Micro SD card partition lost/damaged
Eddga
#1 Post by Eddga »
Dear file rescuers out there,
A friend of mine asked me to recover files (especially jpg photos) from his obviously damaged 32 GB Transcend micro SD card. He told me that he just removed it from its smartphone, put it in a laptops micro sd card slot, which then said that the card was corrupt.
Before doing anything he asked me what to do and so I told him to definitely not format it. He then cancelled the windows formatting request safely (he always does that even on the phone) removed it from the laptop and handed it over to me.
After the second time now of investing hours and hours in recovering the files, I was at least able to recover some of the photos but certainly not all.
The only tools that helped me yet were Wondershare Data Recovery and CardReader which both recovered an respectable amount of files from the card.
chdsk is not working, as windows detects the card as unformatted which testdisk and many other tools do, too. Tells my that file system type is RAW and that CHKDSK isn't available for RAW-disks.
PhotoRec successfully recovers about 20 photos until (like other tools did too) at a certain sector area (about 4% ~250,000 of ~6,000,000) it maybe only faces bad sectors because it needs about 30 seconds for each sector to scan, which in return tells me that it would take about 6 hours to finish.
When using testdisk (analyze) for trying to recover a partition it gets stuck also at about 4 % every time at the same cylinder (186 of ~3,800), won't continue and react to any keyboard inputs anymore.
I read a hint for that cloning the device could help with that?
Any advice or ideas for me to try? Don't exactly know what is meant by cloning.
Still the card was not formatted at any time since the "corruption".
Thanks in advance for your help and the work you do here. Love your tools. :)
Best regards,
Eddga
testdisk.log
Wed Jan 31 16:00:53 2018
TestDisk 7.1-WIP, Data Recovery Utility, January 2018
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=31674335232
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=2000398931968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=31674335232
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000398931968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=674547892224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=31674335232
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=2000263577600
Disk /dev/sda - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - Crucial_CT750MX300SSD1, S/N:1616130D31AB, FW:M0CR060
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DM001-9YN164, S/N:Z1F0RGRQ, FW:CC4C
Disk /dev/sdc - 31 GB / 29 GiB - CHS 3850 255 63, sector size=512 - Generic STORAGE DEVICE, S/N:000000000828, FW:0828
Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - TOSHIBA External USB 3.0, S/N:20131223046368, FW:5438
Disk /dev/sdc - 31 GB / 29 GiB - Generic STORAGE DEVICE
Analyse Disk /dev/sdc - 31 GB / 29 GiB - CHS 3850 255 63
qphotorec.log
de
translator not installed
Wed Jan 31 16:03:10 2018
PhotoRec 7.1-WIP, Data Recovery Utility, January 2018
Compiler: GCC 4.9, MinGW 3.11
ext2fs lib: none, ntfs lib: 10:0:0, ewf lib: 20140608, libjpeg: libjpeg-turbo-1.3.1
Disk \\.\PhysicalDrive0 - 750 GB / 698 GiB (RO) - Crucial_CT750MX300SSD1
 3 P MS Reserved             70  61 56    72  71 63      32768 [Microsoft reserved partition]
     Unknown                  0   0  1 91201  80 63 1465149168 [Whole disk]
 1 P Windows Recovery Env     0  32 33    57 126  5     921600 [Basic data partition]
 2 P EFI System              57 126  6    70  61 55     204800 [EFI system partition]
 4 P MS Data                 72  72  1 82081 100  3 1317476352 [Basic data partition]
     NTFS, blocksize=4096, 674 GB / 628 GiB
Partition table type defaults to None
Disk \\.\PhysicalDrive2 - 31 GB / 29 GiB (RO) - Generic STORAGE DEVICE
   P Unknown                  0   0  1  3850 217 15   61863936
713 first-level signatures enabled
blocksize=16384, offset=0
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0001632.fat	 1632-1663
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0003552.fat	 3552-3583
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0014464.fat	 14464-14495
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0014496.fat	 14496-14527
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0016672.fat	 16672-16703
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0018944.fat	 18944-18975
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0018976.fat	 18976-19007
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0019808.fat	 19808-19839
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0024768.fat	 24768-24799
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0024800.fat	 24800-24831
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0024896.fat	 24896-24927
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0025088.xml	 25088-25119
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0025120.xml	 25120-25151
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0026816.fat	 26816-26847
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0029120.fat	 29120-29151
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0029152.fat	 29152-29183
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0030144.fat	 30144-30175
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0031872.fat	 31872-31903
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0031904.fat	 31904-31935
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0035808.fat	 35808-35839
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0036032.xml	 36032-36063
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0036064.fat	 36064-36095
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0037504.fat	 37504-37535
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0038848.fat	 38848-38879
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0040768.fat	 40768-40799
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0040896.fat	 40896-40927
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0041152.fat	 41152-41183
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0041312.fat	 41312-41343
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0044736.fat	 44736-44767
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0044768.flac	 44768-47935
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0047936.fat	 47936-47967
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0053280.gz	 53280-187391
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0187392.xml	 187392-187423
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0187424.xml	 187424-187455
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0187936.jpg	 187936-204383
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0187648.jpg	 187648-187935 204384-213919
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0213920.jpg	 213920-225119
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0225120.jpg	 225120-236447
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0236448.jpg	 236448-247839
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0247840.jpg	 247840-258495
