Accidently run diskpart and cleaned my external HDD
gufigueiredo
#1 Post by gufigueiredo »
Hi everyone,
Hope someone can help me.
I accidently run diskpart on my external HDD 1.5TB drive, witch is my backup drive.
Here is the steps I have followed:
1) selected disk 3 (my external HDD)
2) run the command clean
3) run the command create partition primary
4) started format fs=fat32
5) when I realized I was formatting the wrong disk I pressed ctrl + c and abort the operation (after only couples of seconds, 0%)
Now, my disk is on a RAW format and windows didn't recognize my hdd.
I've tried run testdisk analyze with quick search and found a HPFS-NTFS partition, but I receive the following message:
The following partition can't be recovered
Then I hit continue and when I try to list files under the NTFS partition, testdisk give me the meesage: Can't open filesystem. Filesystem seems damaged
Here are is some screenshots:
If anyone can help me I will be very grateful, as I have a backup on this disk since 2009
Re: Accidently run diskpart and cleaned my external HDD
Go in Advanced, Type, force the type to 7 (NTFS), Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit
If it doesn't work, in the Advanced menu, press the key 'a' and add a partition starting at 0 1 1 (cylinder=0 head=1 sector=1), set the partition type to 7 (NTFS) and try Boot, RebuildBS, List. If it works, Write, confirm, Quit
What are the results ?
gufigueiredo
#3 Post by gufigueiredo »
First step give me the following message when I try to list files (run RebuildBS for two days):
The second step don't create the NTFS partition. I choose 0 0 1, 07 - NTFS, [y], but partition doesn't change.
Here are some screenshots: (I cannot attach log file because it's around 1GB)
Any advices at this point?
gufigueiredo
#4 Post by gufigueiredo »
Anyone can help me?
