Hi everybody,
I am kinda new to this whole data recovery stuff and therefore I would appreciate your help a lot. The drive in question is a brand new (1 month old) 4TB WD Black harddrive that had been partioned under Windows 10 (NTFS) and filled up with almost 2 TB data. It has been used with 4 other 4 TB WD Black Drives in an external Sharkoon Drive. No Raid or whatsoever. Upon starting up the drive a few days ago only 4 of the 5 drives showed up. Win10 Disk Management shows me the drive with the correct amount of space however it tells me the drive needs to be initialized. Of course I did not do that. Instead I tried several programs to save the data - however none could find anything.
I then stumbled upon Testdisk and ran a quick analysis. The result was - nothing. Testdisk could not find any partitions to recover. However upon start Testdisk says:
Trying alternate GPT
Bad GPT partition, invalid signature
Afterwards I did a Deep Scan. Again no paritions could be found. 1/3 of the logfile is posted furter down below as it exceeded the allowed Charakters (188681 Charakters). I already tried to salvage some data with Qphotorec - however it found absolutely no data to recover.
Ironically Crystal Disk shows a "good" status. The Western Digital LifeGuard Diagnostic Tool shows me that the SMART Status is a "PASS". However when I try to run a Quick Test I get an error.
Status Code = 06 (Failed servo and/or seek test element), Failure
Checkpoint = 09 (Unknown Test)
I would appreciate it a lot if you guys could tell me how bad the situation actually is and what I could do. If the drive has a hardware failure - is there a possibilty to make an image of the disk and build a new partition table on a new drive? I hope I gave every info needed. Thanks in advance for the time and help:
LOG FILE
Sat Dec 30 12:13:27 2017
TestDisk 7.1-WIP, Data Recovery Utility, November 2017
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=499529048064
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=4000650887168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=104857600
Disk /dev/sda - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - WDC WD40EZRZ-00GXCB0, S/N:WD-WCC7K6VSLC99, FW:80.00A80
Disk /dev/sdb - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - WDC WD4004FZWX-00GBGB0, S/N:NHGKZG6Y, FW:81.H0A81
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Samsung SSD 850 EVO 500GB, S/N:S2RBNX0H530913W, FW:EMT02B6Q
Partition table type defaults to EFI GPT
Disk /dev/sdb - 4000 GB / 3726 GiB - WDC WD4004FZWX-00GBGB0
Partition table type: EFI GPT
New options :
Dump : No
Align partition: Yes
Expert mode : No
Analyse Disk /dev/sdb - 4000 GB / 3726 GiB - CHS 486401 255 63
file_pread(5,2,buffer,3519070207(486401/86/21)) lseek err Invalid argument
file_pread(5,1,buffer,3519070207(486401/86/21)) lseek err Invalid argument
interface_load
New options :
Dump : No
Expert mode : Yes
New options :
Dump : No
Expert mode : Yes
file_pread(5,1,buffer,3519069872(486401/81/1)) ReadFile Das Laufwerk kann den angeforderten Sektor nicht finden.
file_pread(5,1,buffer,3519069873(486401/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,3519069874(486401/81/3)) lseek err Invalid argument
file_pread(5,1,buffer,3519069875(486401/81/4)) lseek err Invalid argument
file_pread(5,1,buffer,3519069876(486401/81/5)) lseek err Invalid argument
file_pread(5,1,buffer,3519069877(486401/81/6)) lseek err Invalid argument
file_pread(5,1,buffer,3519069878(486401/81/7)) lseek err Invalid argument
file_pread(5,1,buffer,3519069879(486401/81/8)) lseek err Invalid argument
file_pread(5,1,buffer,3519069880(486401/81/9)) lseek err Invalid argument
file_pread(5,1,buffer,3519069881(486401/81/10)) lseek err Invalid argument
file_pread(5,1,buffer,3519069882(486401/81/11)) lseek err Invalid argument
file_pread(5,1,buffer,3519069883(486401/81/12)) lseek err Invalid argument
file_pread(5,1,buffer,3519069884(486401/81/13)) lseek err Invalid argument
file_pread(5,1,buffer,3519069885(486401/81/14)) lseek err Invalid argument
file_pread(5,1,buffer,3519069886(486401/81/15)) lseek err Invalid argument
file_pread(5,1,buffer,3519069887(486401/81/16)) lseek err Invalid argument
file_pread(5,1,buffer,3519069888(486401/81/17)) lseek err Invalid argument
