wiki/Add_your ... o_PhotoRec
awalker
#3 Post by awalker »
Hi Fiona
.dng files are listed as supported on the main page for photorec there just doesnt seem to be an option in photorec for it im guessing its grouped together with another file format like the raw picture files i was just wondering if some one knew which one
Cheers
#4 Post by Fiona »
Probably it belongs to a file family?
Did you test PhotoRec 6.14-32bit?
awalker
#5 Post by awalker »
Yeah I did test 6.14 but still didn't have the option so it must be in one of the family's just cant work out which one
maxH
#6 Post by maxH »
Did you ever resolve this issue? I'm dealing with the same question. I've also been seeing .dng files appear and then suddenly disappear in the recovery directory...did you ever notice that behavior?
Thanks.
#7 Post by cgrenier »
dng are in the TIFF file family.
If you have the problem of appearing and disappearing dng file in recup_dir.*, try using the latest 6.14-WIP version and if the problem persists, please send me some unmodified dng file taken with your camera.
