I am trying to find the previous partiton. I did all steps... I did deep search too.
OS: Linux, kernel 4.10.0-28-generic (#32~16.04.2-Ubuntu SMP Thu Jul 20 10:19:48 UTC 2017) x86_64
Compiler: GCC 4.4
Compilation date: 2015-04-18T13:03:42
ext2fs lib: 1.42.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504, curses lib: ncurses 5.7
/dev/sda: LBA, LBA48, DCO support
/dev/sda: size 500118192 sectors
/dev/sda: user_max 500118192 sectors
/dev/sr0 is not an ATA disk
Disk /dev/sda - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - MTFDDAK256MAM-1K1, S/N:1250092062A6, FW:0909
Disk /dev/sdf - 4007 MB / 3822 MiB - CHS 1018 124 62, sector size=512 - TOSHIBA TransMemory, FW:PMAP
Disk /dev/sdg - 4007 MB / 3822 MiB - CHS 1018 124 62, sector size=512 - TOSHIBA TransMemory, FW:PMAP
Disk /dev/sdh - 15 GB / 14 GiB - CHS 14800 64 32, sector size=512, FW:8.07
Disk /dev/sr0 - 47 GB / 44 GiB - 23301376 sectors (RO), sector size=2048 - hp BD B DH8B2SHB, S/N:226303900624, FW:SHDQ
write_all_log_i386: CHS: 1/0/1,lba=2048
Disk /dev/sda - 256 GB / 238 GiB - MTFDDAK256MAM-1K1
Partition table type: EFI GPT
Analyse Disk /dev/sda - 256 GB / 238 GiB - CHS 31130 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=500118191 (expected 500118191)
hdr_lba_start=34
hdr_lba_end=500118158
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
3 P MS Reserved 2834432 3096575 262144 [Microsoft reserved partition]
1 P Unknown 2048 2097151 2095104 [Basic data partition]
2 P EFI System 2097152 2834431 737280 [EFI system partition]
4 P MS Data 3096576 477091839 473995264 [Basic data partition]
5 P MS Data 477091840 500117503 23025664 [Basic data partition]
NTFS at 0/32/33
filesystem size 2095104
mft_lcn 87296
mftmirr_lcn 2
NTFS part_offset=1048576, part_size=1072693248, sector_size=512
NTFS at 0/32/33
mft_lcn 87296
mftmirr_lcn 2
MS Data 2048 2097151 2095104
NTFS, blocksize=4096, 1072 MB / 1023 MiB
FAT32 at 130/138/9
FAT1 : 6766-7478
FAT2 : 7479-8191
Data : 8192-737279
sectors : 737280
cluster_size : 8
no_of_cluster : 91136 (2 - 91137)
fat_length 713 calculated 713
FAT32 at 130/138/9
MS Data 2097152 2834431 737280 [SYSTEM]
FAT32, blocksize=4096, 377 MB / 360 MiB
NTFS at 192/192/1
filesystem size 473995264
mftmirr_lcn 2
NTFS part_offset=1585446912, part_size=242685575168, sector_size=512
NTFS at 192/192/1
mftmirr_lcn 2
NTFS, blocksize=4096, 242 GB / 226 GiB
NTFS at 29697/151/23
filesystem size 23025664
mftmirr_lcn 2
MS Data 454066177 477091840 23025664
NTFS found using backup sector, blocksize=4096, 11 GB / 10 GiB
mftmirr_lcn 2
NTFS, blocksize=4096, 11 GB / 10 GiB
P MS Data 2048 2097151 2095104
P MS Data 2097152 2834431 737280 [SYSTEM]
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 2095104 linear /dev/sda 2048" | dmsetup create test0
echo "0 737280 linear /dev/sda 2097152" | dmsetup create test1
echo "0 473995264 linear /dev/sda 3096576" | dmsetup create test2
echo "0 23025664 linear /dev/sda 454066177" | dmsetup create test3
echo "0 23025664 linear /dev/sda 477091840" | dmsetup create test4
ntfs_ucstoutf8: iconv_open failed
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 22-Jan-2018 23:03 .
5 dr-xr-xr-x 0 0 0 22-Jan-2018 23:03 ..