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0258496.jpg	 258496-270399
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0270400.jpg	 270400-281567
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0281600.jpg	 281600-292543
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0292544.jpg	 292544-302783
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0302784.jpg	 302784-313215
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0313216.jpg	 313216-324127
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0324128.jpg	 324128-334911
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0334912.jpg	 334912-344383
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0344480.jpg	 344480-363167
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0363232.xml	 363232-363263
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0363264.xml	 363264-363295
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0363328.jpg	 363328-375519
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0375520.jpg	 375520-387967
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0387968.jpg	 387968-400415
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0400416.jpg	 400416-413631
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0413632.jpg	 413632-425919
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0425920.jpg	 425920-437951
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0438304.jpg	 438304-449887
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0457152.fat	 457152-457183
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0457184.fat	 457184-457215
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0457216.fat	 457216-457247
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0457248.fat	 457248-457279
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0457280.fat	 457280-457311
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0457312.fat	 457312-457343
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0457344.fat	 457344-457375
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0457376.fat	 457376-457407
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0457440.tar.gz	 457440-457471
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0457472.gz	 457472-518431
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0518432.gz	 518432-524031
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0524032.gz	 524032-524447
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0524448.gz	 524448-524511
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0524512.gz	 524512-524735
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0524736.gz	 524736-524799
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0524800.gz	 524800-524895
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0524896.gz	 524896-524927
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0524928.gz	 524928-525087
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0525088.gz	 525088-525215
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0525216.gz	 525216-525375
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0525376.gz	 525376-525407
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0525408.gz	 525408-525503
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0525504.gz	 525504-525535
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0525536.gz	 525536-525631
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0525632.gz	 525632-525663
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0525664.gz	 525664-525759
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0525760.gz	 525760-530591
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0530592.gz	 530592-530751
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0530752.gz	 530752-530815
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0530816.gz	 530816-530911
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0530912.gz	 530912-530975
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0530976.gz	 530976-531167
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0531168.gz	 531168-531199
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0531200.gz	 531200-531423
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0531424.gz	 531424-531455
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0531456.gz	 531456-534271
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0540384.gz	 540384-540447
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0540448.gz	 540448-540671
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0540672.gz	 540672-540831
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0540832.gz	 540832-540959
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0540960.gz	 540960-540991
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0540992.gz	 540992-541087
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0541088.gz	 541088-541119
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0541120.gz	 541120-541311
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0541312.gz	 541312-543263
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0543264.gz	 543264-543391
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0543392.gz	 543392-543423
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0543424.gz	 543424-543519
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0543520.gz	 543520-543903
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0543904.gz	 543904-544063
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0544064.gz	 544064-544095
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0544096.gz	 544096-544255
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0544256.gz	 544256-544799
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0544800.gz	 544800-544927
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0544928.gz	 544928-546495
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0546496.gz	 546496-549951
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0549952.gz	 549952-550239
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0550240.gz	 550240-550335
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0550336.gz	 550336-550847
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0550848.gz	 550848-551711
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0551712.gz	 551712-555039
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0555040.gz	 555040-555839
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0555840.gz	 555840-557151
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0557152.gz	 557152-557471
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0557472.gz	 557472-557535
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0557536.gz	 557536-557631
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0557632.gz	 557632-563167
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0563168.jpg	 563168-574559
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0574560.jpg	 574560-585951
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0593760.gz	 593760-594847
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0594848.gz	 594848-595519
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0595520.gz	 595520-595551
