Attempting to recover ntfs partition from san storage
shce11
#1 Post by shce11 »
Do I have to wait for the analyze to complete before I attempt to recover my ntfs partition ? I see my ntfs partition. This is taking quite a while. 35% in 24 hrs. It's been hanging on this screen for quite some time.
Re: Attempting to recover ntfs partition from san storage
If you see your partition, choose Stop, no need to wait.
On next screen, check that the partitions you want to keep/recover are listed as *(bootable), P(rimary) or L(ogical) (Us ethe arrow keys to switch from Deleted if necessary)
When done, choose Write, confirm, Quit and restart your computer.
shce11
#3 Post by shce11 »
Actually, I thought I seen the partition I needed. I let it run a little more while. Then it came up with the one labeled [Docs-3Par] I think the one below it is the one I want to recover. I will press on the side of caution and let it run all the way through. It's san storage, no telling what's on there. I tried to sop it before. I didn't see option to stop. I just hit enter. I don't remember seeing any options to recover. If you look at the screenshot I posted, you see there is no "Stop" option to be highlighted. I had to start this whole process over. It's all blank when I scroll down.