file_pread(5,1,buffer,3519069889(486401/81/18)) lseek err Invalid argument
file_pread(5,1,buffer,3519069890(486401/81/19)) lseek err Invalid argument
file_pread(5,1,buffer,3519069891(486401/81/20)) lseek err Invalid argument
file_pread(5,1,buffer,3519069892(486401/81/21)) lseek err Invalid argument
file_pread(5,1,buffer,3519069893(486401/81/22)) lseek err Invalid argument
file_pread(5,1,buffer,3519069894(486401/81/23)) lseek err Invalid argument
file_pread(5,1,buffer,3519069895(486401/81/24)) lseek err Invalid argument
file_pread(5,1,buffer,3519069896(486401/81/25)) lseek err Invalid argument
file_pread(5,1,buffer,3519069897(486401/81/26)) lseek err Invalid argument
file_pread(5,1,buffer,3519069898(486401/81/27)) lseek err Invalid argument
file_pread(5,1,buffer,3519069899(486401/81/28)) lseek err Invalid argument
file_pread(5,1,buffer,3519069900(486401/81/29)) lseek err Invalid argument
file_pread(5,1,buffer,3519069901(486401/81/30)) lseek err Invalid argument
file_pread(5,1,buffer,3519069902(486401/81/31)) lseek err Invalid argument
file_pread(5,1,buffer,3519069903(486401/81/32)) lseek err Invalid argument
file_pread(5,1,buffer,3519069904(486401/81/33)) lseek err Invalid argument
file_pread(5,1,buffer,3519069905(486401/81/34)) lseek err Invalid argument
file_pread(5,1,buffer,3519069906(486401/81/35)) lseek err Invalid argument
file_pread(5,1,buffer,3519069907(486401/81/36)) lseek err Invalid argument
file_pread(5,1,buffer,3519069908(486401/81/37)) lseek err Invalid argument
file_pread(5,1,buffer,3519069909(486401/81/38)) lseek err Invalid argument
file_pread(5,1,buffer,3519069910(486401/81/39)) lseek err Invalid argument
file_pread(5,1,buffer,3519069911(486401/81/40)) lseek err Invalid argument
file_pread(5,1,buffer,3519069912(486401/81/41)) lseek err Invalid argument
file_pread(5,1,buffer,3519069913(486401/81/42)) lseek err Invalid argument
file_pread(5,1,buffer,3519069914(486401/81/43)) lseek err Invalid argument
file_pread(5,1,buffer,3519069915(486401/81/44)) lseek err Invalid argument
file_pread(5,1,buffer,3519069916(486401/81/45)) lseek err Invalid argument
file_pread(5,1,buffer,3519069917(486401/81/46)) lseek err Invalid argument
file_pread(5,1,buffer,3519069918(486401/81/47)) lseek err Invalid argument
file_pread(5,1,buffer,3519069919(486401/81/48)) lseek err Invalid argument
file_pread(5,1,buffer,3519069920(486401/81/49)) lseek err Invalid argument
file_pread(5,1,buffer,3519069921(486401/81/50)) lseek err Invalid argument
file_pread(5,1,buffer,3519069922(486401/81/51)) lseek err Invalid argument
file_pread(5,1,buffer,3519069923(486401/81/52)) lseek err Invalid argument
file_pread(5,1,buffer,3519069924(486401/81/53)) lseek err Invalid argument
file_pread(5,1,buffer,3519069925(486401/81/54)) lseek err Invalid argument
file_pread(5,1,buffer,3519069926(486401/81/55)) lseek err Invalid argument
file_pread(5,1,buffer,3519069927(486401/81/56)) lseek err Invalid argument
IN ORDER TO KEEP WITHIN THE CHARACTER LIMIT I DELETED SOME INFO IN BETWEEN - THE ERRORS KEPT ON GOING CONTINUOUSLY TILL THE NEXT LINE
file_pread(5,1,buffer,3519071784(486401/111/23)) lseek err Invalid argument
file_pread(5,1,buffer,3519071785(486401/111/24)) lseek err Invalid argument
file_pread(5,1,buffer,3519071786(486401/111/25)) lseek err Invalid argument
file_pread(5,1,buffer,3519071787(486401/111/26)) lseek err Invalid argument
file_pread(5,1,buffer,3519071788(486401/111/27)) lseek err Invalid argument
file_pread(5,11,buffer,3519069866(486401/80/58)) ReadFile Das Laufwerk kann den angeforderten Sektor nicht finden.
file_pread(5,1,buffer,3519071789(486401/111/28)) lseek err Invalid argument
file_pread(5,5,buffer,3519069873(486401/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,3519071790(486401/111/29)) lseek err Invalid argument
file_pread(5,1,buffer,3519071791(486401/111/30)) lseek err Invalid argument
file_pread(5,1,buffer,3519071792(486401/111/31)) lseek err Invalid argument
file_pread(5,1,buffer,3519071793(486401/111/32)) lseek err Invalid argument
file_pread(5,1,buffer,3519071794(486401/111/33)) lseek err Invalid argument
file_pread(5,11,buffer,3519069872(486401/81/1)) ReadFile Das Laufwerk kann den angeforderten Sektor nicht finden.
