Seagate backup drive not working.
NovianM
#1 Post by NovianM »
My K drive where i store most of my digital Media started becoming unaccessible after a few days of me not using it. I looked for tools to try and recover the data since windows simply wan't to format I decided to look in to recovery options. I tried Recuva from piriform and although it said it scanned a large number of files it said nothing was on the drive which lead me to Testdisk by a friend's recommendation.
I am dealing with a 4TB Seagate backup drive and it only had one main partition. I believe it was NTFS format. My main worry is that In Test disk the disk appears twice. The disk Dev sdc says its in intel partition table and drive K says its in none partition table. if I hit the P key on either of them they both seem to list all the files. i am just trying to figure out how to get the drive navigatable again now.
What should my next steps be? Worst possible solution would be to get a new drive and write the files to a new drive but screenshot feel like this should be recoverable.Is the duplicate listing the problem. Please send what ever support you can my way.
Try to enjoy your Thanksgiving if you celebrate it too.
https://imgur.com/a/zUgLl
Re: Seagate backup drive not working.
Use /dev/sdc
You should read https://www.cgsecurity.org/testdisk.pdf
NovianM
#3 Post by NovianM »
I ran a chkdsk just to start and that seems to have dome some things. I then restarted and loaded up testdisk and followed the steps on page 20 in the pdf you linked me.
I am still not sure what the issue is since it says the boot sectors are okay and the back up is okay but it says a valid ntfs boot sector needs to be present still.
Here is my log and the latest screenshot.
Fri Nov 24 16:50:09 2017
TestDisk 7.1-WIP, Data Recovery Utility, October 2017
Compiler: GCC 5.4, Cygwin 2005.2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=1000203804160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=4000787025920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=2000398929920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1000203804160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=4000787025920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000398929920
filewin32_getfilesize(\\.\PhysicalDrive8) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\PhysicalDrive8) SetFilePointer err Incorrect function.
Warning: can't get size for \\.\PhysicalDrive8
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1000097185792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=423485441024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2000291889152
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=4000770424832
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\N:)=576715751424
Disk /dev/sda - 1000 GB / 931 GiB - CHS 459004 224 19, sector size=512 - ST1000DM003-1CH162, S/N:2020202020202020202020203153454431324b4e, FW:CC47
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST31000333AS, S/N:2020202020202020202020205439314533384554, FW:CC1F
Disk /dev/sdc - 4000 GB / 3726 GiB - CHS 60800 255 63, sector size=4096 - Seagate Backup+ Desk, S/N:NA5KV69S, FW:050B
Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Toshiba External USB 3.0, S/N:71573493, FW:0201
Disk \\.\PhysicalDrive2 - 4000 GB / 3726 GiB - CHS 60800 255 63, sector size=4096 - Seagate Backup+ Desk, S/N:NA5KV69S, FW:050B
Drive K: - 4000 GB / 3726 GiB - CHS 60799 255 63, sector size=4096 - Seagate Backup+ Desk, S/N:NA5KV69S, FW:050B
Disk /dev/sdc - 4000 GB / 3726 GiB - Seagate Backup+ Desk
NTFS at 0/32/33
 1 * HPFS - NTFS              0  32 33 60800  10 10  976750592 [Seagate Backup Plus Drive]
     NTFS, blocksize=4096, 4000 GB / 3726 GiB
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
filesystem size           976750592
sectors_per_cluster       1
mftmirr_lcn               2
clusters_per_mft_record   1
Status: OK
Status: OK
Sectors are identical.
rebuild_NTFS_BS
mft at 2
read_mft_info failed
ntfs_find_mft: sectors_per_cluster invalid
ntfs_find_mft: mft_lcn             786432
ntfs_find_mft: mftmirr_lcn         0
ntfs_find_mft: mft_record_size     4096
mft at 786432
ntfs_find_mft: sectors_per_cluster 1
ntfs_find_mft: mft_record_size     4096 bytes
ntfs_find_mft: index_block_size    4096
             New / Current boot sector
filesystem size           976750592 976750592
sectors_per_cluster       1 1
mft_lcn                   786432 786432
mftmirr_lcn               0 2
clusters_per_mft_record   1 1
clusters_per_index_record 1 1
mftmirr_lcn               0 2
Write new boot!
file_pwrite(6,1,buffer,976752639(60800/10/10)) write err Permission denied
Write error: Can't write new NTFS backup boot sector
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn               0 2
Status: OK
Status: OK
Sectors are not identical.
NovianM
#4 Post by NovianM »
UPDATE after a few more restarts and updating windows the drive appears to be functioning.
Thank you very much for your help.
I am not sure what the issue was but now when i check in TESTDISK it says the boot sectors are not identical and its working.