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0595552.gz	 595552-595711
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0595712.gz	 595712-595743
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0595744.gz	 595744-596063
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0596064.gz	 596064-598879
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0598880.gz	 598880-598911
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0598912.gz	 598912-599199
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0599200.gz	 599200-612639
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0612640.jpg	 612640-624511
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0624512.jpg	 624512-635967
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0635968.jpg	 635968-647775
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0647776.jpg	 647776-658783
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0658784.jpg	 658784-670207
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0670208.jpg	 670208-681855
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0681856.jpg	 681856-693631
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0700544.gz	 700544-719103
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0719104.gz	 719104-719135
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0719136.gz	 719136-719519
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0719520.gz	 719520-720575
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0720576.gz	 720576-721727
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0721728.gz	 721728-722207
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0722208.gz	 722208-723295
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0723296.gz	 723296-723327
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0723328.gz	 723328-723615
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0723616.gz	 723616-724447
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0724448.gz	 724448-725055
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0725056.gz	 725056-725375
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0725376.gz	 725376-725855
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0725856.gz	 725856-725919
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0725920.gz	 725920-726175
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0726176.gz	 726176-727967
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0727968.gz	 727968-728511
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0728512.gz	 728512-730559
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0730560.gz	 730560-731871
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0731872.gz	 731872-731903
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0731904.gz	 731904-732447
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0732448.gz	 732448-732607
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0732608.gz	 732608-732927
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0732928.gz	 732928-735647
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0735648.gz	 735648-735711
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0735712.gz	 735712-735871
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0735872.gz	 735872-735903
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0735904.gz	 735904-737919
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0737920.jpg	 737920-749695
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0749696.jpg	 749696-760991
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0760992.jpg	 760992-772415
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0773440.fat	 773440-773471
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0773472.fat	 773472-773503
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0773632.fat	 773632-773663
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0773664.fat	 773664-773695
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0773920.fat	 773920-773951
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0773952.fat	 773952-773983
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0773984.fat	 773984-774015
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0772416.jpg	 772416-773439 773504-773631 773696-773919 774016-784799
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0794976.fat	 794976-795007
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0795008.fat	 795008-795039
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0784800.jpg	 784800-794975 795040-797439
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0797440.jpg	 797440-810463
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0811520.gz	 811520-821759
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0821760.gz	 821760-821855
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0821856.gz	 821856-822015
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0822016.gz	 822016-822047
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0822048.gz	 822048-822495
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0822496.gz	 822496-822527
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0822528.gz	 822528-822719
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0822720.gz	 822720-822943
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0822944.gz	 822944-823231
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0823232.gz	 823232-823679
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0823680.gz	 823680-825055
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0825056.fat	 825056-825087
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0825088.fat	 825088-825119
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0825120.fat	 825120-825151
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0826336.gz	 826336-826367
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0826368.gz	 826368-826463
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0826464.gz	 826464-827743
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0827744.gz	 827744-828127
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0828128.gz	 828128-829951
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0829952.gz	 829952-831327
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0831328.gz	 831328-831551
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0831552.gz	 831552-832959
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0832960.gz	 832960-833471
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0833472.gz	 833472-833727
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0833728.gz	 833728-834367
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0834368.gz	 834368-836767
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0836768.gz	 836768-837151
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0837152.gz	 837152-837535
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0837536.gz	 837536-837567
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0837568.gz	 837568-837663
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0837664.gz	 837664-837759
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0837760.gz	 837760-837855
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0837856.gz	 837856-837919