file_pread(5,1,buffer,3519071795(486401/111/34)) lseek err Invalid argument
file_pread(5,1,buffer,3519071796(486401/111/35)) lseek err Invalid argument
file_pread(5,1,buffer,3519071797(486401/111/36)) lseek err Invalid argument
file_pread(5,1,buffer,3519071798(486401/111/37)) lseek err Invalid argument
file_pread(5,1,buffer,3519071799(486401/111/38)) lseek err Invalid argument
file_pread(5,1,buffer,3519071800(486401/111/39)) lseek err Invalid argument
file_pread(5,11,buffer,3519069878(486401/81/7)) lseek err Invalid argument
file_pread(5,1,buffer,3519071801(486401/111/40)) lseek err Invalid argument
file_pread(5,1,buffer,3519071802(486401/111/41)) lseek err Invalid argument
file_pread(5,1,buffer,3519071803(486401/111/42)) lseek err Invalid argument
file_pread(5,1,buffer,3519071804(486401/111/43)) lseek err Invalid argument
file_pread(5,1,buffer,3519071805(486401/111/44)) lseek err Invalid argument
file_pread(5,1,buffer,3519071806(486401/111/45)) lseek err Invalid argument
file_pread(5,11,buffer,3519069884(486401/81/13)) lseek err Invalid argument
file_pread(5,1,buffer,3519071807(486401/111/46)) lseek err Invalid argument
file_pread(5,1,buffer,3519071808(486401/111/47)) lseek err Invalid argument
file_pread(5,1,buffer,3519071809(486401/111/48)) lseek err Invalid argument
file_pread(5,1,buffer,3519071810(486401/111/49)) lseek err Invalid argument
file_pread(5,1,buffer,3519071811(486401/111/50)) lseek err Invalid argument
file_pread(5,1,buffer,3519071812(486401/111/51)) lseek err Invalid argument
file_pread(5,11,buffer,3519069890(486401/81/19)) lseek err Invalid argument
file_pread(5,1,buffer,3519071813(486401/111/52)) lseek err Invalid argument
file_pread(5,11,buffer,3519069891(486401/81/20)) lseek err Invalid argument
file_pread(5,1,buffer,3519071814(486401/111/53)) lseek err Invalid argument
file_pread(5,1,buffer,3519071815(486401/111/54)) lseek err Invalid argument
file_pread(5,1,buffer,3519071816(486401/111/55)) lseek err Invalid argument
file_pread(5,1,buffer,3519071817(486401/111/56)) lseek err Invalid argument
file_pread(5,1,buffer,3519071818(486401/111/57)) lseek err Invalid argument
file_pread(5,1,buffer,3519071819(486401/111/58)) lseek err Invalid argument
file_pread(5,11,buffer,3519069897(486401/81/26)) lseek err Invalid argument
file_pread(5,1,buffer,3519071820(486401/111/59)) lseek err Invalid argument
file_pread(5,1,buffer,3519071821(486401/111/60)) lseek err Invalid argument
file_pread(5,1,buffer,3519071822(486401/111/61)) lseek err Invalid argument
file_pread(5,1,buffer,3519071823(486401/111/62)) lseek err Invalid argument
file_pread(5,1,buffer,3519071824(486401/111/63)) lseek err Invalid argument
file_pread(5,1,buffer,3519071825(486401/112/1)) lseek err Invalid argument
file_pread(5,11,buffer,3519069903(486401/81/32)) lseek err Invalid argument
file_pread(5,1,buffer,3519071826(486401/112/2)) lseek err Invalid argument
file_pread(5,11,buffer,3519069904(486401/81/33)) lseek err Invalid argument
file_pread(5,1,buffer,3519071827(486401/112/3)) lseek err Invalid argument
file_pread(5,11,buffer,3519069905(486401/81/34)) lseek err Invalid argument
file_pread(5,1,buffer,3519071828(486401/112/4)) lseek err Invalid argument
file_pread(5,11,buffer,3519069906(486401/81/35)) lseek err Invalid argument
file_pread(5,1,buffer,3519071829(486401/112/5)) lseek err Invalid argument
file_pread(5,11,buffer,3519069907(486401/81/36)) lseek err Invalid argument
file_pread(5,1,buffer,3519071830(486401/112/6)) lseek err Invalid argument
file_pread(5,11,buffer,3519069908(486401/81/37)) lseek err Invalid argument
file_pread(5,1,buffer,3519071831(486401/112/7)) lseek err Invalid argument
file_pread(5,11,buffer,3519069909(486401/81/38)) lseek err Invalid argument
file_pread(5,1,buffer,3519071832(486401/112/8)) lseek err Invalid argument
file_pread(5,11,buffer,3519069910(486401/81/39)) lseek err Invalid argument
file_pread(5,1,buffer,3519071833(486401/112/9)) lseek err Invalid argument
file_pread(5,11,buffer,3519069911(486401/81/40)) lseek err Invalid argument
file_pread(5,1,buffer,3519071834(486401/112/10)) lseek err Invalid argument
file_pread(5,11,buffer,3519069912(486401/81/41)) lseek err Invalid argument
file_pread(5,1,buffer,3519071835(486401/112/11)) lseek err Invalid argument
file_pread(5,1,buffer,3519071836(486401/112/12)) lseek err Invalid argument
file_pread(5,1,buffer,3519071837(486401/112/13)) lseek err Invalid argument
file_pread(5,1,buffer,3519071838(486401/112/14)) lseek err Invalid argument
file_pread(5,8,buffer,3519069869(486401/80/61)) ReadFile Das Laufwerk kann den angeforderten Sektor nicht finden.
