Help Please
CyberMonkey
Help Please
#1 Post by CyberMonkey »
I have a USB external drive. Today it could not be mounted on my Mac OS X system and on Windows 7 it says it "needs to be formatted" to be used.
I downloaded testDisk and was able to make an image of the contents of the drive, but it's a .dd file format. I downloaded an app for Mac called "The Unarchiver" that stated it opens .dd files.....but it does not. What should I use to be able to access the .dd file that TestDisk created?
Re: Help Please
That image is only intended to work using TestDisk.
A description would be here;
http://www.cgsecurity.org/wiki/Media_Image
Some Infos about dd ;
CyberMonkey
Re: Help Please
#3 Post by CyberMonkey »
Ok thanks.
If the .dd file is only to be intended to work with TestDisk, that just means I will have to copy the files/folders using that copy function in TestDisk.
Re: Help Please
#4 Post by Fiona »
Yes, it's a good idea to copy/backup data if they are listed!