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0837920.gz	 837920-838015
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0838016.gz	 838016-838047
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0838048.gz	 838048-838143
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0838144.gz	 838144-841247
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0841248.gz	 841248-841631
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0841632.gz	 841632-841727
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0841728.gz	 841728-841759
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0841760.gz	 841760-841855
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0841856.gz	 841856-841887
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0841888.gz	 841888-841983
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0841984.gz	 841984-842047
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0842048.gz	 842048-842207
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0842208.gz	 842208-842367
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0842368.gz	 842368-842495
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0842496.gz	 842496-847071
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0847072.gz	 847072-855039
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0855040.gz	 855040-856543
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0856544.gz	 856544-857055
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0857056.gz	 857056-858687
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0858688.gz	 858688-859167
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0859168.gz	 859168-859391
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0859392.gz	 859392-864447
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0864448.gz	 864448-864543
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0864544.gz	 864544-864703
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0864704.gz	 864704-864735
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0864736.gz	 864736-864831
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0864832.gz	 864832-864927
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0864928.gz	 864928-865119
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0865120.gz	 865120-865983
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0865984.gz	 865984-866143
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0866144.gz	 866144-866175
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0866176.gz	 866176-866271
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0866272.gz	 866272-866303
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0866304.gz	 866304-866399
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0866400.gz	 866400-866431
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0866432.gz	 866432-866527
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0866528.gz	 866528-866591
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0866592.gz	 866592-866719
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0866720.gz	 866720-866751
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0866752.gz	 866752-867135
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0867136.gz	 867136-867295
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0867296.gz	 867296-867455
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0867456.gz	 867456-867647
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0867648.gz	 867648-867839
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0867840.gz	 867840-867967
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0867968.gz	 867968-868191
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0868192.gz	 868192-868543
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0868544.gz	 868544-869503
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0869504.gz	 869504-869535
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0869536.gz	 869536-869631
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0869632.gz	 869632-869663
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0869664.gz	 869664-869791
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0869792.gz	 869792-871391
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0871392.gz	 871392-871679
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0871680.gz	 871680-874623
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0874624.gz	 874624-874847
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0874848.gz	 874848-875039
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0875040.gz	 875040-875519
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0875520.gz	 875520-875551
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0875552.gz	 875552-879871
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0883488.gz	 883488-894271
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0894272.gz	 894272-920831
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0920832.gz	 920832-920959
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0920960.gz	 920960-921567
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0921568.gz	 921568-922463
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0922464.gz	 922464-922975
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0922976.gz	 922976-923263
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0923264.gz	 923264-923583
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0923584.gz	 923584-923743
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0923744.gz	 923744-926015
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0926016.gz	 926016-926751
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0926752.gz	 926752-927327
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0927328.gz	 927328-928351
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0928352.gz	 928352-928383
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0928384.gz	 928384-934463
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0934464.jpg	 934464-946015
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0946144.jpg	 946144-957439
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0965920.gz	 965920-966047
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0966048.gz	 966048-966143
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0966144.gz	 966144-966175
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0966176.gz	 966176-966303
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0966304.gz	 966304-967839
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0967840.gz	 967840-967935
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0967936.gz	 967936-968287
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0968288.gz	 968288-968447
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0968448.gz	 968448-968991
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0968992.gz	 968992-969247
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0969248.gz	 969248-969279
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0969280.gz	 969280-969375
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0969376.gz	 969376-969407
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0969408.gz	 969408-969503