file_pread(5,11,buffer,3519069916(486401/81/45)) lseek err Invalid argument
file_pread(5,1,buffer,3519071839(486401/112/15)) lseek err Invalid argument
file_pread(5,1,buffer,3519071840(486401/112/16)) lseek err Invalid argument
file_pread(5,1,buffer,3519069928(486401/81/57)) lseek err Invalid argument
file_pread(5,1,buffer,3519071841(486401/112/17)) lseek err Invalid argument
file_pread(5,1,buffer,3519069929(486401/81/58)) lseek err Invalid argument
file_pread(5,1,buffer,3519071842(486401/112/18)) lseek err Invalid argument
file_pread(5,1,buffer,3519069930(486401/81/59)) lseek err Invalid argument
file_pread(5,1,buffer,3519071843(486401/112/19)) lseek err Invalid argument
file_pread(5,8,buffer,3519069874(486401/81/3)) lseek err Invalid argument
file_pread(5,11,buffer,3519069921(486401/81/50)) lseek err Invalid argument
file_pread(5,1,buffer,3519071844(486401/112/20)) lseek err Invalid argument
file_pread(5,8,buffer,3519069875(486401/81/4)) lseek err Invalid argument
file_pread(5,1,buffer,3519069932(486401/81/61)) lseek err Invalid argument
file_pread(5,1,buffer,3519071845(486401/112/21)) lseek err Invalid argument
file_pread(5,8,buffer,3519069876(486401/81/5)) lseek err Invalid argument
file_pread(5,1,buffer,3519069933(486401/81/62)) lseek err Invalid argument
file_pread(5,1,buffer,3519071846(486401/112/22)) lseek err Invalid argument
file_pread(5,8,buffer,3519069877(486401/81/6)) lseek err Invalid argument
file_pread(5,11,buffer,3519069924(486401/81/53)) lseek err Invalid argument
file_pread(5,1,buffer,3519071847(486401/112/23)) lseek err Invalid argument
file_pread(5,8,buffer,3519069878(486401/81/7)) lseek err Invalid argument
file_pread(5,1,buffer,3519069935(486401/82/1)) lseek err Invalid argument
file_pread(5,1,buffer,3519071848(486401/112/24)) lseek err Invalid argument
file_pread(5,8,buffer,3519069879(486401/81/8)) lseek err Invalid argument
file_pread(5,1,buffer,3519069936(486401/82/2)) lseek err Invalid argument
file_pread(5,1,buffer,3519071849(486401/112/25)) lseek err Invalid argument
file_pread(5,8,buffer,3519069880(486401/81/9)) lseek err Invalid argument
file_pread(5,11,buffer,3519069927(486401/81/56)) lseek err Invalid argument
file_pread(5,1,buffer,3519071850(486401/112/26)) lseek err Invalid argument
file_pread(5,8,buffer,3519069881(486401/81/10)) lseek err Invalid argument
file_pread(5,1,buffer,3519069938(486401/82/4)) lseek err Invalid argument
file_pread(5,1,buffer,3519071851(486401/112/27)) lseek err Invalid argument
file_pread(5,8,buffer,3519069882(486401/81/11)) lseek err Invalid argument
file_pread(5,1,buffer,3519069939(486401/82/5)) lseek err Invalid argument
file_pread(5,1,buffer,3519071852(486401/112/28)) lseek err Invalid argument
file_pread(5,8,buffer,3519069883(486401/81/12)) lseek err Invalid argument
file_pread(5,11,buffer,3519069930(486401/81/59)) lseek err Invalid argument
file_pread(5,1,buffer,3519071853(486401/112/29)) lseek err Invalid argument
file_pread(5,8,buffer,3519069884(486401/81/13)) lseek err Invalid argument
file_pread(5,1,buffer,3519069941(486401/82/7)) lseek err Invalid argument
file_pread(5,1,buffer,3519071854(486401/112/30)) lseek err Invalid argument
file_pread(5,8,buffer,3519069885(486401/81/14)) lseek err Invalid argument
file_pread(5,1,buffer,3519069942(486401/82/8)) lseek err Invalid argument
file_pread(5,1,buffer,3519071855(486401/112/31)) lseek err Invalid argument
file_pread(5,8,buffer,3519069886(486401/81/15)) lseek err Invalid argument
file_pread(5,11,buffer,3519069933(486401/81/62)) lseek err Invalid argument
file_pread(5,1,buffer,3519071856(486401/112/32)) lseek err Invalid argument
file_pread(5,1,buffer,3519069944(486401/82/10)) lseek err Invalid argument
