Hello, my SD card unexpectedly damaged. I tried to analyse the card using testdisk and it didn't found any bootable partition (screen https://prnt.sc/hzf2wk ).
Is there any chance to save data and the card? Can you help me please? Thank you so much.
Re: No partition is bootable
Run TestDisk, in Advanced, select the FAT32 partition, Undelete.
If you don't see your files, use PhotoRec instead. Read https://www.cgsecurity.org/testdisk.pdf if you need more information.