9427 dr-xr-xr-x 0 0 0 3-Dec-2017 01:04 $RECYCLE.BIN
357877 dr-xr-xr-x 0 0 0 3-Dec-2017 17:15 ArcTemp
3771 dr-xr-xr-x 0 0 0 11-Aug-2012 01:09 Boot
1456 dr-xr-xr-x 0 0 0 3-Dec-2017 01:09 NVIDIA
4621 dr-xr-xr-x 0 0 0 26-Jul-2012 07:33 PerfLogs
4622 dr-xr-xr-x 0 0 0 6-Jan-2018 11:57 Program Files
17307 dr-xr-xr-x 0 ntfs_mst_post_read_fixup_warn: magic: 0xe12e79da size: 1024 usa_ofs: 63129 usa_count: 1656: Invalid argument
Record 0 has no FILE magic (0xe12e79da)
0 0 12-Jan-2018 12:15 Program Files (x86)
17375 dr-xr-xr-x 0 0 0 26-Dec-2017 22:56 ProgramData
17488 dr-xr-xr-x 0 0 0 11-Aug-2012 00:16 Recovery
4609 dr-xr-xr-x 0 0 0 3-Dec-2017 01:03 SWSETUP
4611 dr-xr-xr-x 0 0 0 3-Dec-2017 01:03 SYSTEM.SAV
6597 dr-xr-xr-x 0 0 0 22-Jan-2018 02:32 System Volume Information
17489 dr-xr-xr-x 0 0 0 3-Dec-2017 01:02 Users
17620 dr-xr-xr-x 0 0 0 11-Jan-2018 10:14 Windows
98 dr-xr-xr-x 0 0 0 3-Dec-2017 01:03 hp
4601 dr-xr-xr-x 0 0 0 11-Aug-2012 00:16 inetpub
403313 dr-xr-xr-x 0 0 0 11-Jan-2018 10:13 sources
35 -r--r--r-- 0 0 0 3-Dec-2017 03:22 13NA1RC8601.restore
34097 -r--r--r-- 0 0 1 2-Jun-2012 14:30 BOOTNXT
736 -r--r--r-- 0 0 0 3-Dec-2017 03:23 OS
274645 -r--r--r-- 0 0 232960 7-Nov-2007 13:12 VC_RED.MSI
12411 -r--r--r-- 0 0 1442522 7-Nov-2007 13:09 VC_RED.cab
34094 -r--r--r-- 0 0 398156 26-Jul-2012 03:44 bootmgr
12330 -r--r--r-- 0 0 17734 7-Nov-2007 13:00 eula.1028.txt
12331 -r--r--r-- 0 0 17734 7-Nov-2007 13:00 eula.1031.txt
12332 -r--r--r-- 0 0 10134 7-Nov-2007 13:00 eula.1033.txt
12372 -r--r--r-- 0 0 17734 7-Nov-2007 13:00 eula.1036.txt
12375 -r--r--r-- 0 0 17734 7-Nov-2007 13:00 eula.1040.txt
12394 -r--r--r-- 0 0 118 7-Nov-2007 13:00 eula.1041.txt
12395 -r--r--r-- 0 0 17734 7-Nov-2007 13:00 eula.1042.txt
12325 -r--r--r-- 0 0 17734 7-Nov-2007 13:00 eula.2052.txt
12335 -r--r--r-- 0 0 17734 7-Nov-2007 13:00 eula.3082.txt
13091 -r--r--r-- 0 0 1110 7-Nov-2007 13:00 globdata.ini
119 -r--r--r-- 0 0 27435802624 23-Jan-2018 07:19 hiberfil.sys
13163 -r--r--r-- 0 0 562688 7-Nov-2007 13:03 install.exe
13170 -r--r--r-- 0 0 843 7-Nov-2007 13:00 install.ini
13171 -r--r--r-- 0 0 76304 7-Nov-2007 13:03 install.res.1028.dll
13172 -r--r--r-- 0 0 96272 7-Nov-2007 13:03 install.res.1031.dll
13173 -r--r--r-- 0 0 91152 7-Nov-2007 13:03 install.res.1033.dll
13092 -r--r--r-- 0 0 97296 7-Nov-2007 13:03 install.res.1036.dll
13096 -r--r--r-- 0 0 95248 7-Nov-2007 13:03 install.res.1040.dll
13098 -r--r--r-- 0 0 81424 7-Nov-2007 13:03 install.res.1041.dll
13162 -r--r--r-- 0 0 79888 7-Nov-2007 13:03 install.res.1042.dll
13174 -r--r--r-- 0 0 75792 7-Nov-2007 13:03 install.res.2052.dll
13095 -r--r--r-- 0 0 96272 7-Nov-2007 13:03 install.res.3082.dll
154 -r--r--r-- 0 0 4563402752 23-Jan-2018 07:19 pagefile.sys
6602 -r--r--r-- 0 0 268435456 23-Jan-2018 07:19 swapfile.sys
12406 -r--r--r-- 0 0 5686 7-Nov-2007 13:00 vcredist.bmp
386 dr-xr-xr-x 0 0 0 3-Dec-2017 01:04 $RECYCLE.BIN
161 dr-xr-xr-x 0 0 0 3-Dec-2017 02:58 EFI
37 dr-xr-xr-x 0 0 0 3-Dec-2017 02:58 Recovery
329 dr-xr-xr-x 0 0 0 3-Dec-2017 02:58 RecoveryImage
393 dr-xr-xr-x 0 0 0 3-Dec-2017 02:58 SOURCES
384 dr-xr-xr-x 0 0 0 3-Dec-2017 01:57 System Volume Information
39 dr-xr-xr-x 0 0 0 3-Dec-2017 02:58 boot
306 dr-xr-xr-x 0 0 0 3-Dec-2017 02:58 hp
391 -r--r--r-- 0 0 0 3-Dec-2017 01:03 BT_HP.FLG
389 -r--r--r-- 0 0 748 3-Dec-2017 02:58 CSP.DAT
390 -r--r--r-- 0 0 10840 3-Dec-2017 02:58 DeployRp.log
378 -r--r--r-- 0 0 0 3-Dec-2017 02:55 RPCONFIG.LOG