file_pread(5,1,buffer,3519071857(486401/112/33)) lseek err Invalid argument
file_pread(5,1,buffer,3519069945(486401/82/11)) lseek err Invalid argument
file_pread(5,1,buffer,3519071858(486401/112/34)) lseek err Invalid argument
file_pread(5,1,buffer,3519069946(486401/82/12)) lseek err Invalid argument
file_pread(5,1,buffer,3519071859(486401/112/35)) lseek err Invalid argument
file_pread(5,8,buffer,3519069890(486401/81/19)) lseek err Invalid argument
file_pread(5,11,buffer,3519069937(486401/82/3)) lseek err Invalid argument
file_pread(5,1,buffer,3519071860(486401/112/36)) lseek err Invalid argument
file_pread(5,1,buffer,3519069948(486401/82/14)) lseek err Invalid argument
file_pread(5,1,buffer,3519071861(486401/112/37)) lseek err Invalid argument
file_pread(5,1,buffer,3519069949(486401/82/15)) lseek err Invalid argument
file_pread(5,1,buffer,3519071862(486401/112/38)) lseek err Invalid argument
file_pread(5,1,buffer,3519069950(486401/82/16)) lseek err Invalid argument
file_pread(5,1,buffer,3519071863(486401/112/39)) lseek err Invalid argument
file_pread(5,8,buffer,3519069894(486401/81/23)) lseek err Invalid argument
file_pread(5,11,buffer,3519069941(486401/82/7)) lseek err Invalid argument
file_pread(5,1,buffer,3519071864(486401/112/40)) lseek err Invalid argument
file_pread(5,1,buffer,3519069952(486401/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,3519071865(486401/112/41)) lseek err Invalid argument
file_pread(5,1,buffer,3519069953(486401/82/19)) lseek err Invalid argument
file_pread(5,1,buffer,3519071866(486401/112/42)) lseek err Invalid argument
file_pread(5,1,buffer,3519069954(486401/82/20)) lseek err Invalid argument
file_pread(5,1,buffer,3519071867(486401/112/43)) lseek err Invalid argument
file_pread(5,8,buffer,3519069898(486401/81/27)) lseek err Invalid argument
file_pread(5,11,buffer,3519069945(486401/82/11)) lseek err Invalid argument
file_pread(5,1,buffer,3519071868(486401/112/44)) lseek err Invalid argument
file_pread(5,1,buffer,3519069956(486401/82/22)) lseek err Invalid argument
file_pread(5,1,buffer,3519071869(486401/112/45)) lseek err Invalid argument
file_pread(5,1,buffer,3519069957(486401/82/23)) lseek err Invalid argument
file_pread(5,1,buffer,3519071870(486401/112/46)) lseek err Invalid argument
file_pread(5,1,buffer,3519069958(486401/82/24)) lseek err Invalid argument
file_pread(5,1,buffer,3519071871(486401/112/47)) lseek err Invalid argument
file_pread(5,8,buffer,3519069902(486401/81/31)) lseek err Invalid argument
file_pread(5,11,buffer,3519069949(486401/82/15)) lseek err Invalid argument
file_pread(5,1,buffer,3519071872(486401/112/48)) lseek err Invalid argument
file_pread(5,1,buffer,3519069960(486401/82/26)) lseek err Invalid argument
file_pread(5,1,buffer,3519071873(486401/112/49)) lseek err Invalid argument
file_pread(5,1,buffer,3519069961(486401/82/27)) lseek err Invalid argument
file_pread(5,1,buffer,3519071874(486401/112/50)) lseek err Invalid argument
file_pread(5,1,buffer,3519069962(486401/82/28)) lseek err Invalid argument
file_pread(5,1,buffer,3519071875(486401/112/51)) lseek err Invalid argument
file_pread(5,8,buffer,3519069906(486401/81/35)) lseek err Invalid argument
file_pread(5,11,buffer,3519069953(486401/82/19)) lseek err Invalid argument
file_pread(5,1,buffer,3519071876(486401/112/52)) lseek err Invalid argument
file_pread(5,1,buffer,3519069964(486401/82/30)) lseek err Invalid argument
file_pread(5,1,buffer,3519071877(486401/112/53)) lseek err Invalid argument
file_pread(5,1,buffer,3519069965(486401/82/31)) lseek err Invalid argument
file_pread(5,1,buffer,3519071878(486401/112/54)) lseek err Invalid argument
file_pread(5,1,buffer,3519069966(486401/82/32)) lseek err Invalid argument
