Segmentation fault on Rebuild BS
armifer
#1 Post by armifer »
Hi ppl! How are you?
This is my first post and first I wanted to thank you for all the effort you make.
Thanks to testdisk, I have fixed several old hard drives, which were in RAW format.
This time I have a Hitachi 500gb hard drive that is failing on "Rebuild BS" with an uncontrolled exception. In addition, it is always the same sector.
I'm running testdisk on ubuntu desktop liveCD.
I leave a catch of error so that you see the case:
Screenshot from 2017-08-23 16-37-23.png (27.38 KiB) Viewed 4105 times
The log is as follows:
Wed Aug 23 16:27:14 2017
OS: Linux, kernel 4.10.0-28-generic (#32~16.04.2-Ubuntu SMP Thu Jul 20 10:19:48 UTC 2017) x86_64
Compiler: GCC 5.3
ext2fs lib: 1.42.13, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.0
/dev/sda: size       488397168 sectors
/dev/sda: user_max   488397168 sectors
/dev/sda: native_max 488397168 sectors
/dev/sdb: LBA, LBA48, DCO support
/dev/sdb: size       976773168 sectors
/dev/sdb: user_max   976773168 sectors
/dev/sdb: dco        976773168 sectors
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung SSD 850 EVO 250GB, S/N:S2R6NB0J311770Z, FW:EMT02B6Q
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Hitachi HDT725050VLA360, S/N:VFK401R427P10K, FW:V56OA7BA
Disk /dev/sdd - 32 GB / 29 GiB - CHS 30544 64 32, sector size=512, FW:PMAP
Disk /dev/sdb - 500 GB / 465 GiB - Hitachi HDT725050VLA360
NTFS at 0/1/1
NTFS at 59498/0/1
Info: size boot_sector 20932694, partition 20932695
 1 * HPFS - NTFS              0   1  1 59497 254 63  955835307
     NTFS, blocksize=4096, 489 GB / 455 GiB
 2 P HPFS - NTFS          59498   0  1 60800 254 63   20932695
     NTFS, blocksize=4096, 10717 MB / 10221 MiB
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
filesystem size           955835307
sectors_per_cluster       8
mftmirr_lcn               6555520
clusters_per_mft_record   -10
Status: OK
Status: OK
Sectors are identical.
ntfs_mst_post_read_fixup_warn: magic: 0x00a80000  size: 1024   usa_ofs: 0  usa_count: 7: Invalid argument
Record 0 has no FILE magic (0xa80000)
Not an exFAT boot sector.
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
mftmirr_lcn               6555520
Status: OK
Status: OK
Do you have any idea?
Thank you very much in advance.
Re: Segmentation fault on Rebuild BS
Can you try with latest testdisk 7.1-WIP ?
If you have difficulties to install it, read https://www.cgsecurity.org/testdisk.pdf
armifer
#3 Post by armifer »
I've same problem,
attach log
Wed Aug 23 16:13:18 2017
TestDisk 7.1-WIP, Data Recovery Utility, July 2017
OS: Windows 8 (9200)
Compiler: GCC 5.4, Cygwin 2005.2
filewin32_getfilesize(\\.\PhysicalDrive2) GetFileSize err Funci�n incorrecta.
filewin32_setfilepointer(\\.\PhysicalDrive2) SetFilePointer err Funci�n incorrecta.
filewin32_getfilesize(\\.\PhysicalDrive3) GetFileSize err Funci�n incorrecta.
filewin32_setfilepointer(\\.\PhysicalDrive3) SetFilePointer err Funci�n incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249465667584
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=489387677184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=10717539840
NTFS at 0/1/1
NTFS at 59498/0/1
 2 P HPFS - NTFS          59498   0  1 60800 254 63   20932695 [FACTORY_IMAGE]
$MFT has invalid magic.
ntfs_mft_load(): Failed.