35 -r--r--r-- 0 0 398156 26-Jul-2012 06:44 bootmgr
36 -r--r--r-- 0 0 1350896 26-Jul-2012 07:57 bootmgr.efi
392 -r--r--r-- 0 0 44 3-Dec-2017 01:03 language.ini
1 P MS Data 2048 2097151 2095104
2 P MS Data 2097152 2834431 737280 [SYSTEM]
3 P MS Data 3096576 477091839 473995264
NTFS at 0/32/33
mft_lcn 87296
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 87296
mftmirr_lcn 2
NTFS at 99/188/2
filesystem size 6174
sectors_per_cluster 1
mft_lcn 2058
mftmirr_lcn 5162
clusters_per_mft_record 2
clusters_per_index_record 8
MS Data 1596107 1602280 6174
NTFS at 99/188/2
mft_lcn 2058
mftmirr_lcn 5162
MS Data 1602280 1608453 6174 [Boot]
NTFS at 130/138/8
mft_lcn 87296
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 1072 MB / 1023 MiB
NTFS at 130/138/8
mft_lcn 87296
mftmirr_lcn 2
MS Data 2097151 4192254 2095104
FAT32 at 130/138/9
FAT1 : 6766-7478
FAT2 : 7479-8191
Data : 8192-737279
sectors : 737280
cluster_size : 8
FAT32 at 130/138/9
FAT32 at 130/138/15
FAT1 : 6766-7478
FAT2 : 7479-8191
Data : 8192-737279
sectors : 737280
cluster_size : 8
FAT differs, FAT sectors=704-713/713
FAT32 at 130/138/15
MS Data 2097152 2834431 737280 [NO NAME]
FAT32 at 130/138/15
FAT1 : 6766-7478
FAT2 : 7479-8191
Data : 8192-737279
sectors : 737280
cluster_size : 8
FAT32 at 130/138/15
MS Data 2097158 2834437 737280 [NO NAME]
NTFS at 192/192/1
mftmirr_lcn 2
NTFS at 192/192/1
mftmirr_lcn 2
LVM magic value at 1082/123/19
ReiserFS Marker at 1123/110/19
LVM magic value at 1337/205/44
LVM magic value at 1449/140/48
LVM magic value at 2582/179/23
LVM magic value at 3386/177/38
FAT12 at 3392/148/29
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
fat_length 9 calculated 9
MS Data 54501832 54504711 2880 [EFISECTOR]
NTFS at 3720/243/52
mft_lcn 2058
mftmirr_lcn 5162
MS Data 59770987 59777160 6174
NTFS at 3720/243/52
mft_lcn 2058
mftmirr_lcn 5162
MS Data 59777160 59783333 6174 [Boot]
FAT12 at 3721/86/54
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 at 3721/86/54
MS Data 59783336 59786215 2880 [EFISECTOR]
FAT12 at 3721/132/36
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
MS Data 59786216 59789095 2880 [EFISECTOR]
recover_EXT2: s_block_group_nr=0/255, s_mnt_count=30/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 8388352
recover_EXT2: part_size 67106816
MS Data 129308992 196415807 67106816
ext4 blocksize=4096 Large_file Sparse_SB Recover, 34 GB / 31 GiB
recover_EXT2: s_block_group_nr=0/255, s_mnt_count=13/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
MS Data 305881344 372988159 67106816
MS Data 305881424 372988239 67106816
MS Data 305881512 372988327 67106816
MS Data 305881592 372988407 67106816
block_group_nr 243
recover_EXT2: "e2fsck -b 7962624 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=243/255, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
MS Data 271094880 338201695 67106816
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 34 GB / 31 GiB
FAT32 at 20877/176/12
FAT1 : 32-16399
FAT2 : 16400-32767
start_rootdir : 32768 root cluster : 2
Data : 32768-33552383
sectors : 33552384
cluster_size : 16
no_of_cluster : 2094976 (2 - 2094977)
fat_length 16368 calculated 16368
MS Data 335400104 368952487 33552384 [NO NAME]
FAT32, blocksize=8192, 17 GB / 15 GiB
FAT32 at 20877/176/18
FAT1 : 32-16399
FAT2 : 16400-32767
sectors : 33552384
cluster_size : 16
MS Data 335400110 368952493 33552384 [NO NAME]
FAT12 at 21093/32/12
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