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0969504.gz	 969504-969535
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0969536.gz	 969536-969631
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0969632.gz	 969632-990719
D:/Users/User1/Desktop/SDcard/recup_dir.4/f0990720.jpg	 990720-1003295
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1003520.xml	 1003520-1003551
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1003552.xml	 1003552-1003583
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1012992.gz	 1012992-1013023
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1013024.gz	 1013024-1013151
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1013152.gz	 1013152-1013183
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1013184.gz	 1013184-1013503
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1013504.gz	 1013504-1014847
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1014848.gz	 1014848-1015359
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1015360.gz	 1015360-1016543
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1016544.gz	 1016544-1016863
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1016864.gz	 1016864-1027967
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1027968.gz	 1027968-1028127
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1028128.gz	 1028128-1028223
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1028224.gz	 1028224-1028287
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1028288.gz	 1028288-1028415
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1028416.gz	 1028416-1028575
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1028576.gz	 1028576-1035071
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1035072.fat	 1035072-1035103
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1035104.xml	 1035104-1036159
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1036160.html	 1036160-1036191
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1036192.tar	 1036192-1062591
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1062592.jar	 1062592-1062623
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1068896.jar	 1068896-1073503
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1084416.tar	 1084416-1097535
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1097536.jar	 1097536-1097567
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1098240.jar	 1098240-1098303
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1099200.tar	 1099200-1117375
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1117376_res.zip	 1117376-1122815
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1153664.tar	 1153664-1208223
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1208224.png	 1208224-1208255
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1226208.txt	 1226208-1226239
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1230976.jar	 1230976-1231135
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1241216.jar	 1241216-1243135
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1245152.jar	 1245152-1245279
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1273632.tar	 1273632-1280095
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1280096_res.zip	 1280096-1280351
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1314464.tar	 1314464-1317631
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1317632.elf	 1317632-1322879
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1322880.tar	 1322880-1332447
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1332448.elf	 1332448-1334239
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1334240.tar	 1334240-1339391
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1339392.3gp	 1339392-1339551
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1341216.txt	 1341216-1341247
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1345312.txt	 1345312-1345375
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1355584.txt	 1355584-1355903
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1355904.txt	 1355904-1355967
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1357408.tar	 1357408-1405599
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1405600.jar	 1405600-1405631
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1411776.elf	 1411776-1414911
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1414912.elf	 1414912-1419775
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1419776.elf	 1419776-1431903
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1431904.tar	 1431904-1446879
File should not be bigger than 10485760, stop adding data
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1446880.elf	 1446880-1467359
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1487520.tar	 1487520-1523263
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1523264.ogg	 1523264-1523711
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1531520.tar	 1531520-1550559
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1550560.elf	 1550560-1553343
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1553344.tar	 1553344-1623583
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1623584.gz	 1623584-1635295
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1635296.gz	 1635296-1639231
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1639232.tar	 1639232-1650655
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1650656.gz	 1650656-1659455
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1659456.gz	 1659456-1664575
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1664576.gz	 1664576-1673183
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1673184.gz	 1673184-1675711
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1675712.tar	 1675712-1681247
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1681248.gz	 1681248-1691263
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1691264.tar	 1691264-1692767
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1692768.gz	 1692768-1702655
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1702656.tar	 1702656-1710623
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1710624.gz	 1710624-1723935
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1723936.tar	 1723936-1736575
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1736576.gz	 1736576-1758367
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1758368.gz	 1758368-1767679
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1767680.tar	 1767680-1768319
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1768320.gz	 1768320-1780735
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1780736.gz	 1780736-1783167
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1783168.gz	 1783168-1790943
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1790944.gz	 1790944-1800511
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1800512.tar	 1800512-1815039
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1815040.gz	 1815040-1825983
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1825984.tar	 1825984-1832799
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1832800.gz	 1832800-1837823