NTFS at 0/1/1
mftmirr_lcn               6555520
NTFS at 59498/0/1
filesystem size           20932694
mft_lcn                   170152
mftmirr_lcn               255229
     HPFS - NTFS          59498   0  1 60800 254 62   20932694 [FACTORY_IMAGE]
NTFS at 60800/254/63
mft_lcn                   170152
mftmirr_lcn               255229
     HPFS - NTFS          59498   0  2 60800 254 63   20932694
     NTFS found using backup sector, blocksize=4096, 10717 MB / 10221 MiB
mft_lcn                   170152
mftmirr_lcn               255229
file_pread(5,2,buffer,978129286(60885/186/44)) lseek err Invalid argument
file_pread(5,1,buffer,978129286(60885/186/44)) lseek err Invalid argument
NTFS: Can't read MFT
     HPFS - NTFS          60800 254 63 62103 254 61   20932694
This partition ends after the disk limits. (start=976768064, size=20932694, end=997700757, disk end=976773168)
file_pread(5,3,buffer,976773182(60801/81/15)) lseek err Invalid argument
file_pread(5,1,buffer,976773182(60801/81/15)) lseek err Invalid argument
file_pread(5,8,buffer,976773198(60801/81/31)) lseek err Invalid argument
file_pread(5,11,buffer,976773245(60801/82/15)) lseek err Invalid argument
file_pread(5,2,buffer,976775167(60801/112/47)) lseek err Invalid argument
file_pread(5,1,buffer,976773206(60801/81/39)) lseek err Invalid argument
file_pread(5,1,buffer,976773256(60801/82/26)) lseek err Invalid argument
file_pread(5,1,buffer,976775169(60801/112/49)) lseek err Invalid argument
file_pread(5,8,buffer,976773226(60801/81/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773234(60801/82/4)) lseek err Invalid argument
file_pread(5,8,buffer,976773354(60801/83/61)) lseek err Invalid argument
file_pread(5,1,buffer,976773362(60801/84/6)) lseek err Invalid argument
file_pread(5,8,buffer,976773482(60801/85/63)) lseek err Invalid argument
file_pread(5,1,buffer,976773490(60801/86/8)) lseek err Invalid argument
file_pread(5,8,buffer,976773610(60801/88/2)) lseek err Invalid argument
file_pread(5,1,buffer,976773618(60801/88/10)) lseek err Invalid argument
file_pread(5,8,buffer,976773738(60801/90/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773746(60801/90/12)) lseek err Invalid argument
file_pread(5,8,buffer,976773866(60801/92/6)) lseek err Invalid argument
file_pread(5,1,buffer,976773874(60801/92/14)) lseek err Invalid argument
file_pread(5,8,buffer,976773994(60801/94/8)) lseek err Invalid argument
file_pread(5,1,buffer,976774002(60801/94/16)) lseek err Invalid argument
file_pread(5,8,buffer,976774122(60801/96/10)) lseek err Invalid argument
file_pread(5,1,buffer,976774130(60801/96/18)) lseek err Invalid argument
file_pread(5,8,buffer,976774250(60801/98/12)) lseek err Invalid argument
file_pread(5,1,buffer,976774258(60801/98/20)) lseek err Invalid argument
file_pread(5,8,buffer,976774378(60801/100/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774386(60801/100/22)) lseek err Invalid argument
file_pread(5,8,buffer,976774506(60801/102/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774514(60801/102/24)) lseek err Invalid argument
file_pread(5,8,buffer,976774634(60801/104/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774642(60801/104/26)) lseek err Invalid argument
file_pread(5,8,buffer,976774762(60801/106/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774770(60801/106/28)) lseek err Invalid argument
file_pread(5,8,buffer,976774890(60801/108/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774898(60801/108/30)) lseek err Invalid argument
file_pread(5,8,buffer,976775018(60801/110/24)) lseek err Invalid argument
file_pread(5,1,buffer,976775026(60801/110/32)) lseek err Invalid argument
file_pread(5,8,buffer,976775146(60801/112/26)) lseek err Invalid argument
file_pread(5,1,buffer,976775154(60801/112/34)) lseek err Invalid argument
file_pread(5,2,buffer,976775168(60801/112/48)) lseek err Invalid argument
file_pread(5,14,buffer,976775170(60801/112/50)) lseek err Invalid argument
file_pread(5,3,buffer,976775184(60801/113/1)) lseek err Invalid argument
file_pread(5,3,buffer,976775231(60801/113/48)) lseek err Invalid argument
file_pread(5,8,buffer,976775247(60801/114/1)) lseek err Invalid argument
file_pread(5,11,buffer,976775294(60801/114/48)) lseek err Invalid argument
file_pread(5,2,buffer,976777216(60801/145/17)) lseek err Invalid argument
The harddisk (500 GB / 465 GiB) seems too small! (< 510 GB / 475 GiB)
NTFS at 0/1/1
NTFS at 59498/0/1
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
mftmirr_lcn               6555520
Status: OK
Status: OK
repair_MFT
NTFS at 0/1/1
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
mftmirr_lcn               6555520
Status: OK
Status: OK
      2 [main] testdisk_win 1708 cygwin_exception::open_stackdumpfile: Dumping stack trace to testdisk_win.exe.stackdump
armifer
#4 Post by armifer »
Any idea?
Thx