MS Data 338861072 338863951 2880 [EFISECTOR]
FAT12 at 21093/77/57
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
MS Data 338863952 338866831 2880 [EFISECTOR]
FAT16 at 21577/128/56
check_FAT: Unusual number of reserved sectors 4 (FAT), should be 1.
FAT1 : 4-23
FAT2 : 24-43
start_rootdir : 44
Data : 76-18019
sectors : 18020
cluster_size : 4
no_of_cluster : 4486 (2 - 4487)
fat_length 20 calculated 18
heads/cylinder 64 (FAT) != 255 (HD)
MS Data 346642624 346660643 18020 [ANACONDA]
FAT16, blocksize=2048, 9226 KB / 9010 KiB
HFS+ magic value at 21578/159/58
part_size 38128
Mac HFS 346660644 346698771 38128
HFS+ blocksize=4096 + Backup, 19 MB / 18 MiB
HFS+ magic value at 21578/159/60
part_size 38128
Mac HFS 346622520 346660647 38128
HFS+ found using backup sector!, 19 MB / 18 MiB
HFS+ magic value at 21581/0/4
part_size 38128
Mac HFS 346698768 346736895 38128
HFS+ blocksize=4096, 19 MB / 18 MiB
HFS+ magic value at 21581/0/6
part_size 38128
FAT12 at 21817/120/48
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
MS Data 350497712 350500591 2880 [EFISECTOR]
FAT12 at 21817/166/30
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
MS Data 350500592 350503471 2880 [EFISECTOR]
FAT12 at 21831/215/9
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
MS Data 350728568 350731447 2880 [EFISECTOR]
NTFS at 21833/3/51
mft_lcn 2058
mftmirr_lcn 5162
MS Data 350741211 350747384 6174
NTFS at 21833/3/51
mft_lcn 2058
mftmirr_lcn 5162
MS Data 350747384 350753557 6174 [Boot]
HFS magic value at 22647/36/39
part_size 1636333214
Mac HFS 363826361 2000159574 1636333214
HFS blocksize=16777216, 837 GB / 780 GiB
This partition ends after the disk limits. (start=363826361, size=1636333214, end=2000159574, disk end=500118192)
HFS magic value at 22647/36/41
HFS magic value at 25123/60/47
part_size 1688998914
Mac HFS 403604821 2092603734 1688998914
HFS blocksize=16777216, 864 GB / 805 GiB
This partition ends after the disk limits. (start=403604821, size=1688998914, end=2092603734, disk end=500118192)
HFS magic value at 25123/60/49
FAT12 at 25264/115/8
check_FAT: Unusual media descriptor (0xf8!=0xf0)
FAT1 : 1-4
FAT2 : 5-8
start_rootdir : 9
Data : 41-4668
sectors : 4672
cluster_size : 4
no_of_cluster : 1157 (2 - 1158)
fat_length 4 calculated 4
MS Data 405873412 405878083 4672 [NO NAME]
FAT12, blocksize=2048, 2392 KB / 2336 KiB
FAT12 at 25293/243/47
FAT1 : 1-12
FAT2 : 13-24
start_rootdir : 25
Data : 57-12536
sectors : 12540
cluster_size : 4
no_of_cluster : 3120 (2 - 3121)
fat_length 12 calculated 10
MS Data 406347400 406359939 12540 [ANACONDA]
FAT12, blocksize=2048, 6420 KB / 6270 KiB
NTFS at 27398/97/27
mftmirr_lcn 2
NTFS part_offset=225359363584, part_size=242685575168, sector_size=512
NTFS at 27398/97/27
mftmirr_lcn 2
MS Data 440155007 914150270 473995264
This partition ends after the disk limits. (start=440155007, size=473995264, end=914150270, disk end=500118192)
HFS magic value at 28548/209/12
part_size 3389017435
Mac HFS 458636798 3847654232 3389017435 [imation]
HFS blocksize=67108864, 1735 GB / 1616 GiB
This partition ends after the disk limits. (start=458636798, size=3389017435, end=3847654232, disk end=500118192)
HFS magic value at 28548/209/14
LVM magic value at 29398/62/58
HFS magic value at 29431/63/34
Mac HFS 472813017 2109146230 1636333214
This partition ends after the disk limits. (start=472813017, size=1636333214, end=2109146230, disk end=500118192)