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1837824.tar	 1837824-1855327
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1855328.gz	 1855328-1870399
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1870400.tar	 1870400-1879295
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1879296.gz	 1879296-1903743
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1903744.gz	 1903744-1934015
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1934016.gz	 1934016-1944671
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1944672.gz	 1944672-1947423
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1947424.gz	 1947424-1952063
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1952064.gz	 1952064-1954111
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1954112.tar	 1954112-1956063
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1956064.gz	 1956064-1979487
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1979488.gz	 1979488-1997343
D:/Users/User1/Desktop/SDcard/recup_dir.4/f1997344.tar	 1997344-2034975
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2034976.gz	 2034976-2054015
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2054016.tar	 2054016-2085215
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2085216.gz	 2085216-2087679
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2087680.gz	 2087680-2088959
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2088960.gz	 2088960-2089919
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2089920.tar	 2089920-2090463
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2090464.sqlite	 2090464-2090527
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2090624.tar	 2090624-2091711
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2091712.xml	 2091712-2091743
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2091808.sqlite	 2091808-2092991
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2093920.tar	 2093920-2094783
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2094784.xml	 2094784-2094815
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2094912.tar	 2094912-2095103
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2095104.xml	 2095104-2095135
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2095168.sqlite	 2095168-2095199
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2095488.tar	 2095488-2097023
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2097024.avi	 2097024-2097055
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2097088.tar	 2097088-2097279
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2097280.avi	 2097280-2097311
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2097312.avi	 2097312-2097343
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2097376.tar	 2097376-2097503
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2097504.jpg	 2097504-2097535
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2097536.avi	 2097536-2097567
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2097568.tar	 2097568-2097663
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2097664.avi	 2097664-2097695
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2097696.tar	 2097696-2097727
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2097728.jpg	 2097728-2097759
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2097824.tar	 2097824-2097855
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2097856.jpg	 2097856-2097887
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2097888.jpg	 2097888-2097919
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2097952.tar	 2097952-2097983
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2097984.jpg	 2097984-2098015
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2098144.tar	 2098144-2098367
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2098368.jpg	 2098368-2098399
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2098400.tar	 2098400-2098431
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2098432.avi	 2098432-2098463
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2098624.avi	 2098624-2098655
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2098688.avi	 2098688-2098719
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2098720.avi	 2098720-2098751
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2098784.avi	 2098784-2098815
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2098816.tar	 2098816-2099007
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2099008.avi	 2099008-2099039
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2099168.tar	 2099168-2099295
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2099296.avi	 2099296-2099327
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2099328.tar	 2099328-2099935
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2099936.sqlite	 2099936-2099967
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2099968.xml	 2099968-2099999
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2100000.tar	 2100000-2102239
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2102240.sqlite	 2102240-2102271
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2102304.tar	 2102304-2102783
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2102784.jpg	 2102784-2102815
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2102816.tar	 2102816-2102975
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2102976.jpg	 2102976-2103007
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2103008.jpg	 2103008-2103039
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2103040.jpg	 2103040-2103071
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2103072.jpg	 2103072-2103103
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2103136.tar	 2103136-2104543
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2104544.xml	 2104544-2104575
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2105760.tar	 2105760-2114719
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2114720.ttf	 2114720-2114783
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2114880.tar	 2114880-2116831
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2116832.elf	 2116832-2123615
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2123616.html	 2123616-2123647
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2123840.xml	 2123840-2123871
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2124032.tar	 2124032-2129215
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2129216.jpg	 2129216-2129247
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2129248.tar	 2129248-2136607
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2136608.gif	 2136608-2136639
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2136640.txt	 2136640-2136703
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2136704.txt	 2136704-2136735
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2136736.txt	 2136736-2136767
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2136800.h	 2136800-2136831
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2136832.txt	 2136832-2136863
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2136864.tar	 2136864-2158111
