TestDisk "Write Error"
ccotton
#1 Post by ccotton »
Recently I had a 1.5TB USB 3.0 disk "go bad." It had become a "RAW" disk. I tried TestDisk and it successfully wrote the partition and, after the reboot and chkdsk run, my disk and all of my data was recovered. Great experience!
Now, I've had the same thing happen to another disk, also a 1.5TB USB 3.0 external disk. This time, however, the Write option fails with "Write Error"
Here is the log file:
--> START
Mon Oct 23 08:24:41 2017
TestDisk 7.1-WIP, Data Recovery Utility, July 2017
Compiler: GCC 5.4, Cygwin 2005.2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=322122547200
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=300647710720
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=322122547200
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\P:)=1500299395072
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000LM014-1EJ164, S/N:202020202020202020202020335731384a573047, FW:SM16
Disk /dev/sde - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512 - TOSHIBA MQ01ABC150, S/N:2020202020202020202059204f32504c51365430, FW:AQF01U
Disk /dev/sde - 1500 GB / 1397 GiB - TOSHIBA MQ01ABC150
Analyse Disk /dev/sde - 1500 GB / 1397 GiB - CHS 182401 255 63
NTFS at 0/32/33
1 P HPFS - NTFS 0 32 33 182401 35 34 2930272256 [Sony USB]
NTFS at 0/32/33
filesystem size 2930272256
mftmirr_lcn 2
NTFS, blocksize=4096, 1500 GB / 1397 GiB
file_pread(5,2,buffer,2930278399(182401/100/35)) lseek err Invalid argument
file_pread(5,1,buffer,2930278399(182401/100/35)) lseek err Invalid argument
file_pread(5,2,buffer,2930278400(182401/100/36)) lseek err Invalid argument
file_pread(5,8,buffer,2930277248(182401/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,2930277248(182401/82/18)) lseek err Invalid argument
file_pread(5,8,buffer,2930277376(182401/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,2930277504(182401/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,2930277632(182401/88/24)) lseek err Invalid argument
file_pread(5,8,buffer,2930277760(182401/90/26)) lseek err Invalid argument
file_pread(5,8,buffer,2930277888(182401/92/28)) lseek err Invalid argument
file_pread(5,8,buffer,2930278016(182401/94/30)) lseek err Invalid argument
file_pread(5,8,buffer,2930278144(182401/96/32)) lseek err Invalid argument
file_pread(5,8,buffer,2930278272(182401/98/34)) lseek err Invalid argument
file_pread(5,6,buffer,2930278402(182401/100/38)) lseek err Invalid argument
file_pread(5,8,buffer,2930278408(182401/100/44)) lseek err Invalid argument
file_pread(5,3,buffer,2930278416(182401/100/52)) lseek err Invalid argument
file_pread(5,3,buffer,2930278463(182401/101/36)) lseek err Invalid argument
file_pread(5,8,buffer,2930278479(182401/101/52)) lseek err Invalid argument
file_pread(5,11,buffer,2930278526(182401/102/36)) lseek err Invalid argument
file_pread(5,2,buffer,2930280448(182401/133/5)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 182401 35 34 2930272256 [Sony USB]
1 * HPFS - NTFS 0 32 33 182401 35 34 2930272256 [Sony USB]
write!
file_pwrite(5,1,buffer,0(0/0/1)) write err Input/output error
Partition: Write error
--> END
Any ideas?
Thank you for any help you can offer.
Charles.
Re: TestDisk "Write Error"
Can you try TestDisk, Advanced, Boot, RebuildBS, List ? If you can see your files, choose Write, confirm, Quit and restart your computer.
Please post the new log file if it doesn't work.