HFS magic value at 29431/63/36
NTFS at 29697/151/22
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 242 GB / 226 GiB
mftmirr_lcn 2
MS Data 477091839 951087102 473995264
This partition ends after the disk limits. (start=477091839, size=473995264, end=951087102, disk end=500118192)
mftmirr_lcn 2
mftmirr_lcn 2
FAT12 at 29700/9/54
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 at 29700/9/54
MS Data 477131120 477133999 2880 [EFISECTOR]
FAT12 at 29700/55/36
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
MS Data 477134000 477136879 2880 [EFISECTOR]
NTFS at 30088/0/49
mft_lcn 2058
mftmirr_lcn 5162
MS Data 483357595 483363768 6174
NTFS at 30088/0/49
mft_lcn 2058
mftmirr_lcn 5162
MS Data 483363768 483369941 6174 [Boot]
FAT12 at 30088/171/52
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
MS Data 483374544 483377423 2880 [EFISECTOR]
FAT12 at 30088/217/34
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
MS Data 483377424 483380303 2880 [EFISECTOR]
NTFS at 31130/223/5
mftmirr_lcn 2
NTFS at 31130/223/5
mftmirr_lcn 2
NTFS: Can't read MFT
MS Data 500117503 523143166 23025664
This partition ends after the disk limits. (start=500117503, size=23025664, end=523143166, disk end=500118192)
The harddisk (256 GB / 238 GiB) seems too small! (< 1969 GB / 1834 GiB)
Mac HFS 191353136 1827686349 1636333214
Recover previous partition
Re: Recover previous partition
The whole disk seems used. What partition are you looking for ? A deleted partition that have been replace by a new one ?
What was the type of the partition ? exFAT, NTFS, ext4 ? Have you seen it after Deeper Search ?
overclocked
Yeah, it was whole disk. I was trying to find previous partition. I formatted and reinstall windows 8. It's NTFS. Yes, I used deeper search. I saw too many MS Data and a message (HD seems too small) after deeper search.
It has 250 gb SSD.
What partition are you looking for ? I am trying to search for partitions inside my partition C:
A deleted partition that have been replace by a new one ? (yes)
What was the type of the partition ? exFAT, NTFS, ext4 ? NTFS
Have you seen it after Deeper Search ? Yes, I have. I was not able to post full log here because it has more than 100,000 words. The log showed me that I have too many MS Data.
Thank you for answering back and approving the thread.
It has 250 gb SSD.
overclocked
Update: You may watch two videos. That's what it shows like that.
Part 1:
https://www.youtube.com/watch?v=BhHQQFQpm_k
Part 2:
https://www.youtube.com/watch?v=e2_9VHJPHLM&t=7s
Sorry about part 2's wrong side.
Part 1:
Part 2:
Try to list the files from each partition that TestDisk has found. If it's a partition you want to recover, set it as P(rimary) or *(bootable) and on next screen, choose Write, confirm, Quit.
Note that you probably won't be able to boot from this disk anymore!
overclocked
There are too many ms data. Most of them are ext4. Some of them are damaged. I haven't seen one partition with old files. If I add it as primary or *(bootable), that means I will boot that partition immediately? And what about "HHD seems too small"?
overclocked
I forgot to add the picture here. You should be able to see the message. It says The HardDisk seems too small.
- Screenshot from 2018-02-21 21-22-18.jpg (103.53 KiB) Viewed 5660 times
overclocked
I believe that there is still a partition. I am not sure how to solve "The hard disk seems too small!" issue.
