Newbie, PLEASE help
ZeroC00L
Newbie, PLEASE help
#1 Post by ZeroC00L »
Hi, I apologise, I'm sure this has already been answered before, but I've looked extensively for someone else with the same problem, but couldn't find anything.
External usb 1tb WD My Book was plugged into my laptop,
My WIN7 Laptop battery no longer holds any charge,
The laptop power cord was accidentally unplugged, Laptop switched off instantly,
After rebooting got the "disk needs formatting" error message.
(I did not format it)
Got a new laptop - WIN 10
Plugged in the Eternal Hard Drive, same thing,
Ran TestDisk - Analyse,
Hit P,
No Joy.
Ran Deeper Scan,
Result:
The attachment DS.PNG is no longer available
Hit P,
Result:
The attachment DSP.PNG is no longer available
Hit Continue,
Result:
What do I do Now ?
How can I fix the file system ?
Surely I haven't lost everything simply from a sudden loss of power ?
Here is my LOG for further details.
PLEASE help. there are a many InDesign files on here that rely on linked files, so filename and folder structure are critical. Recovering hundreds of thousands of renamed files in random folders is not an option.
testdisk.log contents:
Tue Jan 30 22:05:13 2018
TestDisk 7.1-WIP, Data Recovery Utility, January 2018
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=499530072064
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=500104378368
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000202043392
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST9500420AS, S/N:5VJ24L9A, FW:0006HPM1
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000BPVT-75HXZT3, S/N:WD-WXL1A9178656, FW:03.01A03
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WD 10EADS External, S/N:WD-WCAV50532811, FW:1.75
Disk /dev/sdc - 1000 GB / 931 GiB - WD 10EADS External
test_FAT()
1 * FAT16 >32M 0 32 33 121601 25 24 1953519616
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
Change partition type:
New options :
Dump : No
Align partition: Yes
Expert mode : No
Analyse Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63
test_FAT()
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
Invalid FAT boot sector
NTFS at 121600/254/63
filesystem size 1953520002
mftmirr_lcn 2
HPFS - NTFS 0 1 1 121600 254 63 1953520002
NTFS found using backup sector, blocksize=4096, 1000 GB / 931 GiB
mftmirr_lcn 2
file_pread(6,2,buffer,1959811526(121992/159/30)) lseek err Invalid argument
file_pread(6,1,buffer,1959811526(121992/159/30)) lseek err Invalid argument
NTFS: Can't read MFT
HPFS - NTFS 121600 254 63 243201 253 62 1953520002
This partition ends after the disk limits. (start=1953520064, size=1953520002, end=3907040065, disk end=1953525168)
file_pread(6,2,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(6,1,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(6,2,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(6,8,buffer,1953525183(121601/81/16)) lseek err Invalid argument
file_pread(6,1,buffer,1953525183(121601/81/16)) lseek err Invalid argument
file_pread(6,8,buffer,1953525311(121601/83/18)) lseek err Invalid argument
file_pread(6,8,buffer,1953525439(121601/85/20)) lseek err Invalid argument
file_pread(6,8,buffer,1953525567(121601/87/22)) lseek err Invalid argument
file_pread(6,8,buffer,1953525695(121601/89/24)) lseek err Invalid argument
file_pread(6,14,buffer,1953525762(121601/90/28)) lseek err Invalid argument
file_pread(6,3,buffer,1953525776(121601/90/42)) lseek err Invalid argument
file_pread(6,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(6,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(6,11,buffer,1953525886(121601/92/26)) lseek err Invalid argument
file_pread(6,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
The harddisk (1000 GB / 931 GiB) seems too small! (< 2000 GB / 1863 GiB)
* HPFS - NTFS 0 1 1 121600 254 63 1953520002
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Not an exFAT boot sector.
1 * HPFS - NTFS 0 1 1 121600 254 63 1953520002
mftmirr_lcn 2
mftmirr_lcn 2
file_pread(6,1,buffer,1953525760(121601/90/26)) lseek err Invalid argument
test_FAT()
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
Re: Newbie, PLEASE help
Go in Advanced, select the partition, use type to switch it to NTFS, Boot, RebuildBS, List.
If you can see your files, choose Write, confirm, Quit and post the new log file content.