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2158112.sqlite	 2158112-2158143
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2158624.sqlite	 2158624-2158655
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2159296.sqlite	 2159296-2159327
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2159392.tar	 2159392-2159423
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2159424.xml	 2159424-2159455
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2159456.xml	 2159456-2159487
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2159488.tar	 2159488-2189471
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2189472_classes.zip	 2189472-2190463
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2207776.jar	 2207776-2207999
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2211168.gif	 2211168-2211199
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2211264.txt	 2211264-2211423
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2211488.txt	 2211488-2211583
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2211648.txt	 2211648-2211775
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2211840.tar	 2211840-2211999
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2212000.gif	 2212000-2212031
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2212320.txt	 2212320-2212447
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2212576.tar	 2212576-2215327
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2215328.gif	 2215328-2215359
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2216128.gif	 2216128-2216159
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2216320.gif	 2216320-2216351
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2216352.tar	 2216352-2218143
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2218144.gif	 2218144-2218175
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2218336.gif	 2218336-2218367
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2219040.tar	 2219040-2219135
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2219136.gif	 2219136-2219167
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2219168.tar	 2219168-2220607
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2220608.gif	 2220608-2220639
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2221088.gif	 2221088-2221119
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2221216.gif	 2221216-2221247
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2221600.gif	 2221600-2221631
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2221920.tar	 2221920-2222111
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2222112.gif	 2222112-2222143
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2222816.txt	 2222816-2222847
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2223008.txt	 2223008-2223039
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2223136.tar	 2223136-2223999
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2224000.png	 2224000-2224031
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2224384.tar	 2224384-2227103
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2227104.gif	 2227104-2227135
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2227552.tar	 2227552-2233727
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2233728.png	 2233728-2233791
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2233824.xml	 2233824-2233855
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2233856.txt	 2233856-2233887
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2234016.tar	 2234016-2249567
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2249568.gif	 2249568-2249599
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2249856.tar	 2249856-2250111
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2250112.jpg	 2250112-2250175
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2250464.gif	 2250464-2250495
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2250560.tar	 2250560-2253951
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2253952.jar	 2253952-2253983
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2254016.tar	 2254016-2290591
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2290592.png	 2290592-2290623
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2300960.txt	 2300960-2300991
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2306528.png	 2306528-2306559
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2360608.png	 2360608-2360639
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2420256.txt	 2420256-2420287
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2420384.txt	 2420384-2420415
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2435616.tar	 2435616-2621727
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2621728.png	 2621728-2621759
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2629216.tar	 2629216-2896831
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2896832.gz	 2896832-2896895
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2896896.gz	 2896896-2897055
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2897056.tar	 2897056-2905951
D:/Users/User1/Desktop/SDcard/recup_dir.4/f2905952.tar.gz	 2905952-2905983
D:/Users/User1/Desktop/SDcard/recup_dir.5/f2905984.gz	 2905984-2906527
D:/Users/User1/Desktop/SDcard/recup_dir.5/f2906528.tar.gz	 2906528-2906559
D:/Users/User1/Desktop/SDcard/recup_dir.5/f2906560.gz	 2906560-2907583
file_win32_pread(768,928,buffer,2997696(186/152/31)) read err: read after end of file
file_win32_pread(768,1024,buffer,2998528(186/165/44)) read err: read after end of file
file_win32_pread(768,1,buffer,2998528(186/165/44)) read err: read after end of file
file_win32_pread(768,1024,buffer,2999456(186/180/27)) read err: read after end of file
file_win32_pread(768,928,buffer,3000480(186/196/43)) read err: read after end of file
file_win32_pread(768,928,buffer,3001408(186/211/26)) read err: read after end of file
PhotoRec has been stopped
D:/Users/User1/Desktop/SDcard/recup_dir.5/f2907584.gz	 2907584-3001311
Re: Micro SD card partition lost/damaged
You can use testdisk, Advanced, Image Creation but the recommended way to clone the memory card is to use ddrescue, it's described in https://www.cgsecurity.org/testdisk.pdf
Once it's done, use photorec on the image.dd file (select the file in windows file explorer, right click, open with, select photorec)
Eddga
#3 Post by Eddga »
Bonjour monsieur Grenier,
Thank you very much for your answer and help.
I successfully created a *.img of the SD card with ddrescue which also didn't face any errors or bad sectors. The dd map also has shown the SD card as 100 % healthy.
TestDisk and PhotoRec now work on the .img without getting stucked. Unfortunately neither was PR able to recover any additional photos nor was TD able to find any partitions.
Also tried mounting the *.img and using chkdsk again -> still says it's RAW and won't work on it.
Do someone have any further ideas on this?
Would it be worth a try formatting the SD, backing the BS or Partition table up, rewriting the data from the image and restore the BS from the backup? Does this make any sense (I guess not)?
Thanks in advance for your kind help.
Best regards,
Eddga