file_pread(5,1,buffer,3519071879(486401/112/55)) lseek err Invalid argument
file_pread(5,8,buffer,3519069910(486401/81/39)) lseek err Invalid argument
file_pread(5,11,buffer,3519069957(486401/82/23)) lseek err Invalid argument
file_pread(5,1,buffer,3519071880(486401/112/56)) lseek err Invalid argument
file_pread(5,1,buffer,3519069968(486401/82/34)) lseek err Invalid argument
file_pread(5,1,buffer,3519071881(486401/112/57)) lseek err Invalid argument
file_pread(5,1,buffer,3519069969(486401/82/35)) lseek err Invalid argument
file_pread(5,1,buffer,3519071882(486401/112/58)) lseek err Invalid argument
file_pread(5,1,buffer,3519069970(486401/82/36)) lseek err Invalid argument
file_pread(5,1,buffer,3519071883(486401/112/59)) lseek err Invalid argument
file_pread(5,8,buffer,3519069914(486401/81/43)) lseek err Invalid argument
file_pread(5,11,buffer,3519069961(486401/82/27)) lseek err Invalid argument
file_pread(5,1,buffer,3519071884(486401/112/60)) lseek err Invalid argument
file_pread(5,1,buffer,3519069972(486401/82/38)) lseek err Invalid argument
file_pread(5,1,buffer,3519071885(486401/112/61)) lseek err Invalid argument
file_pread(5,1,buffer,3519069973(486401/82/39)) lseek err Invalid argument
file_pread(5,1,buffer,3519071886(486401/112/62)) lseek err Invalid argument
file_pread(5,1,buffer,3519069974(486401/82/40)) lseek err Invalid argument
file_pread(5,1,buffer,3519071887(486401/112/63)) lseek err Invalid argument
file_pread(5,8,buffer,3519069918(486401/81/47)) lseek err Invalid argument
file_pread(5,11,buffer,3519069965(486401/82/31)) lseek err Invalid argument
file_pread(5,1,buffer,3519071888(486401/113/1)) lseek err Invalid argument
file_pread(5,1,buffer,3519069976(486401/82/42)) lseek err Invalid argument
file_pread(5,1,buffer,3519071889(486401/113/2)) lseek err Invalid argument
file_pread(5,1,buffer,3519069977(486401/82/43)) lseek err Invalid argument
file_pread(5,1,buffer,3519071890(486401/113/3)) lseek err Invalid argument
file_pread(5,1,buffer,3519069978(486401/82/44)) lseek err Invalid argument
file_pread(5,1,buffer,3519071891(486401/113/4)) lseek err Invalid argument
file_pread(5,8,buffer,3519069922(486401/81/51)) lseek err Invalid argument
file_pread(5,11,buffer,3519069969(486401/82/35)) lseek err Invalid argument
file_pread(5,1,buffer,3519071892(486401/113/5)) lseek err Invalid argument
file_pread(5,1,buffer,3519069980(486401/82/46)) lseek err Invalid argument
file_pread(5,1,buffer,3519071893(486401/113/6)) lseek err Invalid argument
file_pread(5,1,buffer,3519069931(486401/81/60)) lseek err Invalid argument
file_pread(5,1,buffer,3519069981(486401/82/47)) lseek err Invalid argument
file_pread(5,1,buffer,3519071894(486401/113/7)) lseek err Invalid argument
file_pread(5,8,buffer,3519069925(486401/81/54)) lseek err Invalid argument
file_pread(5,11,buffer,3519069972(486401/82/38)) lseek err Invalid argument
file_pread(5,1,buffer,3519071895(486401/113/8)) lseek err Invalid argument
file_pread(5,1,buffer,3519069983(486401/82/49)) lseek err Invalid argument
file_pread(5,1,buffer,3519071896(486401/113/9)) lseek err Invalid argument
file_pread(5,1,buffer,3519069934(486401/81/63)) lseek err Invalid argument
file_pread(5,1,buffer,3519069984(486401/82/50)) lseek err Invalid argument
file_pread(5,1,buffer,3519071897(486401/113/10)) lseek err Invalid argument
file_pread(5,8,buffer,3519069928(486401/81/57)) lseek err Invalid argument
file_pread(5,11,buffer,3519069975(486401/82/41)) lseek err Invalid argument
file_pread(5,1,buffer,3519071898(486401/113/11)) lseek err Invalid argument
file_pread(5,1,buffer,3519069986(486401/82/52)) lseek err Invalid argument
file_pread(5,1,buffer,3519071899(486401/113/12)) lseek err Invalid argument
