Help with recovery of an LVM Volume
walkitinkid
#1 Post by walkitinkid »
I'm trying to recover and LVM Volume. Using test disk. The Volume is located at /dev/sdb
Gparted looks like this:
Thing is, I'm not sure if the volume was formatted and now it's blank or if the LVM Volume is just damaged.
Any way to tell?
I'm trying to proceed in the safest way possible, ultimately I'd like to repair the LVM, but would settle for a file recovery.
So here's how far I've gone in testdisk...
 Disk /dev/sda - 8000 GB / 7451 GiB - DELL PERC H330 Mini
>Disk /dev/sdb - 3839 GB / 3575 GiB - DELL PERC H330 Mini
 Disk /dev/sdc - 536 GB / 500 GiB - General UDisk
 Disk /dev/mapper/VG_XenStorage--48ad482d--31de--bfeb--dbba--2fab3fbe8892-MGT -
 Disk /dev/mapper/VG_XenStorage--48ad482d--31de--bfeb--dbba--2fab3fbe8892-VHD--0
 Disk /dev/mapper/VG_XenStorage--48ad482d--31de--bfeb--dbba--2fab3fbe8892-VHD--1
>[Previous]  [  Next  ]  [Proceed ]  [  Quit  ]
If a disk listed above has incorrect size, check HD jumper settings, BIOS
Select my drive. Check. I dont see any other options so I think I did that right.
estDisk 7.0, Data Recovery Utility, April 2015
 [Intel  ] Intel/PC partition
>[EFI GPT] EFI GPT partition map (Mac i386, some x86_64...)
 [Humax  ] Humax partition table
 [Mac    ] Apple partition map
 [None   ] Non partitioned media
 [Sun    ] Sun Solaris partition
 [XBox   ] XBox partition
Hint: EFI GPT partition table type has been detected.
Note: Do NOT select 'None' for media with only a single partition. It's very
rare for a disk to be 'Non-partitioned'.
Detected EFI GPT, seems to make sense. I dont see any other options so I think I did that right.
     CHS 466784 255 63 - sector size=512
>[ Analyse  ] Analyse current partition structure and search for lost partitions
 [ Advanced ] Filesystem Utils
 [ Options  ] Modify options
 [ Quit     ] Return to disk selection
Note: Correct disk geometry is required for a successful recovery. 'Analyse'
process may give some warnings if it thinks the logical geometry is mismatched.
HERE! should I choose advanced? to do a partition recovery?
Disk /dev/sdb - 3839 GB / 3575 GiB - CHS 466784 255 63
 1 P MS Data                     2048    8388641    8386594 [root-dxovkaup]
 2 P MS Data                  8390656   16777249    8386594
No LVM or LVM2 structure
 3 P Linux LVM               16779264 7498891230 7482111967 [Linux LVM]
                P=Primary  D=Deleted
>[Quick Search]  [ Backup ]
                            Try to locate partition
It seems this option is for scanning the drive and doing a file recovery...
>P MS Data                     2048    8388639    8386592 [root-dxovkaup]
 D MS Data                 28244664  101436087   73191424
 D MS Data                 66893545  140084968   73191424
 D MS Data                140084968  213276391   73191424
 P Mac HFS                406206199  431375609   25169411 [D^B]
 P Mac HFS                472655021  497824431   25169411 [D^_]
 P Mac HFS                540520729  565690139   25169411 [D^\]
 D MS Data                606316969  679508392   73191424
 D MS Data                679508392  752699815   73191424
 D MS Data                758992961  832184384   73191424
 D MS Data                832184384  905375807   73191424
 P Mac HFS               1077146704 1086321806    9175103
                P=Primary  D=Deleted
     Enter: to continue
ext3 blocksize=4096 Large_file Sparse_SB, 4293 MB / 4095 MiB
or maybe not? This disk has about 30 or forty listings like this, I dont see anything referred to as linux LVM.
Re: Help with recovery of an LVM Volume
Are you able to list files from ext3 partitions found by testdisk ?
It's difficult to recover LVM data, an example is listed at https://www.centos.org/docs/5/html/Clus ... cover.html