file_pread(5,1,buffer,3519069937(486401/82/3)) lseek err Invalid argument
file_pread(5,1,buffer,3519069987(486401/82/53)) lseek err Invalid argument
file_pread(5,1,buffer,3519071900(486401/113/13)) lseek err Invalid argument
file_pread(5,8,buffer,3519069931(486401/81/60)) lseek err Invalid argument
file_pread(5,11,buffer,3519069978(486401/82/44)) lseek err Invalid argument
file_pread(5,1,buffer,3519071901(486401/113/14)) lseek err Invalid argument
file_pread(5,1,buffer,3519069989(486401/82/55)) lseek err Invalid argument
file_pread(5,1,buffer,3519071902(486401/113/15)) lseek err Invalid argument
file_pread(5,1,buffer,3519069940(486401/82/6)) lseek err Invalid argument
file_pread(5,1,buffer,3519069990(486401/82/56)) lseek err Invalid argument
file_pread(5,1,buffer,3519071903(486401/113/16)) lseek err Invalid argument
file_pread(5,8,buffer,3519069934(486401/81/63)) lseek err Invalid argument
file_pread(5,11,buffer,3519069981(486401/82/47)) lseek err Invalid argument
file_pread(5,1,buffer,3519071904(486401/113/17)) lseek err Invalid argument
file_pread(5,1,buffer,3519069992(486401/82/58)) lseek err Invalid argument
file_pread(5,1,buffer,3519071905(486401/113/18)) lseek err Invalid argument
file_pread(5,1,buffer,3519069943(486401/82/9)) lseek err Invalid argument
file_pread(5,1,buffer,3519069993(486401/82/59)) lseek err Invalid argument
file_pread(5,1,buffer,3519071906(486401/113/19)) lseek err Invalid argument
file_pread(5,14,buffer,3519069860(486401/80/52)) ReadFile Das Laufwerk kann den angeforderten Sektor nicht finden.
file_pread(5,3,buffer,3519069874(486401/81/3)) lseek err Invalid argument
file_pread(5,3,buffer,3519069921(486401/81/50)) lseek err Invalid argument
file_pread(5,8,buffer,3519069937(486401/82/3)) lseek err Invalid argument
file_pread(5,11,buffer,3519069984(486401/82/50)) lseek err Invalid argument
file_pread(5,2,buffer,3519071906(486401/113/19)) lseek err Invalid argument
file_pread(5,14,buffer,3519069861(486401/80/53)) ReadFile Das Laufwerk kann den angeforderten Sektor nicht finden.
file_pread(5,2,buffer,3519069873(486401/81/2)) lseek err Invalid argument
file_pread(5,3,buffer,3519069875(486401/81/4)) lseek err Invalid argument
file_pread(5,3,buffer,3519069922(486401/81/51)) lseek err Invalid argument
file_pread(5,8,buffer,3519069938(486401/82/4)) lseek err Invalid argument
file_pread(5,11,buffer,3519069985(486401/82/51)) lseek err Invalid argument
file_pread(5,2,buffer,3519071907(486401/113/20)) lseek err Invalid argument
file_pread(5,14,buffer,3519069862(486401/80/54)) ReadFile Das Laufwerk kann den angeforderten Sektor nicht finden.
file_pread(5,3,buffer,3519069873(486401/81/2)) lseek err Invalid argument
file_pread(5,3,buffer,3519069876(486401/81/5)) lseek err Invalid argument
file_pread(5,3,buffer,3519069923(486401/81/52)) lseek err Invalid argument
file_pread(5,8,buffer,3519069939(486401/82/5)) lseek err Invalid argument
file_pread(5,11,buffer,3519069986(486401/82/52)) lseek err Invalid argument
file_pread(5,2,buffer,3519071908(486401/113/21)) lseek err Invalid argument
file_pread(5,14,buffer,3519069863(486401/80/55)) ReadFile Das Laufwerk kann den angeforderten Sektor nicht finden.
file_pread(5,4,buffer,3519069873(486401/81/2)) lseek err Invalid argument
file_pread(5,3,buffer,3519069877(486401/81/6)) lseek err Invalid argument
file_pread(5,3,buffer,3519069924(486401/81/53)) lseek err Invalid argument
file_pread(5,8,buffer,3519069940(486401/82/6)) lseek err Invalid argument
file_pread(5,11,buffer,3519069987(486401/82/53)) lseek err Invalid argument
file_pread(5,2,buffer,3519071909(486401/113/22)) lseek err Invalid argument
file_pread(5,14,buffer,3519069864(486401/80/56)) ReadFile Das Laufwerk kann den angeforderten Sektor nicht finden.
file_pread(5,3,buffer,3519069878(486401/81/7)) lseek err Invalid argument
file_pread(5,3,buffer,3519069925(486401/81/54)) lseek err Invalid argument
file_pread(5,8,buffer,3519069941(486401/82/7)) lseek err Invalid argument
file_pread(5,11,buffer,3519069988(486401/82/54)) lseek err Invalid argument
file_pread(5,2,buffer,3519071910(486401/113/23)) lseek err Invalid argument
file_pread(5,1,buffer,3519069999(486401/83/2)) lseek err Invalid argument
file_pread(5,1,buffer,3519071912(486401/113/25)) lseek err Invalid argument
file_pread(5,14,buffer,3519069866(486401/80/58)) ReadFile Das Laufwerk kann den angeforderten Sektor nicht finden.
file_pread(5,7,buffer,3519069873(486401/81/2)) lseek err Invalid argument
file_pread(5,3,buffer,3519069880(486401/81/9)) lseek err Invalid argument
file_pread(5,3,buffer,3519069927(486401/81/56)) lseek err Invalid argument
file_pread(5,8,buffer,3519069943(486401/82/9)) lseek err Invalid argument
file_pread(5,11,buffer,3519069990(486401/82/56)) lseek err Invalid argument
file_pread(5,1,buffer,3519071913(486401/113/26)) lseek err Invalid argument
file_pread(5,1,buffer,3519069951(486401/82/17)) lseek err Invalid argument
file_pread(5,1,buffer,3519070001(486401/83/4)) lseek err Invalid argument
file_pread(5,1,buffer,3519071914(486401/113/27)) lseek err Invalid argument
file_pread(5,14,buffer,3519069868(486401/80/60)) ReadFile Das Laufwerk kann den angeforderten Sektor nicht finden.
file_pread(5,3,buffer,3519069882(486401/81/11)) lseek err Invalid argument
file_pread(5,3,buffer,3519069929(486401/81/58)) lseek err Invalid argument
file_pread(5,8,buffer,3519069945(486401/82/11)) lseek err Invalid argument
file_pread(5,11,buffer,3519069992(486401/82/58)) lseek err Invalid argument
file_pread(5,1,buffer,3519071915(486401/113/28)) lseek err Invalid argument
file_pread(5,10,buffer,3519069873(486401/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,3519070003(486401/83/6)) lseek err Invalid argument
file_pread(5,1,buffer,3519071916(486401/113/29)) lseek err Invalid argument
file_pread(5,14,buffer,3519069870(486401/80/62)) ReadFile Das Laufwerk kann den angeforderten Sektor nicht finden.
file_pread(5,3,buffer,3519069884(486401/81/13)) lseek err Invalid argument
file_pread(5,3,buffer,3519069931(486401/81/60)) lseek err Invalid argument
file_pread(5,8,buffer,3519069947(486401/82/13)) lseek err Invalid argument
file_pread(5,11,buffer,3519069994(486401/82/60)) lseek err Invalid argument
file_pread(5,1,buffer,3519071917(486401/113/30)) lseek err Invalid argument
file_pread(5,12,buffer,3519069873(486401/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,3519069955(486401/82/21)) lseek err Invalid argument
file_pread(5,1,buffer,3519070005(486401/83/8)) lseek err Invalid argument
file_pread(5,1,buffer,3519071918(486401/113/31)) lseek err Invalid argument
file_pread(5,1,buffer,3519070006(486401/83/9)) lseek err Invalid argument
file_pread(5,1,buffer,3519071919(486401/113/32)) lseek err Invalid argument
file_pread(5,2,buffer,3519069885(486401/81/14)) lseek err Invalid argument
file_pread(5,8,buffer,3519069950(486401/82/16)) lseek err Invalid argument
file_pread(5,11,buffer,3519069997(486401/82/63)) lseek err Invalid argument
file_pread(5,1,buffer,3519071920(486401/113/33)) lseek err Invalid argument
file_pread(5,14,buffer,3519069874(486401/81/3)) lseek err Invalid argument
file_pread(5,1,buffer,3519070008(486401/83/11)) lseek err Invalid argument
file_pread(5,1,buffer,3519071921(486401/113/34)) lseek err Invalid argument
Partition gone for no apparent reason - Deep Scan doesn't find anything and provides immense error log
Re: Partition gone for no apparent reason - Deep Scan doesn't find anything and provides immense error log
I think it's a hardware problem. As it's more serious than bad sectors, you will be unable to clone the disk, you should contact a data recovery company.
